Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 10-09-2021, 02:43 PM   #1
dadstoy's Avatar
1982 28' Airstream 280
_ , _
Cruise Control
Anyone know what cruise control this is on my '82 280? It worked well for years, but not working at all now. Are there any docs for this CC? I would replace it with aftermarket, but not feasible at this time. Thanks!
dadstoy is offline   Reply With Quote
Old 10-09-2021, 07:15 PM   #2
Antsville , FUBAR
Appears to be a stock GM Vacuum unit, appears a 454 ...I recall seeing them on the Workhorse chassis...ck all the lines make sure they are good and all cables free.
You could search the salvage yards but a new aftermarket may be the best option.
Old 10-09-2021, 07:56 PM   #3
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Following up on Bobís advice, besides the vacuum lines check the switch on the brake pedal arm. GM systems had a plunger switch that would disengage the cruise when the brake pedal was depressed. If the switch is out of adjustment the cruise will not engage.
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 10-09-2021, 08:20 PM   #4
Antsville , FUBAR
Ahhh yes, I remember how a pot hole could dis-engage on our 95 burb.
Old 10-09-2021, 08:29 PM   #5
dadstoy's Avatar
_ , _
A couple weeks back when I checked all vacuum lines and vacuum components on the top of the engine, I also checked the vacuum lines for the cruise control as well. I also verified the brake switch is functioning and is adjusted properly.
Cruise or not cruise? badkat On The Road... 39 07-23-2016 07:37 AM
Cruise Control Chaplain Kent Mechanics Corner - Engines, Transmission & More... 4 10-14-2004 08:56 PM
1984 motorhome cruise control cooperhawk Airstream Motorhome Forums 2 12-25-2003 09:12 AM
No cruise control on '92 30' fangthorpe Mechanics Corner - Engines, Transmission & More... 3 05-09-2003 10:46 PM
Cruise Control Servo Diaphram zamboni Airstream Motorhome Forums 5 06-26-2002 10:14 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
