RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-30-2018, 03:25 PM   #1
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte , North Carolina
Critter prevention 345 LE
What holes in the MH readily admit critters? Haven't been in the MH in 6 weeks, discovered a ~10" long snake skin (really small diameter) near the accelerator pedal. Immediately after purchase, I found a partial skin in the minute gap under the dinette headed towards the bath.
Is there such a thing as a sure-fire means of keeping mice, spiders & snakes out?
wimpy is offline   Reply With Quote
Old 08-30-2018, 03:58 PM   #2
Long Island , New York
Probably not IMO.
Old 08-30-2018, 04:38 PM   #3
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Most get in around the shower drain area, and the holes under the toilet base, very sloppy sealing job right from the factory,seems like hole saws were not invented yet back in the 80ís when they built most of these, you will see that wherever plumbing goes through the floor whether itís a vent pipe or a drain pipe they cut a square or somewhat square hole through the floor and tried to patch it with 2 pieces of scrap aluminum with half circles that somewhat were supposed to overlap. I took care of all of my holes, completely.....no more mice. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 08-30-2018, 07:07 PM   #4
1986 34.5' Airstream 345
Alliance , Ohio
Mice were getting in my 345 around the shower drain. I think they used a chain saw or broad axe at the factory. Like Bob said the plumbing drains seem to be the most frequent spot left open by the factory. I would check around gas and water lines as well.
mehes is offline   Reply With Quote
Old 08-30-2018, 08:05 PM   #5
1982 28' Airstream 280
Redwood City , California
What are folks using to seal up around pipes, etc.? I need to reseal some of mine.
"A nation that isn't broken but simply unfinished" -
Amanda Gorman
dadstoy is online now   Reply With Quote
Old 08-31-2018, 05:55 AM   #6
Alliance , Ohio
I cut some pieces of sheetmetal to surround the pipes or whatever and screwed them to the underside of the floor, Sealed with caulk or silicone you should be good to go.
Old 08-31-2018, 06:07 AM   #7
. . . should be good to go.
What about the other critters mentioned in the original post?
The only adjustment which can eliminate these as issues in our minds, is to change the operating system of the bio-mass at the tops of our heads.
After doing the best preventative steps, turn inward for further corrective measures IMO.
Animals are a part of life, and we have willingly entered their natural world in our RV's and trailers.
Old 08-31-2018, 06:25 AM   #8
Ebro , Fla Panhandle
Multiple snake skins, yikes, they might help with mice control tho.
I see some time on your back in your near future.
A big sheet of cardboard and a flashlight are your friends.
Plumbers putty for the smaller openings you find like propane pipes, heater hoses etc.
Cheers Richard
tevake is offline   Reply With Quote
Old 08-31-2018, 07:17 AM   #9
Magnet18's Avatar
Churubusco , Indiana
I've noticed a small gap under the gas/brake pedals, might take a look there
My shower/toilet were sealed well with expanding spray foam, I haven't had any issues
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 08-31-2018, 07:19 AM   #10
Totally agree, just don't want to deal with better half discovering a slithering "monster".
Old 08-31-2018, 10:06 AM   #11
Understood!
Old 08-31-2018, 10:17 AM   #12
1988 Argosy 32
Lomita , California
i use stainless scrub pads stuffed into gaps they can't eat it and water drains out a +.
Wolfe is offline   Reply With Quote
Old 08-31-2018, 10:41 AM   #13
2017 25' Flying Cloud
tarzana , California
Buy some Dove soap and cut it to two parts. That should help.
frank nordyk is offline   Reply With Quote
Old 08-31-2018, 12:12 PM   #14
2007 22' International CCD
Have a look at this stuff. Cuts with scissors, won't rot or dry out, still allows some air movement and water drainage when installed, but critters will not eat it.
Particularly good for plugging the ends of the A-frame that are open to the environment, stuffing into plumbing openings, etc. Stays in place, but can be pulled out for repairs. Not cheap, but worth it...
https://www.amazon.com/s?url=search-...2+X+10%27+ROLL
No, just a happy user of the stuff. Works on houses as well...
And here is a copper mesh version:
https://www.amazon.com/s?url=search-...+Birds+Control
Old 08-31-2018, 02:54 PM   #15
2019 25' International
Washington , Washington, D.C.
Stuff steel wool into any gap you can find.
PatLee is offline   Reply With Quote
Old 08-31-2018, 03:42 PM   #16
Doesn't steel wool rust away, make a mess, and eventually disappear? Copper mesh idea in Post #14, and stainless pads in #12.
Old 08-31-2018, 04:32 PM   #17
Magnet18's Avatar
Steel wool will rust and make a mess
Copper will too, but much slower
Regarding spiders, let me know if you find anything!
I've heard tales of some chemical back in the 50s that has since been outlawed decades ago, but my relatives in texas simply put a bottle of it in the outdoor shed, cap on mind you, and not a single bug ever ventured in.
-Rob
Old 08-31-2018, 05:28 PM   #18
For spiders, CruizinDux Bob swears by dog flea collars cut up for his FC20's fridge and water heater mechanical spaces. Maybe get a few for the 345 and give it a try?
Have a good Labor Day weekend, all!
Peter
Old 08-31-2018, 06:52 PM   #19
3wd67rg's Avatar
1988 32.5' Airstream 325
WhereIam , Left Coast Proud
DDT?? Of course, now that we are living in Texas, pretty much explains everything.
3wd67rg is offline   Reply With Quote
Old 09-06-2018, 08:33 AM   #20
Magnet18's Avatar
LOL, probably
Bug and Critter Protection...To the Extreme! mopariac Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 09-23-2015 08:39 AM
Critter-Proofing my AS mopariac Steps 2 08-24-2013 10:52 AM
Fire Prevention/Escape Plan Foiled Again Off Topic Forum 21 05-05-2010 11:58 PM
Interesting Article on Wood Preservation and Rot Prevention Pick Repairing/Replacing Floor &/or Frame 0 07-29-2005 12:34 PM
rear tub sag prevention and axle replacement sovereignrwe Axles 10 07-23-2004 04:25 PM
