Old 10-08-2017, 02:40 PM   #1
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Classic motor home shower re-do
ID:	296512Click image for larger version
ID:	296513Click image for larger version
ID:	296514Click image for larger version
ID:	296515Click image for larger version
ID:	296516Click image for larger version
ID:	296517Click image for larger version
ID:	296518Click image for larger version
ID:	296519Click image for larger version
bobmiller1 is offline   Reply With Quote
Old 10-08-2017, 04:20 PM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
That really turned out beautiful
mayco is offline   Reply With Quote
Old 10-08-2017, 04:39 PM   #3
1986 34.5' Airstream 345
Alliance , Ohio
Thanks Bob. This will certainly help with my redo. Other than the height of the doorway is the fiberglass replacement shower pan a duplicate of the original? Did you secure it to the side walls with screws like the original?
mehes is offline   Reply With Quote
Old 10-08-2017, 05:21 PM   #4
bobmiller1's Avatar
The new shower pan was made from a new mold of the original shower pan with the exception that there was no cut out for the shower door as can be seen in the picture with the original pan. This resulted in raising the door 4 inches in addition to having the opening 4 inches wider than with the original shower door/curtain opening. It was not necessary to screw the sides in to the wall because the new pan is 4 times the thickness of the original resulting in a stronger base. The new pan is only screwed into the new 3/4" oak doorway.Click image for larger version
ID:	296528Click image for larger version
ID:	296529Click image for larger version
ID:	296530Click image for larger version
Old 10-08-2017, 05:24 PM   #5
bobmiller1's Avatar
Lance, did you pull the refrigerator or did you do it a different way ?
Old 10-08-2017, 10:35 PM   #6
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Bob's shower door install, and in-shower lighting is magnificent.
Being the gentleman that he is, he won't mention that during a tour of his 370 at the get together, that I cracked my head against the door glass as I attempted to check out the shower pan. It is so perfect, that it is invisible!
Simply beautiful workmanship!
streamquest is offline   Reply With Quote
Old 10-09-2017, 04:54 AM   #7
Alliance , Ohio
Bob on my 345 the shower is installed between a wardrobe closet to the rear, and the microwave and some draws forward. It shouldn't be too hard to access the screws providing I can contort this stiff body into the proper configuration. I will pull the refrigerator later this winter to install a baffle like yours.
Old 10-30-2017, 12:16 PM   #8
Very nice as always Bob.
Questions, that you may have answered in your thread or elsewhere, but maybe I missed...
Did you get the show pan made yourself, or did you buy it?
Where did you get the shower door?
Thanks in advance!
Old 10-30-2017, 01:57 PM   #9
bobmiller1's Avatar
One of my customers made a new heavier shower pan and the door is an American Standard, which requires the original door opening to be 4" wider which is no problem. Regards, Bob
Airstream Classic 350 LE Motor Home 1992 Orig. Owner SAirstream Classic 350 LE Motor eBay Watch Airstreams on eBay 0 11-28-2010 10:00 PM
Classic Motor Home Parts for Sale Howard Lefkowitz Classic Motorhomes 0 02-28-2009 10:04 AM
The Classic Is Featured In Motor Home Magazine Chaplain Kent Classic Motorhomes 9 11-24-2006 05:46 AM
The new "Classic" Motor Home?? 87MH Airstream "In the News" 7 04-14-2005 09:29 PM
classic motor home engine r&r wb13798 Airstream Motorhome Forums 33 02-14-2004 09:33 PM
