Old 07-01-2018, 08:54 PM   #1
gaiaenviro's Avatar
1987 32.5' Airstream 325
dripping springs , Texas
AC units
I need to replace one of the roof ACís on the 345, and between them have 2 carriers and one Coleman which sums up my personal experience with their output. Does anyone have a favorite brand/model? And if so why? Iím thinking a 15k btu is the correct size, but thatís about it....thanks!
gaiaenviro is offline   Reply With Quote
Old 07-02-2018, 07:12 AM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
OK, Iím going to be the first to wack the bees nest with a stick....I installed 2 - 15,000 BTU Dometic Penguin low profile units on the 370LE. Keep in mind that I upgraded to 50 amp service which is really 100 amp service 2 Yearís ago. Never the less they both have the heat pumps as well as the optional drain kits so I can use the interior wall factory drains that Airstream installed in between the walls. The performance is flawless whether on generator or shore power. In addition to painting the roof white, where you canít see it from the ground, inside temperatures are easily maintained. Should you decide to go this way and have any other questions feel free to contact me, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 07-02-2018, 10:27 AM   #3
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
I went with a 13.5K Atwood because it is theoretically more energy efficient with separate blowers for the condenser and internal airflow. It also has a slightly lower roof profile.
I had some initial problems (as shown in my install web page), but it has doing fine for me since 2013 once I got the bugs out.
http://theouterlimits.ws/projects/ai..._ac/index.html
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
Old 07-02-2018, 06:16 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
+2 for the Atwood
http://www.my12voltstore.com/Atwood_...5021-15026.htm
They seem like a very high quality unit with two separate fans that can run at independent speeds.
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 07-07-2018, 08:46 PM   #5
gaiaenviro's Avatar
Thanks!
Old 07-07-2018, 08:47 PM   #6
gaiaenviro's Avatar
Thanks!
Old 07-07-2018, 08:48 PM   #7
gaiaenviro's Avatar
Originally Posted by Isuzusweet View Post
+2 for the Atwood
Cheers
Sidekick Tony
Thanks!
Old 07-07-2018, 08:54 PM   #8
gaiaenviro's Avatar
Thanks for the input guys! I ordered a new one and will post follow up. After these posts it jogged my memory that I put an Atwood on a Ď73 Airstream International that was converted to a cigar bar about a year ago, and itís been working fine, and also a dometic on a buddyís 5th wheel, but it was ducted, but also working fine.
Old 07-09-2018, 09:32 PM   #9
gaiaenviro's Avatar
bobmiller1:
What did you use for roof paint? Thanks in advance!
Old 07-09-2018, 10:15 PM   #10
Magnet18's Avatar
Churubusco , Indiana
I have two new coleman mach 9330e715 (a 13.5k btu unit), installed by the previous owner
I just finished my 50A upgrade, so today was the first day of running them both, but upper 80s and sunny and it got so cold we had to turn them both to low
We will see how they handle 100 degree days, but so far I'm super happy
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 07-10-2018, 05:09 AM   #11
bobmiller1's Avatar
While I had the entire roof stripped and bare, I sanded all of the remaining clear coat off, applied three Coates of etching primer followed by 4 Coates of gloss white, Regards, Bob
Old 07-12-2018, 04:30 PM   #12
gaiaenviro's Avatar
Thanks!
Thanks Bob!
I figured you used some super duper ceramic coating or something, since your works seem to be a step above factory. I have some ceramic coating stuff that I've used in hot rods where it can't be seen, but not sure about the exterior in the TX sun. I'll peruse the interwebs and see what the world has to recommend....
Are all A/C units Rooftop units? jrsygrl Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-19-2013 08:23 PM
WBCCI and local Units Stougard WBCCI Forum 54 02-28-2006 08:46 AM
Vintage Units VS New Units Cstar On The Road... 4 05-07-2004 09:22 PM
Midwest VAC units Jabba WBCCI Rallies & Events 3 01-16-2003 05:49 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
