Old 04-04-2020, 11:52 AM   #1
1988 32' Excella
1987 34.5' Airstream 345
Livingston , Texas
Anyone know where I cant get a new motor for 345 electric steps?
My electric steps by the front door have never worked and I want to dig in and replace the motor.
Anyone know where I could snag a used one? And if so, what brand/model am I looking for?
345 MoHo is offline   Reply With Quote
Old 04-04-2020, 01:51 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I had the same problem. The factory said the steps were too old and would have to be replaced. There are lots of Lippert Kwikee parts on eBay. This is what I did to repair mine. https://www.airforums.com/forums/f31...-183003-3.html
Cheers, Dan
~ Margaret Thatcher ~
Old 04-06-2020, 12:12 AM   #3
northern IL , Illinois
It's a power window motor from a 85 Buick or something llke that.
Hans 34.5 is offline   Reply With Quote
Old 04-06-2020, 10:08 AM   #4
Central , Mississippi
Does it look like this? Itís a 1980ís to Ď90ís GM window lift motor. They had left and right hand plus various output gear versions. Click image for larger version
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 04-09-2020, 10:30 AM   #5
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
You can buy a Dorman Window motor which will work as a replacement. The reference numbers are on the forum. However, I think those motors had small plastic cogs which shred easily and I've never been convinced about longeivity. You could try though. You can just buy the replacement cogs. I think the original motors might have had metal cogs but someone more knowledgable than me can advise on that #BradKahler #MartinWarman #BobMiller #PeterHausmann
Kwikee have some excellent fault testing on their website or available on the web. It's worth noting that the problem can also reside in the control module and, if that is the case, you might be looking at replacing the module (now Lippert) plus the motor, door switch etc. I think the polarity and set up is different to the stock stuff.
Boom Sounds is offline   Reply With Quote
Old 04-09-2020, 10:38 PM   #6
Search Kwikee steps - that plastic gear issue 1991 25
I have a picture of the one I pulled out of my step
Old 08-25-2020, 02:34 PM   #7
1989 34.5' Airstream 345
Oakville , Ontario
Hi, I'm wondering if anyone can specify the exact motor for the kwikee electric 2 step in my 345 LE?
parnek is offline   Reply With Quote
Old 08-25-2020, 02:41 PM   #8
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Can you see any numbers on the motor? Picture might be best. Lot's of leads posted above.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-25-2020, 02:43 PM   #9
"Silver Shrek"
drairstream's Avatar
2000 27' Safari
Crestwood , Kentucky
Amazon. No sweat.
drairstream is online now   Reply With Quote
Old 09-15-2020, 10:44 AM   #10
Ebro , Fla Panhandle
Has anyone found the drive motor for the steps for the 345 LE, the one with metal drive motors.
Could you please post the numbers that you have found for this part.
Cheers Richard
tevake is offline   Reply With Quote
Old 09-16-2020, 09:02 AM   #11
Hi Richard - I think the metal cog version is the one available via Kwikee. I can't be certain, but I think it is made by AM equipment. I would call them and check and ask the question about the metal cogs/parts and also whether it is cheaper via AM Equipment direct or via another supplier.
The Dorman window motor i posted has the plastic cogs which disintegrate over time. Saying that, if the Motor is the problem, the Dorman replacement is a cheap easy fix (less than 60 mins) and you could put in another if it fails in a few years.
........note to self and everyone - be careful under those steps...disconnect power
Old 09-16-2020, 09:03 AM   #12
Something like this...you need to line up your step type to the correct replacement part
https://www.amazon.co.uk/Kwikee-1101.../dp/B005G21JP2
Old 09-16-2020, 06:42 PM   #13
Thanks Boom sounds, I found them listed on craigslist here in the US.
I've got some clean up to do here over the next couple of days from the hurricane that blew thru yesterday and this morning.
So once I can get to the stairs I'll dive into them it detrimined what it's is that wrong with them, I'll see what is wrong with them.
Thanks for the details!
Cheers Richard
Old 09-17-2020, 03:53 AM   #14
You can probably check the motor by taking it out and running 12v through it/taking it apart. It could easily be another issue e.g. the control module or steps binding in which case they won't retract. Check out the Kwikee test procedures. They are pretty good from memory. If you have to replace the control module, you may need to change other stuff e.g. door jamb due to polarity.....some time ago, PPL used to do deals on Kwikee steps
Old 09-17-2020, 04:38 PM   #15
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
If you want to just replace the whole step ass, here is where I'm getting mine: https://www.pplmotorhomes.com/parts/...ch-kit_3722616
I can tell in a couple days whether it's the right one cause my new one is coming tomorrow.
choctawmel is offline   Reply With Quote
Old 09-17-2020, 05:37 PM   #16
The series 32 steps will fit. I installed the same one on my 84 310. Only problem is the new steps are not as deep so you have to fill about a 1-1/2" or so gap between the step and the door frame. You'll see what I'm saying once you try to fit the new ones.
Kwikee step installation on 84 310
Old 09-21-2020, 06:13 PM   #17
Bikerman's Avatar
St Petersburg , Florida
I replaced mine with a new kit, I purchased it through the Airstream parts department In Grand Rapids, Michigan.
Bikerman is offline   Reply With Quote
Electric motor for steps ????? CMDR BOB Steps 12 12-15-2014 08:50 AM
Cant get all Removall 220 off my AS :( Archie5038 Cleaning, Stripping & Polishing 7 12-26-2012 01:01 PM
I cant get the awning to open....... vwrhoden Awnings 7 02-23-2011 03:02 PM
Cant get hinge pin out kevinkatz Doors & Locks 4 07-17-2009 06:16 AM
Cant get frige out of 65 Tradewind. lrichards Refrigerators 2 07-19-2005 06:13 AM
