08-04-2018, 10:35 PM
#21
1987 32.5' Airstream 325
dripping springs
The floor needed a little more than I thought....
08-07-2018, 08:17 AM
#22
Churubusco
, Indiana
On the subject of towing a tag, what happens if you just remove the wheels from the tag axle?
Should gain you plenty of clearance, no weight on the tag for sure
I wouldn't hesitate to do that on a 325, not sure if the load limit on the main rear axle is an issue for a 345 or 370 though
1983 Airstream 310 Class A Motorhome
-Rob
08-07-2018, 01:16 PM
#23
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
LOL...,let me know how that works out for you.....are you kidding ????
08-07-2018, 02:49 PM
#24
Churubusco
, Indiana
Only Half kidding, I wouldn't dream of trying that on a 370
The 310 and 325 are pretty close in most ways, and the 310 does just fine with no tag at all.
From what I understand this makes the 325 tag borderline optional, and if my options were ruin the tag axle by overloading it, or take the wheels off and keep it up off the road, I'd consider trying it if you were just gonna limp down the road at 30mph
My old man used to design air ride suspensions for heavy duty trucks, most of the tag axles were added more to meet codes for wheel #s or wheelbase length than for any legitimate engineering reason.
This is 100% speculation, as I've only looked at a tag axle in person once, and I'm curious why others think it would fail.
Sorry to hijack the thread, the rest of the discussion has moved on from this.
08-08-2018, 01:36 AM
#25
1987 34.5' Airstream 345
Auckland
, New Zealand
Tag Tow Hitch
Sorting a game plan....
#1 Well good thinking regarding removing tag wheels!
#2 Being towed using a Hitch, I'd plan on once front is in the air, remove front wheels also so tow driver can reduce front hight, less likely to scrape its ars!
Remove prop shaft spicer from rear Dif, maybe wire up on to undercarrage. Then put a note on windscreen not to put in gear
#3 keep compressor on full time during tow, disconect levelling valves rods from tag and raise them to the max lift position.
#4 Dump all rear tank water n weight! Wheels can go forward on floor.
Yes you are also right as far as I can tell regarding the distance from bumper to mid way between Drive wheels and Tag wheels = 3.5 m? max overhang distance for Transport Regulations Code..
But the other hairy bit is all that overhang past the Drive Axle to rear bumper from 325 and up were designed for support from that Tag. So dont bend it!
Anyway plan is feeling better .
08-08-2018, 06:22 AM
#26
Churubusco
, Indiana
Keep in mind my comments about the tag were just speculation!! Be careful!!
Don't forget the electric step (if yours works)
I had to crawl under and unplug the step while it was retracted, otherwise I couldn't figure out how to get the step up, while I was outside the airstream, without leaving the ignition on
-Rob
08-13-2018, 06:03 AM
#27
dripping springs
08-13-2018, 09:04 PM
#28
dripping springs
Today, a layer of fiberglass resin to level it a bit, then a layer of 3/8 to build up to the height of the kitchen floor (glued down oak)...
08-16-2018, 08:55 PM
#29
dripping springs
08-16-2018, 09:54 PM
#30
Churubusco
, Indiana
Awesome progress!
Why were these toilets raised up start with?
I assumed it was to gain more black tank space underneath, but that doesn't seem to be the case with yours
Are those your heater ducts down there?
-Rob
08-17-2018, 05:17 AM
#31
dripping springs
There are two ducts under the toilet, but the PO abandoned the heater behind it, and it so I’ll remove them. Did this in the 325 and put in a low profile toilet, which is infinitely better.
08-17-2018, 10:07 AM
#32
dripping springs
08-17-2018, 12:22 PM
#33
Churubusco
, Indiana
Good to know, thanks
I feel like I need a ladder to use the factory toilet
-Rob
08-17-2018, 04:10 PM
#34
north blenheim
, New York
Are you vertically challenged ???
08-17-2018, 06:38 PM
#35
dripping springs
Nope, just prefer my toilets to be consistent height. Keeps my butt more comfortable when it matters. Either the guy who designed these was some sort of freak of nature with a 38” inseam and under 6’ tall (ceiling height of these is not for the tall guys), or really bad at kinesiology....
08-17-2018, 06:39 PM
#36
dripping springs
08-17-2018, 06:43 PM
#37
dripping springs
So, you’re saying ‘bill, the flange should be on top of the finished floor!’ Which is absolutely true for residential, but I want a low rider toilet and am using laminate so I’ll cut it in to the base to maximize my lowering ...yes I like my stuff low...
08-17-2018, 06:44 PM
#38
dripping springs
08-17-2018, 06:48 PM
#39
dripping springs
Final note on this task. In case the lack of skill was not apparent from the 30” seat height, the carpet and mdf in a ‘wet’ location should seal the deal there...
08-24-2018, 03:20 PM
#40
dripping springs
Finished floor just about complete this week, remaking the bed today. New toilet arrived so will finish these tasks over the weekend.
