Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 04-05-2021, 07:14 AM   #161
Peter417's Avatar
1966 17' Caravel
1972 21' Globetrotter
SW , Missouri
A boy airstream? That never happens any more. Nice work.
Peter417 is offline   Reply With Quote
Old 04-06-2021, 09:31 PM   #162
Kvsterling's Avatar
West Chester , Ohio
Originally Posted by Magnet18 View Post
What ubolts did you install after putting the spacer in?
Thank you for the part #s!
The shop did the spacer and u bolt, not sure about part #. Found out many of these spring shops make their own u-bolts, and can make them cheap for customers
Looks like my rad shop will be doing a re core with 9/16Ē tubes. Hope done by Friday and driving this weekend(fingers crossed)
Kvsterling is offline   Reply With Quote
Old 04-07-2021, 11:59 AM   #163
Magnet18's Avatar
Churubusco , Indiana
No problem!
I highly recommend michigan truck spring if you want them timely
Sdtruckspring is usually a few bucks cheaper but takes forever, mediocre customer service, and sometimes sends the wrong part
I was curious about the ubolts because neither Chris nor I found ones the right profile to match the originals. Would love some close ups of what they made you if you get a chance, no big deal, don't make a special trip under the airstream for it!
Magnet18 is offline   Reply With Quote
Old 04-08-2021, 08:28 AM   #164
Kvsterling's Avatar
West Chester , Ohio
Here are the left and right respectively. Looks like the matched the original profile pretty close. Iím guessing the shop made these, but lists part number SPG 8T3428 U BOLT $18.95
SPG DN 34 nut $1.41
SPG SUW-34 washer $.87
ID:	392734   Click image for larger version
Old 04-12-2021, 06:28 PM   #165
Kvsterling's Avatar
West Chester , Ohio
[ATTACH]393074
Check out the crap that built up in there! Said there was some silicone from thermostat changes that breaks loose and plugs the tubes. The old core alone weighs about as much as the new reassembled radiator with 9/16Ē tubes (build up and corrosion). The shop took about a week to turn it around and was $660. Seems like a good deal, re-installing this afternoon
Old 04-12-2021, 07:03 PM   #166
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
The larger tubes will make it flow better and dissipate the heat faster .....make sure you change the thermostat and use lots of silicone ! LOL, best of luck, let me know how your new fan works with the fan clutch. Regards, Bob
bobmiller1 is online now   Reply With Quote
Old 04-13-2021, 07:05 PM   #167
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
The "thing" about thermostats: boiled both the old and new (180 degrees). They both started to open at 180. Old never opened all the way...
AIR #13
PeterH-350LE is online now   Reply With Quote
Old 04-13-2021, 07:42 PM   #168
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Peter, I think that you need to run the 195 because of the TBI system and computer!?
I'm just amazed they use this small thermostat in an engine that is prone to high heat issues!?
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (274,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 04-13-2021, 07:52 PM   #169
Airstream Driver
1994 30' Excella
Images: 49
I don't recall where I got the 180 degree being the best one to use, do you have any documentation for the 195?
This is from trouble shooting your TBI220 system:
. Does the engine have a fully operational thermostat? Yes – insure that the engine will reach 180 deg. in a reasonable time, go to step 5. No – Install new thermostat, proper size thermostat will be 180 or higher. 160 degree in many cases is OK but the preference is 180 or higher. If still running rich go to step 5
Sorry Kyle, don't mean to Hijack your thread...
AIR #13
Old 04-13-2021, 08:02 PM   #170
cmadmaxman's Avatar
Not sure, but I know that the system reduces fuel, timing etc. when the engine gets to temp, that should be around the 195 deg.
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 04-13-2021, 08:39 PM   #171
Kvsterling's Avatar
West Chester , Ohio
This is great! Iím still on a carburetor, but went from a 195 thermostat to 180 deg. Did the stovetop hot water test and new one opened wide at 185 isch. My dash temp gauge says 190-195 but think it reads a little high. Just got radiator re-installed with new hoses.
[ATTACH]393151
I was able to borrow a SnapOn coolant refill tool. Had the whole system vacuumed and refilled in less than 10 minutes!
No leaks, temp held, going into our trip with some confidence. About that...
