Old 10-02-2022, 03:41 PM   #1
1988 34.5' Airstream 345
Clarkston , MI
Bearings and U-Joints… oh my
A couple of U joints are bad so I bought 4 new ones and 2 new bearings. How to I get the bearing off this shaft? Rubber mallet had no effect.
ID:	423377   Click image for larger version
Beltran is offline   Reply With Quote
Old 10-02-2022, 04:16 PM   #2
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Take to a shop and have them pressed off in a hydraulic press.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 10-02-2022, 04:58 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
That looks like a center support bearing. I would guess rust is holding it on. A press is the best bet. A big enough puller would probably work, too.
I changed a bearing like that on one of my trucks about 2 weeks ago. It slid right off. It wasn't rusted though.
I don't recommend it, but I would probably have already attacked that bearing with some penetrating oil and a 3 pound hammer.
CRH is offline   Reply With Quote
Old 10-02-2022, 09:10 PM   #4
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Have a driveshaft shop do it and get the shafts balanced as an assembly at the same time. Good chance that they are not willing to work with the bearing you purchased and insist to use their own.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 10-02-2022, 10:05 PM   #5
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Get the shafts balanced while you're at it. You'll be amazed at the nice ride that will give you, and you didn't even know the old shaft needed balanced.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 10-03-2022, 09:28 PM   #6
Clarkston , MI
I had to borrow a puller from the neighbor. Mine wasn't deep enough. Came right off with that.
The shafts are balanced, I can see various weights on them. I made sure to keep the orientation. It's almost hard to get it wrong. It only goes back together one way, and you can be only 180 degrees out. Assuming you haven't moved the MH after you took it all apart.
Old 10-03-2022, 09:36 PM   #7
2019 25' Flying Cloud
Hendersonville , North Carolina
Do it yourself driveshaft rebuild
Just like tires driveshafts need to be rebalanced after you disassemble/reassemble. Take the advice of the others and have a pro shop examine your work and check the driveline for straightness and balance. Money well spent.
Old school drag racer who has had his share of broken/bent/sheared/shattered driveshafts.
uraljohn is offline   Reply With Quote
Old 10-03-2022, 10:56 PM   #8
Clarkston , MI
ok, I will look into it. I suppose I will have to take them out again. But it would be after this next trip.
Old 10-04-2022, 12:08 AM   #9
NevadaGeo's Avatar
Genoa , Nevada
I also have my vehicle tires rebalanced when the tires are rotated, even when the weights are still on there. I Never seem to get a tracing around the weights before the tires get re mounted.
NevadaGeo
Bridging Staples on plywood floor joints - leave or remove? whitelight Floor Finishes 5 04-14-2009 04:06 PM
How to seal window joints & seams prior to painting? nick6930 All Argosy Trailers 10 03-17-2009 05:18 PM
front suspension/ ball joints wb13798 Mechanics Corner - Engines, Transmission & More... 13 11-07-2003 08:57 AM
U joints and drive shaft thenewkid64 Mechanics Corner - Engines, Transmission & More... 2 07-13-2002 05:07 PM
End Joints in New Floor melprice Floor Finishes 3 07-12-2002 12:16 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
