Old 03-04-2020, 09:54 AM   #1
Roddyy's Avatar
1982 28' Airstream 280
Grantsburg , Wisconsin
advice on air pumps, cruise control, and air conditioners
I'm doing a major upgrade to my 28 ft Excella. One goal is to replace the air pump. The original pump was used to keep the rear air shocks balanced. It seems to me I have the opportunity to improve this system now. I'd like to install air lines and gauges so that I could remotely adjust shock air pressure in the cab. Has anyone done this? And if so can you recommend equipment?
Also I need to replace the cruise control. Are there any recommendations for after market kits that work?
And of course I need to replace the air conditioners. That scares me a little bit. How to set up a working platform on top of the coach, how to remove it without breaking things, and what kind of air conditioners are best for this marvelous little beast? I would certainly welcome any comments.
Roddyy is offline   Reply With Quote
Old 03-04-2020, 10:51 AM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Several folks, including myself, have replaced their compressors with V-air units. Reasonably priced and readily available. Typically they are set up with a pressure switch and relay which regulates the pressure in your air bags between 80-110 psi.
Rostra is probably the most well known brand in aftermarket cruise controls .
mayco is offline   Reply With Quote
Old 03-04-2020, 04:01 PM   #3
As Mike stated, Rostra is most commonly used. I've installed it in to Airstreams plus one of my Triumph sports cars. They seem to be very solid units.
Atwood Air Command Air Conditioners Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 35 10-08-2020 08:14 AM
1 Micro Air 2 Air Conditioners | Dilemma MarkJUrban Electrical - Systems, Generators, Batteries & Solar 17 10-30-2018 02:43 PM
Cruise or not cruise? badkat On The Road... 39 07-23-2016 06:37 AM
Air conditioners and generators Lumatic Generators & Solar Power 12 07-27-2012 01:22 PM
Gas pedal and cruise control question wierdwiam General Motorhome Topics 1 09-20-2009 02:02 PM