Heading to Carlsbad canyon to Big Bend TX starting this weekend. Few parks in between
We did a little dry camping last weekend and all coach systems checked out. Getting out on the road tomorrow for a final on the road test and getting propane fill
Old 04-13-2021, 09:24 PM   #172
cmadmaxman's Avatar
Yes I run the 180 in the 310 with the Q jet. Runs good and temps keep down.
Peter, have been looking and looks like the 180 should work fine, and should not effect the the gas mileage to much, they say minuscule!? The 160 looks definitely to low unless you want to run it on the drag strip!
Kv that radiator looks great. Do you have a part number for that 7 blade fan?
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 04-14-2021, 08:54 AM   #173
Magnet18's Avatar
That's a pretty radiator, wishing you guys luck and don't forget to be flexible!
1983 Airstream 310 Class A Motorhome
-Rob
Old 04-14-2021, 09:36 AM   #174
When I switched the Argosy over to TBI I had the guy doing the tuning change the temperature parameter to account for a 180 degree thermostat. I don't have any real runtime to know if this was a good idea or a bad idea. I guess if/when I make the trip to Arkansas later this year I'll find out
1975 24' Argosy Motor Home
Old 04-15-2021, 06:44 AM   #175
Kvsterling's Avatar
West Chester , Ohio
The 7 blade fan was on when we purchased in 2018, so I have no idea about source or part number. Didnít see any label on it before reassembling.
Still dialing in the Rostra cruise control, it will turn on at lower speed but wonít activate at higher speed. Iím sure it is a DIP switch setting at this point, I tried a couple changes without success.
I have a MDS ignition module providing the tach signal. Not sure if this affects the setting. Also, using a 16 pulse Hall effect VSS at the transmission. How would this translate to wave form and pulse per mile settings for Rostra. I may be calling Rostra customer support
Old 04-15-2021, 07:07 AM   #176
These are the settings I used for my Argosy and old 310. The only difference between the two was the Argosy used square wave because of the TBI and the 310 I believe was a sine wave.
Dip Sw Setting Description Type
1 OFF Gain/Sensitivity Mid
2 ON Gain/Sensitivity
3 ON Pulses/Mile
4 OFF Pulses/Mile 4,000
5 OFF Pulses/Mile
6 OFF Pulses/Mile
7 OFF Engine/Setup Timer 8 cylinder high
8 OFF Engine/Setup Timer
9 ON Engine/Setup Timer
10 ON VSS Source Square
11 ON Transmission Manual/Auto Automatic
12 ON Controll Switch Closed Circuit
Old 04-18-2021, 07:00 AM   #177
Kvsterling's Avatar
West Chester , Ohio
Thanks for the DIP settings, still no joy but we left anyway
Made it from Cincinnati to Effingham Il last night with an early warning from TPMS indicating a leaking left front. I purchased that because of the story Magnet18 posted, good looking out Rob! Found to be a bad seal at valve stem extender. Pulled that, air up, and we go
Yesterday, stopped for lunch and we had no voltage from coach batteries. Little poking around and found this [ATTACH]393408
Looks like the highway vibration torture test backed out the battery terminal screw. After a little prayer of thanks (not the positive terminal) hooked back up and torqued all bolts
Made it to Tulsa without incident, averaging 8.2 mpg at about 63 mph on the stock transmission. Itís a little loud, but temps are holding steady with new radiator
Heading to Amarillo TX today, really enjoying this trip!!!
Old 04-18-2021, 07:34 AM   #178
Kvsterling's Avatar
West Chester , Ohio
And a pretty regular experience with the obligatory ďwhat year is that thing?Ē
[ATTACH]393411
Old 04-18-2021, 08:14 AM   #179
cmadmaxman's Avatar
Yep, just about every time!
And the next line: "Did not know Airstream ever made a Motorhome!"
Safe travels, and looks like your getting great MPG!
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Old 04-18-2021, 09:03 AM   #180
Airstream Driver
1994 30' Excella
Images: 49
Looks like you are taking the western route. Didn't think you would be hitting the road that soon, always have a stop in Austin...
AIR #13
Je Suis CHARLIE! cwf Off Topic Forum 12 01-10-2015 01:32 PM
Charlie Brown. . . maxandgeorgia Off Topic Forum 21 12-18-2006 07:59 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
