Old 05-10-2020, 04:21 PM   #1
Roddyy's Avatar
1982 28' Airstream 280
Grantsburg , Wisconsin
'82 Diesel Excella Heater motor replacement
My heater motor needed replacement. It's very accessible so I thought it would be a piece of cake. Bought a new motor/fan assembly from O'Rileys. It was easy to install and started right up but I hardly get any blown air through the ducts. Everything is open so I am assuming that I must have gotten a slightly different assembly than came with the camper. I can't find the VIN so I'm not exactly sure what model Chevy chassis this is. Can anyone guide me to the right place to buy a heater motor and fan assembly?
Roddyy is offline   Reply With Quote
Old 05-11-2020, 03:19 PM   #2
Roddyy's Avatar
I think I may be learning something here about old Airstreams. Apparently they didn't use the standard Chevy parts for their heating/cooling equipment. I'm talking with the possible supplier now, but they are asking me for a picture or model number of the heater fan. Of course I threw that away thinking this would be an easy fix. Does anyone have a picture of your blower motor/fan assembly that you might share with me? If this works I will give everyone the contact info for these replacement blowers.
Old 05-11-2020, 04:07 PM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Curious why the motor was replaced? Same symptoms as new motor?
VIN. Look on registration or title.
Old v new units, any visible why does it look like ???? This.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 05-11-2020, 04:39 PM   #4
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Do you have a pic of the assembly
shepherd57 is offline   Reply With Quote
Old 05-11-2020, 08:59 PM   #5
Roddyy's Avatar
Blower motor pictures
There is another Excella in town and I was able to pull the motor and get a picture of it. the vanes are in the opposite direction than the ones available for a Chevy P20, so this is not a stock item, and the face width is narrower which doesn't seem to matter; there is enough room in the housing for a bigger fan.
Old 05-12-2020, 10:04 AM   #6
1972 31' Sovereign
Dry Branch , Georgia
Blower
You could reverse motor rotation by changing the motor wires around to see if it would blow better.
Buckless is offline   Reply With Quote
Old 05-12-2020, 10:08 AM   #7
1972 31' Sovereign
Or swap fan blades
Old 05-12-2020, 11:22 AM   #8
Roddyy's Avatar
I tried that. This particular fan doesn't blow well in either direction. It appears to me that I need a CCW rotation (when looking at the face of the fan). I see a Four seasons model 35333 that actually looks like a pretty good match but the vanes are different. 35333 rotates CCW and 35334 rotates CW, but the vane designs are totally different. And the catalog says it is CCW looking at the fan, but the sales guy at Four Seasons thinks that the CCW rotation is when viewed from the back of the motor. Aaaaaargh!
Airstream Classic 350 LE Motor Home 1992 Orig. Owner SAirstream Classic 350 LE Motor eBay Watch Airstreams on eBay 0 11-28-2010 10:00 PM
selling AO Smith 105 motor to replace original Armstrong blower motor eubank Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-07-2010 10:09 AM
1994 diesel land yacht motor home frankf Mechanics Corner - Engines, Transmission & More... 4 06-30-2010 07:26 AM
1998 35ft AIRSTREAM CUTTER 35 Diesel Pusher Motor Coach eBay Watch Airstreams on eBay 0 02-15-2009 07:31 PM
Need Help looking at 28' diesel motor home SteveR Airstream Motorhome Forums 1 02-01-2004 06:46 PM
