Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 08-04-2018, 11:35 PM   #21
gaiaenviro's Avatar
1987 32.5' Airstream 325
dripping springs , Texas
The floor needed a little more than I thought....Click image for larger version
gaiaenviro is offline   Reply With Quote
Old 08-07-2018, 09:17 AM   #22
Magnet18's Avatar
Churubusco , Indiana
On the subject of towing a tag, what happens if you just remove the wheels from the tag axle?
Should gain you plenty of clearance, no weight on the tag for sure
I wouldn't hesitate to do that on a 325, not sure if the load limit on the main rear axle is an issue for a 345 or 370 though
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 08-07-2018, 02:16 PM   #23
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
LOL...,let me know how that works out for you.....are you kidding ????
bobmiller1 is offline   Reply With Quote
Old 08-07-2018, 03:49 PM   #24
Magnet18's Avatar
Only Half kidding, I wouldn't dream of trying that on a 370
The 310 and 325 are pretty close in most ways, and the 310 does just fine with no tag at all.
From what I understand this makes the 325 tag borderline optional, and if my options were ruin the tag axle by overloading it, or take the wheels off and keep it up off the road, I'd consider trying it if you were just gonna limp down the road at 30mph
My old man used to design air ride suspensions for heavy duty trucks, most of the tag axles were added more to meet codes for wheel #s or wheelbase length than for any legitimate engineering reason.
This is 100% speculation, as I've only looked at a tag axle in person once, and I'm curious why others think it would fail.
Sorry to hijack the thread, the rest of the discussion has moved on from this.
Old 08-08-2018, 02:36 AM   #25
1987 34.5' Airstream 345
Auckland , New Zealand
Tag Tow Hitch
Sorting a game plan....
#1 Well good thinking regarding removing tag wheels!
#2 Being towed using a Hitch, I'd plan on once front is in the air, remove front wheels also so tow driver can reduce front hight, less likely to scrape its ars!
Remove prop shaft spicer from rear Dif, maybe wire up on to undercarrage. Then put a note on windscreen not to put in gear
#3 keep compressor on full time during tow, disconect levelling valves rods from tag and raise them to the max lift position.
#4 Dump all rear tank water n weight! Wheels can go forward on floor.
Yes you are also right as far as I can tell regarding the distance from bumper to mid way between Drive wheels and Tag wheels = 3.5 m? max overhang distance for Transport Regulations Code..
But the other hairy bit is all that overhang past the Drive Axle to rear bumper from 325 and up were designed for support from that Tag. So dont bend it!
Anyway plan is feeling better .
Voltair is offline   Reply With Quote
Old 08-08-2018, 07:22 AM   #26
Magnet18's Avatar
Keep in mind my comments about the tag were just speculation!! Be careful!!
Don't forget the electric step (if yours works)
I had to crawl under and unplug the step while it was retracted, otherwise I couldn't figure out how to get the step up, while I was outside the airstream, without leaving the ignition on
-Rob
Old 08-13-2018, 07:03 AM   #27
gaiaenviro's Avatar
From 24ga galvanized to 18ga painted, glued down, then glued techsheild, with screws to frame. Now a layer of 3/8 to level with the kitchen floor and then waterproof laminate...Click image for larger version
ID:	319753Click image for larger version
ID:	319754Click image for larger version
ID:	319755Click image for larger version
ID:	319756Click image for larger version
ID:	319757Click image for larger version
Old 08-13-2018, 10:04 PM   #28
gaiaenviro's Avatar
Today, a layer of fiberglass resin to level it a bit, then a layer of 3/8 to build up to the height of the kitchen floor (glued down oak)...Click image for larger version
ID:	319836Click image for larger version
Old 08-16-2018, 09:55 PM   #29
gaiaenviro's Avatar
As long as I’m tearing stuff down, might as well lower the toilet now before the finish floor goes in.Click image for larger version
ID:	320081Click image for larger version
ID:	320083Click image for larger version
Old 08-16-2018, 10:54 PM   #30
Magnet18's Avatar
Awesome progress!
Why were these toilets raised up start with?
I assumed it was to gain more black tank space underneath, but that doesn't seem to be the case with yours
Are those your heater ducts down there?
-Rob
Old 08-17-2018, 06:17 AM   #31
gaiaenviro's Avatar
There are two ducts under the toilet, but the PO abandoned the heater behind it, and it so I’ll remove them. Did this in the 325 and put in a low profile toilet, which is infinitely better.
Old 08-17-2018, 11:07 AM   #32
gaiaenviro's Avatar
So here’s the lowering fix if anyone cares. I used a 45 closet flange with a steel reinforced rubber coupling (as the factory did). Cut out the top ABS 45 and stub (trimmed to fit), and wound up with a flange height of 7.5” versus 10.5” which with a low profile toilet results in a 16” seat height which is comparable to a house.Click image for larger version
ID:	320106Click image for larger version
ID:	320107Click image for larger version
ID:	320108Click image for larger version
ID:	320109Click image for larger version
Old 08-17-2018, 01:22 PM   #33
Magnet18's Avatar
Good to know, thanks
I feel like I need a ladder to use the factory toilet
-Rob
Old 08-17-2018, 05:10 PM   #34
bobmiller1's Avatar
Are you vertically challenged ???
Old 08-17-2018, 07:38 PM   #35
gaiaenviro's Avatar
Nope, just prefer my toilets to be consistent height. Keeps my butt more comfortable when it matters. Either the guy who designed these was some sort of freak of nature with a 38” inseam and under 6’ tall (ceiling height of these is not for the tall guys), or really bad at kinesiology....
Old 08-17-2018, 07:39 PM   #36
gaiaenviro's Avatar
So, if not for this pesky ‘job’ I’d be further along... but here’s the important stuff minus a few screws. Click image for larger version
ID:	320143Click image for larger version
ID:	320145Click image for larger version
ID:	320147Click image for larger version
Old 08-17-2018, 07:43 PM   #37
gaiaenviro's Avatar
So, you’re saying ‘bill, the flange should be on top of the finished floor!’ Which is absolutely true for residential, but I want a low rider toilet and am using laminate so I’ll cut it in to the base to maximize my lowering ...yes I like my stuff low...
Old 08-17-2018, 07:44 PM   #38
gaiaenviro's Avatar
Old 08-17-2018, 07:48 PM   #39
gaiaenviro's Avatar
Final note on this task. In case the lack of skill was not apparent from the 30” seat height, the carpet and mdf in a ‘wet’ location should seal the deal there...
Old 08-24-2018, 04:20 PM   #40
gaiaenviro's Avatar
Finished floor just about complete this week, remaking the bed today. New toilet arrived so will finish these tasks over the weekend. Click image for larger version
ID:	320733Click image for larger version
Fan stopped, now Dometic fridge stopped-what now? BWright2016 General Repair Forum 10 08-27-2017 01:14 PM
Interior re-do of 1989 345LE charles white Airstream Motorhome Forums 9 03-21-2003 05:14 PM
water in fuel(345le) will Mechanics Corner - Engines, Transmission & More... 9 10-16-2002 01:38 PM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 06:49 AM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 11:13 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
