Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 09-22-2019, 07:03 PM   #1
Kvsterling's Avatar
1984 27' Airstream 270
West Chester , Ohio
Charlie the Airstream
We have owned our 1984 Airstream Excella 270 motorhome for about 16 months now. The goal was to fix up for some full time RVing for a couple years.
In the course of these months, I have relied on the body of knowledge on this forum and want to thank all the members who have shared your ownership adventure!
Thought it was time to start my own thread, try to do my part and give back to this community
So here is the deal, we bought the MH last year off craigslist. I was not really sure what to look for in a used unit, and we got a running “driving” MH about 1.5 hours away.
I did get it home, but not after a series of alternator/belt failures. That’s a thread in and of itself[emoji19]
I got it road worthy, used the MH for a few months, and started the To-Do list. One thing led to another, and we are neck deep in a full gutting of the interior. Had to address subfloor rot due to hundreds of failing Olympic rivets used in previous rear-shell damage/repair. My wife Veronica and I are doing the work, using local shops for some more specific and technical issues. Quick shout out to RV Clinic in Franklin, OH!
So we just reinstalled our walls after fixing all the leaks, floor, new vents, electrical re-wire almost everything, and insulate with Havelock Wool.
Up front I have wired in rear/side view camera system, stereo, speedometer/tach, wiper switch, found and repaired bunch of previous owner “fixes” which included several burnt grounding wires!!!
Next projects to install a Rostra cruise control system, reinstall fiberglass-repaired headliner, and rear bathroom shell repair/replace
We are really enjoying the community, please feel free to ask any questions about what we have done so far!
Updates on the way
Kyle
Most of our progress thus far is on Instagram: @airstreamcharlie
ID:	352783   Click image for larger version
Kvsterling is offline   Reply With Quote
Old 09-23-2019, 07:22 AM   #2
"Alumi-holic"
cesalie2's Avatar
1982 31' Airstream 310
Bartlett , Tennessee
Welcome! Nice to have a willing victim...err partner for the renovation!
cesalie2 is offline   Reply With Quote
Old 09-29-2019, 05:54 PM   #3
Kvsterling's Avatar
West Chester , Ohio
This weekend has been a good one! Back in December, the front headliner was removed along with all the other inner walls to address leaks. Up front was a leak behind one of the running lights. Replaced all running lights with LED and new gasket, but still had the headliner to repair. It was discolored with age and cracked about 8 inches in 2 places at the top and 4 small areas around the perimeter. All those areas have been fiberglassed and Bondo-ed. Primer/paint this weekend and should have it up next week!
Also finished the Rostra cruise control install while wifey primer/paints the interior and molded trim parts.
I wanted to do a test drive, but the seats are out and using the lawn chair was voted down.
ID:	353215   Click image for larger version
Old 09-29-2019, 05:58 PM   #4
Kvsterling's Avatar
West Chester , Ohio
Wanted to share some previous owner “Fixes.” I do NOT bring this up to jab the previous owner, we adore Charlie and happy to have her with her storied past. These just added a little flare to the project
Main grounding wire for 12 v system...3 butt connectors and 8 gauge wire...blackened by heat
Fridge vent with added fans, wired with very thin speaker wire and no connectors...just twisted wire
Anti freeze bottle, spray painted, and hanging by a zip tie as the coolant overflow reservoir
Washer bottle...see above
Newish antenna on side of RV, new cable ran, but cut wire under the dash (radio was never connected to the antenna)
The OEM cruise control system was disconnected (all wires cut), but almost all the components were left in place
Today found an alligator clip as connector the for power source to my carburetor.
Old 09-29-2019, 07:53 PM   #5
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Kinda makes you wonder......doesn’t it ? Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 10-06-2019, 05:21 PM   #6
Kvsterling's Avatar
West Chester , Ohio
So this weekend we got the headliner installed after repaired and painted, tank sensors and tank heaters installed, and a pair of speakers installed in the side panels. Seats reinstalled for a test drive to check side/rear view camera system, speedometer/tach, and cruise control. Also had oil change and coolant system flushed
All systems checked out but couldn’t get the cruise control working.
For those who did the universal Rostra CC, did the switch on the steering column need to be switched out as well?
Old 10-10-2019, 03:02 PM   #7
"Alumi-holic"
cesalie2's Avatar
Kyle,
Do you have any other photo’s of the Fiberglas and Bondo repair of the front end cap?
We have similar cracks on ours...
Old 10-10-2019, 03:13 PM   #8
Magnet18's Avatar
Churubusco , Indiana
My factory cruise control works, but it's very finnicky, gotta push the button *just* right, interested in seeing what you come up with as a replacement
+1 on the cap repair, looks great!
What paint did you use and do you think it will hold up well?
