Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 03-20-2021, 06:33 PM   #141
Kvsterling's Avatar
West Chester , Ohio
Somehow, the alignment attempt revealed a ďdraggingĒ left front wheel. Wheel bearings are super smooth, but a sticky and leaking caliper. Impromptu brake job today as well (both done for good measure)
Ran out of time for parking brake cable, but if itís the right part I will post part number and review
Kvsterling is offline   Reply With Quote
Old 03-20-2021, 06:34 PM   #142
Kvsterling's Avatar
West Chester , Ohio
Here are some pics of the original air injection tubes...capped off with coolant tubing. Still finding funny PO fixes
Old 03-21-2021, 09:26 AM   #143
Magnet18's Avatar
Churubusco , Indiana
Good to catch that!
After all the brake issues I found, I'm glad to have replaced the whole dang system, because that parking brake won't do a thing to stop it once rolling.
Magnet18 is offline   Reply With Quote
Old 03-22-2021, 06:31 AM   #144
Kvsterling's Avatar
West Chester , Ohio
The brake cable was a good fit. It is a Raybestos product, and looks more robust than the OEM
The Part Number is BC93818 and some comparison pics. Glad I didnít need a custom solution!
Also, discovered some adjustment can be made at the parking brake handle! Turning it changes where the cable link attaches to the lever arm. No wonder I had to pull so hard...Iím guessing this also allows for some on-the-fly adjustment for cable stretch and pad wear
ID:	391339   Click image for larger version
Old 04-02-2021, 10:41 PM   #145
Kvsterling's Avatar
West Chester , Ohio
We are hosting some friends for the weekend, work on Charlie progresses. We have a parks trip to TX in a few weeks, so we have a priority list of things to fix. Unexpected projects included replacing power steering hose (leaks), front brakes, getting the radiator record versus re-rodded, and low fluid sensors (engine). All systems check, then who knows what else
The rear springs were a bust. Not sure how Iím going to address that. Put a spacer in to level it, but nothing repaired or replaced. 2 shops took a look and passed on the work...
Old 04-03-2021, 11:12 AM   #146
Magnet18's Avatar
Where did you put the spacer?
And did they say why they passed?
Maybe I should start a side gig doing airstream rear suspensions...
Old 04-04-2021, 08:32 AM   #147
Kvsterling's Avatar
West Chester , Ohio
Just added a block to the spring stack
One shop said the labor involved with removal of our springs would require cutting into the back of the box for air compressor. More than they wanted to take on, but willing to help if I pulled the springs myself
The other shop said these springs are ďwavyĒ and did not think re arch was a good idea. Also didnít see any springs in his catalog that would fit and didnít have shop time available to commit to the job
When you open your shop, I request customer #1!
Old 04-04-2021, 10:25 AM   #148
Magnet18's Avatar
I have a hard time understanding why shop 1 said that... Sounds like a "we use a big tool to make it easy and it won't fit in there"
The part number for the correct spring is
GM C/K 30 and 3500 Truck Rear Leaf Spring | 10 Leaves | 3,955 lbs. Capacity
SKU: 22-617
Ordered from Michigan truck spring, but I had to change the bushings out and remove the included 9/16" bushings and install the right 5/8" size
Rubber Leaf Spring Bushing | Chevy/GM
SKU: RB-129
If you order yourself, probably worth calling to see if they can sell you the spring or an equivalent that has the right bushings already installed.
Old 04-04-2021, 10:31 AM   #149
Magnet18's Avatar
What ubolts did you install after putting the spacer in?
1983 Airstream 310 Class A Motorhome
-Rob
Old 04-04-2021, 11:31 AM   #150
Kvsterling's Avatar
West Chester , Ohio
After coolant flush and changing out the thermostat to 180 deg, driving a couple hours still saw engine temps creeping up at highway speeds and while running the AC. Decided to bite the bullet and address the primary cooling system [ATTACH]392334
Confirmed a few things, it is a 4-core radiator, no leaks, and cruddy insides. Getting this to a radiator shop tomorrow for a clean out and re rodding.
Will take this opportunity to add an external trans radiator and trans temp sensor. Am I missing anything?
ID:	392334   Click image for larger version
Old 04-04-2021, 11:55 AM   #151
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
I am about to tackle that one myself, since i suspect a bad water pump bearing and possibly seal.
My list includes new water pump (still confused about which of the 2 acdelco listed at Rockauto is the right one) new ACD fan clutch and 7 blade fan.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 04-04-2021, 12:02 PM   #152
You want the long nose water pump. There are two styles available for the big block. Long nose and short nose, sometimes referred to as truck and car water pumps.
I didn't write down the part number from mine so I can't help you with that.
1975 24' Argosy Motor Home
Old 04-04-2021, 12:12 PM   #153
Airstream Driver
1994 30' Excella
Images: 49
Rockauto list 2 for P30
ACD 252608 @39.79 https://www.rockauto.com/en/moreinfo...059544&jsn=452
and
ACD 251612 @115.79 https://www.rockauto.com/en/moreinfo...722&cc=1059544
I can't make out a nose length difference
AIR #13
Old 04-04-2021, 12:20 PM   #154
and
I find it interesting that one is listed for serpentine belt and the other for timing belt. Neither makes sense to me.
I used this Cardone water pump on Peanut.
Old 04-04-2021, 02:07 PM   #155
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Problem we have Brad, we have serpentine and v belts!
Intrested in how to get the radiator out!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (274,000 and still going )
cmadmaxman is online now   Reply With Quote
Old 04-04-2021, 02:56 PM   #156
Magnet18's Avatar
An oil cooler is easy enough since you're in there, and can't hurt in getting heat out of the engine, we have one. Only other upgrade i can think of is an electric fan to help move the air, which is something I'll likely do myself before long.
Old 04-04-2021, 06:53 PM   #157
Kvsterling's Avatar
West Chester , Ohio
Iím now referring to AS motorhome as more of a practice than a project. The power steering lines were in fact leaking, so thatís done.
Found another break in the AC compressor bracket! Previous owner did a repair, looks like I need a replacement bracket but ours doesnít look like ones coming up in my searches[ATTACH]392382
The interior is really coming together, here is the latest development...
[ATTACH]392383
Iím starting to think we can travel/camp in these things
ID:	392382   Click image for larger version
Old 04-04-2021, 08:17 PM   #158
Airstream Driver
1994 30' Excella
Images: 49
[ATTACH]392383
Looks great, where did you score the dinette set? Or did you built it yourself?
AIR #13
Old 04-04-2021, 09:03 PM   #159
Kvsterling's Avatar
West Chester , Ohio
I discovered our forum has a marketplace late last year. The same day I found the dinette set for sale in the neighboring city from a 2004 trailer. Its just a couple inches larger, lighter, and much more sturdy. Frame is formed plastic like our tanks! Some modification to fit around the tv cabinet and seatbelt anchor frame, but otherwise plug and play
Old 04-04-2021, 10:23 PM   #160
Magnet18's Avatar
[ATTACH]392383
Looks beautiful!
Je Suis CHARLIE! cwf Off Topic Forum 12 01-10-2015 01:32 PM
Charlie Brown. . . maxandgeorgia Off Topic Forum 21 12-18-2006 07:59 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
