Old 08-30-2018, 11:54 AM   #1
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte , North Carolina
89 345 LE Parting Strip/Ornamental side piece
Spent several hours washing the wheels & outside & encountering lots of crud that seems to continue moving from behind this piece to the surface below it. There is some sort of partially deteriorated sealer visible which has allowed years of dirt & trash to accumulate & migrate to where the sealer is still intact.
After an hour of trying to find the name for the part (red arrow) in the attached photo, could someone tell me:
1. what it's called?
2. how is the gunk cleaned out?
3. should I remove it completely, clean, polish the MH, re-install the piece?
3. what do I use to seal the upper gap?
The gray paint (yellow arrow) is flaking with normal low pressure water applied. I think there was poor prep prior to painting. I plan on removing the remainder & polishing the area from the black strip up to the roof (where it hasn't been painted). How do I determine if I'm dealing with clearcoat in that area?
Name:	0828 Left Frt.jpg
wimpy is offline   Reply With Quote
Old 08-30-2018, 01:14 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
The upper “Rub” rail has a plastic/vinyl insert that you can remove/replace/re-use. Once it’s removed you should be able to wash the track out completely. As far as the lower goes, I personally would repaint. I considered a wrap, but to hard to do the generator, water heater, and furnace outlets, paint would be a better choice, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 08-30-2018, 02:03 PM   #3
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
I think that lower section fails in high temps. Mine is all flaking off. Like Bob says, I reckon repaint
Boom Sounds is offline   Reply With Quote
Side window with gap after weather strip. Sdmezurek General Repair Forum 0 08-09-2018 08:13 PM
Can we replace floor piece by piece? tdturn2 Repairing/Replacing Floor &/or Frame 5 06-22-2009 07:54 PM
To strip or not to strip. That is the question. mjmcwhorte Cabinets, Counter Tops & Furnishings 2 01-16-2006 08:10 AM
