Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 04-25-2018, 05:14 PM   #21
1960 26' Overlander
1989 34.5' Airstream 345
Borger , Texas
Originally Posted by 1989_345LE View Post
Hi everyone.
My name is Jerry and I'm new to this forum and joined just for the purpose of joining this conversation. A few months ago I took on this 345LE project for my uncle and without considering that it might not be available tore out all of the deteriorated channel out of the sliding windows. Now I'm in a real bind.
I have high hopes that DJs guy can produce this stuff but need to work on a plan "B" in case it doesn't happen. I have approached a couple of different extrusion companies here in the Denver area and it can be done but the tooling and minimum run costs are outrageously expensive.
Does anyone know who or where produced the original window channel?
If we could get our hands on the dies it would be a huge savings.
I've tried talking to Airstream and they put zero effort into trying to help.
If anyone has any suggestions or input on how to further this project I would love to hear it.
Thanks for your time.
Jerry
I am in the need of at least one track right now. I am replacing the glass in a bathroom slider using plexiglass on my 1989 345.
I sure could use the tracks and the fuzzy channel. Where to purchase??
Chalee is offline   Reply With Quote
Old 04-25-2018, 08:50 PM   #22
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey,
I'll call my guy tomorrow, and get an update.
The fuzzy channel, I think I went through vintage airstream. Remember to punch holes where the vents are.
Sugestion, use lexicon for the window plexiglas is softer and scratches easier. You may want to check with a plastic mfger, and see if there is anything better . Plexiglass also yellows fairly quickly if my memory serves me correctly. Doesn't one of our airstream supplers have that glass.
RV solutions, where I'm getting my windsheilds from, claims they can make custom glass. Maybe they lol have something for you. Just a thought. DJ
davejay is offline   Reply With Quote
Old 04-30-2018, 07:34 AM   #23
Plattsburgh , New York
Hello airstreamsupply has complete window assemblies (kind of pricey)and some misc glass panels if that helps. Davejay you able to get a hold of your guy to see how hes making out on the window channels?Have a good day.
Gradients is offline   Reply With Quote
Old 05-01-2018, 09:36 PM   #24
Hey,
I'm sorry y'all, I keep forgetting to call him. I promise I will call him tomorrow and gives y'all an update. DJ
Old 05-03-2018, 07:24 PM   #25
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
bump
shepherd57 is offline   Reply With Quote
Old 05-08-2018, 08:51 AM   #26
Did you talk to him Davejay?
Old 05-08-2018, 06:49 PM   #27
Liberator
klattu's Avatar
1972 Argosy 24
Heart of Dixie , Alabama
Images: 834
https://www.dkhardware.com/7-16-x-3-...uct-18258.html
This place has many varieties.
Also this is good source.
http://odmrv.com/catalog/index.php?m...oducts_id=1302
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 05-08-2018, 06:53 PM   #28
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
https://www.vintagetrailersupply.com...-p/vts-278.htm
I'm thinking this is for all the framed sliding windows down the sides.
Click To See Me Wet
1972 Argosy 24'...
Old 05-16-2018, 08:36 PM   #29
Hey,
I talked to him Monday,and he's working on them. Having trouble with that center little V rise in the channel . The upsidedown v is to keep the window edges running true, and separated from each other. We're dabbling with the idea of making it like a little step up wall. As wide as the v, maybe a little taller, but the affect should be the same. Holding the windows apart so they don't touch, the fuzz does its job and looks correct,as well as working correctly. I'll give him a shout Thursday, and check on progress. Get back to y'all Friday. Ok? DJ
Old 05-17-2018, 08:08 PM   #30
Hey,
Well, I talked to my guy. He's having a little trouble with the lip of the channel that goes over the center aluminum part of the window frame. To my way of thinking, this little lip is not nessessary, if the bottom of the channel has a solid base. The design of the one channel is really poor. All the weight of the window is on the channel, and the center of the window, has a sharpe edge. So when you open the window, pressure is put on the little lip of the channel. Thus they crack in the middle of the channel right up by lip.
Our design change will eliminate the lip, retain the upsidedown V in the center of the channel , and fill in the bottom of the channel to where the weight and pressure of Open/closing the window will be on the base of the channel. And we re making the sides a little thicker. The screen and the window will stay where they were designed to be. They'll be separated as designed, so the fuzz does its job, and it'll look like it was stock. I'll keep y'all posted. DJ
Old 05-31-2018, 07:14 AM   #31
Any luck on the redesign?
Old 06-01-2018, 08:09 AM   #32
Hey,
I talked to him yesterday. He's got a new machine, that as we were speaking, was getting wired for power. He was having trouble with holding the material down on the table. He couldn't hold the tolerances. This new machine is like a huge computer driven router. The material is held to the table via vacum. I got another shop up here that does the same type of work, only on a mass scale.hes got that same type of machine. Very cool. He can take a 4x8 sheet of whatever and rout it out, to where it looks like the product was extruded. If I have to go to this shop. I'd have to commit to a huge run, to make it worth they're time. My guy has the same capabilities, on a smaller scale. He's a one man operation, so his time schedule is longer. I'll keep hall posted. DJ
Old 06-03-2018, 07:03 PM   #33
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Commit to the huge run as you'll sell a bunch to guys on this site, then sell the rest to Airstream Supply, Out of Doors mart, Vintage trailer supply and Inland RV.
Trust me, they will sell, and people will buy, at a reasonable price point.
I'll take 12 myself.
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 06-03-2018, 09:53 PM   #34
Undereducated AS Newbie
Charlotte , North Carolina
Pieces needed?
Is there just 1 length regardless of the window location? Would I just count my windows and that's the number of pieces I'd need? Regardless, I'm on board!
wimpy is offline   Reply With Quote
Old 06-04-2018, 06:09 AM   #35
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Ditto.....get the rights to it, cut us a break, and charge the SODOMY fee back to Inland, and the others !
bobmiller1 is offline   Reply With Quote
Old 06-04-2018, 07:02 AM   #36
If I'm not mistaken there are two pieces per window. All the slider windows are the same width so you just need a window count times two.
1975 24' Argosy Motor Home
Old 06-04-2018, 07:04 AM   #37
I'm in for 18 strips.....
Old 06-04-2018, 04:55 PM   #38
Dazed and Confused
Isuzusweet's Avatar
Brad stocking up for the many Argosy's on the horizon..........or he's seriously miscounted his windows; just sliders Brad, not fixed as well.
Told you they would sell.....
Cheers
Sidekick Tony
Old 06-04-2018, 04:59 PM   #39
Dazed and Confused
Isuzusweet's Avatar
Come to think about it I'll have to jazz my order up to 20? 7 windows on the Classic, 3 on the Argosy.
Question, the smaller slider on my 310 where the kitchen is takes the same length channel? Just checking.
Cheers
Sidekick Tony
Old 06-04-2018, 05:22 PM   #40
shepherd57's Avatar
Lindsay , Ontario
I don't think that they were used on the Argosy
C channel/U channel replacement cole3444 Repairing/Replacing Floor &/or Frame 11 04-17-2019 06:20 PM
'69 Window Gray U-Channel Rubber? 69bullet Windows & Screens 13 06-16-2017 11:10 PM
window channel felt? arden_dean General Motorhome Topics 5 05-23-2017 11:58 AM
U channel or C Channel???? vintageracer Repairing/Replacing Floor &/or Frame 5 01-24-2016 07:49 AM
'76 Argosy window channel rv-n Argosy Motorhomes 11 05-29-2009 10:36 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
