Old 09-20-2021, 07:19 PM   #1
1988 34.5' Airstream 345
Clarkston , MI
Battery Isolators
There was a short discussion in Magnet's thread about the battery Isolator. I don't have one in my vehicle, anymore. It was removed by one of the previous owners and replaced with a marine battery switch. It works well enough but I am not sure it prevents you from draining your engine battery while boondocking.
Just wondering who has these units still in their Classics and is it a Diode or MOSFET version?
PS.. how do you rotate pictures on the forums. Its not like this in my photo library.. here its turned 90 degrees left.
Beltran is offline   Reply With Quote
Old 09-20-2021, 08:19 PM   #2
Kvsterling's Avatar
West Chester , Ohio
Had a diode isolator, it drew heavy load on the alternator which caused belt failure.
Tried mosfet isolator which helped correct alternator voltage regulator, but did not limit load on the alternator
Finally to DC/DC charger and very happy with its performance and configure-ability
Kvsterling is offline   Reply With Quote
Batteries, inverters, isolators, oh my... pago cruiser Land Yacht/Legacy Motorhomes 2 11-15-2017 11:36 AM
Isolators versus continuous duty solenoids PeterH-350LE Mechanics Corner - Engines, Transmission & More... 23 09-02-2017 05:08 PM
To battery or not to battery 29348 Batteries, Univolts, Converters & Inverters 4 07-16-2006 02:02 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
