Originally Posted by John P
That’s good information DJ. Thanks.
The PO had the entire front end rebuilt and He says he spent a lot of money doing so. Maybe the rebuild kit included these spacers/adapters. I’ve driven several thousand miles on this set up and have had all the wheel bearings examined with no issues. Unless you or someone else is adamant that this is unacceptable, I am comfortable as installed. Again, great information. Thanks for your interest and concern.
I would be curious to know the dimensions(width) of the replacement rotor/adapter and compare with the original. If someone with a front wheel off, could possibly post it and you can compare.
The original 5 stud front rotor assembly is to the best of my knowledge NLA. The Rotor has to be bought separately and the eight rusty bolts have to be removed to split the 2 components. It would make me wonder why that was not done on your rig, since the adapter is very expensive, versus just replacing the rotor, which I believe is part Number ACD 18A274A.
Confirmation of this part number from someone how has done it would be appreciated.
https://www.rockauto.com/en/moreinfo...865065&jsn=565