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 10-11-2019, 05:25 AM   #9
Kvsterling's Avatar
West Chester , Ohio
So this is the end cap after I used a Bondo brand fiberglass repair kit and Bondo body filler. One patch of fiberglass on either side of the plastic headliner. Then a few smaller patch repairs around the perimeter and behind the visor mount. Bondo body filler used very thin over this side to smooth the surface. I can barely tell, but chipped a little off during re-installation[emoji30]. It was pretty rough process trying to get the rear edge behind the ceiling skins. 3 attempts to reinstall but no cracks in any of the repaired areas
For the paint, we are using an Adhesion Primer which is supposed to be very durable on all kinds of surfaces (after a thorough cleaning), then household paint. I’m using these products based on what we have learned from an airstream renovation company we follow in Tx
Old 10-14-2019, 03:10 PM   #10
Kvsterling's Avatar
West Chester , Ohio
Sorry, the pic didn’t attach. This is after the Bondo, then primed
ID:	354244   Click image for larger version
Old 10-15-2019, 06:45 AM   #11
Magnet18's Avatar
Looks good!
What's the specific adhesion primer if you don't mind me asking?
-Rob
Old 10-16-2019, 05:33 AM   #12
Kvsterling's Avatar
West Chester , Ohio
Thanks!
This primer is supposed to be better at sticking to variety of surfaces that traditional paint/primer won’t. We have vinyl covered aluminum skins and plastic, so this was chosen for both areas. Heard about this from an airstream renovation guy. It’s a little difficult to find, but Kilz and Zinsser both make adhesion primer
Old 10-24-2019, 08:21 PM   #13
Kvsterling's Avatar
West Chester , Ohio
So I have a few things I will not be using in the rebuild. Let me know if there is any interest in the following:
30 amp power reel
Airstream Monitor panel
Tripplite 750 inverter Charger
Progressive Dynamics 60amp intellipower with charge wizard
ID:	354895   Click image for larger version
Old 10-25-2019, 03:41 AM   #14
1989 37' Airstream 370
Cleveland , Georgia
A/s parts
Kyle
Hi my name is Ken I'm vary much in need of this power reel please pm me with info
Thanks ken
Krg22 is offline   Reply With Quote
Old 10-25-2019, 04:55 AM   #15
Kvsterling's Avatar
West Chester , Ohio
Originally Posted by Krg22 View Post
Kyle
Thanks ken
PM sent
Old 10-25-2019, 05:00 AM   #16
Kvsterling's Avatar
West Chester , Ohio
Forgot to mention, won’t be re-using:
Black Holding tank (rebuild with composting toilet)
stovetop
refrigerator-is a 12v/120v, but I’m really wanting the propane option back
Old 10-29-2019, 01:19 PM   #17
Magnet18's Avatar
I'm really interested in the control panel
Regarding the black tank, I also swapped to composting, but i cut and welded mine and use it as extra grey storage/for urine
I'll post a link
Do you have any other interior "stuff" laying around?
-Rob
Old 10-29-2019, 01:27 PM   #18
Magnet18's Avatar
http://www.airforums.com/forums/f446...me-192589.html
Might not apply since you have a 270, but just note I found it's not that hard to modify the shape of the tanks if needed
-Rob
Old 10-30-2019, 06:42 AM   #19
Kvsterling's Avatar
West Chester , Ohio
Hi Rob, PM your address and I can get a shipping quote to you.
Did I see you used marine epoxy to to re weld the tank after you cut it?
The items I listed are the main things available. Most of my cabinetry was either water damaged, warped, or molded beyond what I would consider serviceable. I have a backrest for one of the convertible sofa bed I’m not using
Old 10-31-2019, 08:13 PM   #20
Kvsterling's Avatar
West Chester , Ohio
Thought I would share some recent success stories: Had some air conditioner problems I have been working though. We have a Dometic Penguin with heat pump (cerca 2003 I think), decided to repair instead of replace. This unit is pretty stout 15kBTU, just needs the maintenance. Wound up replacing capacitor and the blower motor, and seems to work just right, doesn’t over draw amp and shut down as it used to.
Also, the roller shade in the door was partially damaged and would never stay down. Turns out, the winding mechanism had been installed upside down. Welp...That had all been removed, new fringe seen on, and reinstalled skin with new (more) insulation.
Going into this weekend with a 4’x12’ sheet aluminum hoping to rebuild the rear bathroom end cap...and one final attempt to seal a leak I can’t find around the rear window[emoji19]
ID:	355366   Click image for larger version
Je Suis CHARLIE! cwf Off Topic Forum 12 01-10-2015 12:32 PM
Charlie Brown. . . maxandgeorgia Off Topic Forum 21 12-18-2006 06:59 PM
