Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-28-2021, 08:26 PM   #1
1987 32.5' Airstream 325
Windsor , Ontario
Brown outlet rewire
In my 87’ 325 MH I have removed the scallop arm chairs in favour of a dinette. Removing the fabric covered wall covers and an outlet that was home in one of the panels.
I would like to run the wire through conduit and attach the box to the lower wall.
They outlet box seems to be “sealed” with side clips that I am not familiar with.
Is there a forum post or how-to post on how to take these apart and reassemble, I would hate to break it and not have a proper replacement or have to “rig” it back together.
Thanks in advance for any suggestions as always.
Chris
realpank is offline   Reply With Quote
Old 11-29-2021, 02:44 AM   #2
2017 25' International
West Lake Hills , Texas
My limited experience on a 2017 yesterday…
Side clips came off easily using a small flat screwdriver.
Wire removal inside also easy.
Pushing the wire back on - not so easy.
These are sometimes called “speed boxes”. There is a special tool that installers use to quickly push the wires onto the grippers without the need to strip the wires. Also no need to cut the wires when daisy-chaining to the next outlet. I believe they are illegal in residential construction in many states. There is little contact area between the wire and the outlet.
The outlet box at the television had just one available outlet. The other one was blocked. I ordered a new speed box with two open outlets but couldn’t get the wires pushed in. Finally gave up. I installed an “old work” outlet box with a normal residential outlet except the outlet also has two USB ports. The most difficult part of the job was enlarging the raggedly cut hole to accept the box. The hole was obviously cut by a chimpanzee using a sawzall or, perhaps, a chisel. I wondered why the hole wasn’t cut on the CNC machine when the panel was cut. But maybe Airstream hasn’t heard of CNC machines. The multitool did the trick. I was very careful because messing up on that paneling wasn’t going to be fixable like messing up on drywall (Sheetrock) at home.
Using an old work box requires having space behind the wall to accommodate the depth of the box. On my application, it was a big empty (wasted) space behind the fridge.
Fungus is offline   Reply With Quote
Old 11-29-2021, 06:07 AM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Does your outlet look like this:
https://highskyrvparts.com/rv-parts/...ceptacle-ivory
These are self-contained receptacles. In my experience it's easier to just toss the old one and install a new one. Too much bother trying to get them apart and to get the wires pulled without doing damage to it.
Richard
11018
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is offline   Reply With Quote
Old 11-29-2021, 09:44 AM   #4
Windsor , Ontario
Brown outlet rewire
Thanks for the responses, this is just what i was hoping to get.
Since I am installing a dinette I can flush mount an exterior box and screw it to the wall as it will be hidden. I think I might as well use the old plug so I’m not messing with the polarity or any grounding that the original receptacle provided.
As always this forum comes through with good answers as well as a good story. Inspired me to just keep the job simple.
Thanks again,
Chris
230v to 120v stepdown transformer or rewire? finn2020 Batteries, Univolts, Converters & Inverters 9 04-05-2007 08:09 AM
1967 Overlander 110v rewire TNBUBBA Electrical - Systems, Generators, Batteries & Solar 1 10-09-2006 11:17 AM
54 safari rewire durans54 Electrical - Systems, Generators, Batteries & Solar 2 01-18-2005 04:52 PM
Should I just rewire it? 63air Electrical - Systems, Generators, Batteries & Solar 5 08-29-2004 10:55 AM
Rewire with Copper McMullen 1965 - 1969 Overlander 4 11-18-2003 04:08 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
