Old 05-12-2020, 02:31 PM   #1
1986 34.5' Airstream 345
La Quinta , California
Accelerator Pedal
I just finished putting a holley sniper efi system on my 34.5. Wow. More power and better milage. Went to 8.5 mpg from 7. I pulled a hill at 65 that normally takes 2nd gear. I am amazed. The reason for my post is my accelerator pedal is broken. Does anyone know where i might find one??? If anyone wants particlars on install of sniper let me know. Did i mention instant starts.
bbabich is offline   Reply With Quote
Old 05-12-2020, 05:43 PM   #2
"Alumi-holic"
cesalie2's Avatar
1982 31' Airstream 310
Dearman Avenue , Tennessee
Very interested in your Holley EFI Install, please share details.
cesalie2 is offline   Reply With Quote
Old 05-12-2020, 07:35 PM   #3
A few quirks. You have to add an O2 sensor. It requires removal of a small pcs of exhaust heat shield and drill a hole in exhaust pipe to and bung for O2 sensor. Most of the 454s have a quadrajet carb so need a conversion plate for the newer square pattern. Have to modify the accel linkage a bit to get a straight pull but not bad. The coolant sensor is a bit of a problem also because of shroud but we got around it. There is a display that needs to run into cockpit but easy to do. The display gives you rpm, temp, air to fuel ratio and voltage. The price was $1350. A new quadrajet was about $450. I went for it and a believer. Power, Milage, display and instant start.
Old 05-13-2020, 05:44 AM   #4
"Alumi-holic"
cesalie2's Avatar
Photo’s of install?
Old 05-13-2020, 08:56 AM   #5
Ill take some as soon as i can and post.
Old 05-17-2020, 03:21 PM   #6
Here are a couple of photos of sniper installed. I have about 250 miles on it. Huge difference in power. My favorite is the instant start.Click image for larger version
ID:	368115Click image for larger version
ID:	368116Click image for larger version
Old 05-19-2020, 05:54 PM   #7
Hi. Sorry could not figure out private post so did quick reply for cesalie2. Yes i used stock manifold for install of sniper. Have to use adaptor plate as i think old carb is quadra jet and new sniper is sq pattern. It acts as riser but only modestly so no problem with aircleaner and vaccuum tubes. Yes i have stock exhaust. Had to cut a small hole in exhaust heat shiel to get o2 sensor. You can mount o2 on either exhaust run.
Emergency! On a trip, Broken down in parking lot & need accelerator/throttle cable Tap General Motorhome Topics 23 09-14-2017 03:09 PM
FYI Classic motorhome Isuzu accelerator cable or throttle cables. Isuzusweet Classic Motorhomes 1 08-05-2015 04:49 PM
accelerator cable for 1982 Isuzu diesel mcplaidpiper Classic Motorhomes 7 06-08-2009 09:05 AM
HELP - Poor Pedal Pressure swebster Mechanics Corner - Engines, Transmission & More... 10 10-28-2003 06:13 PM
accelerator cable islandvu3@cox.net Airstream Motorhome Forums 1 05-26-2002 11:02 PM
