03-24-2017, 02:49 PM
#41
Dazed and Confused
Hillsburgh
, Ontario
Originally Posted by 81 MexCella
Thanks Tony! We did replace the master cylinder. For the bleeding process we used a pressurized bleeder that sits on top of master and sucks brake fluid from a bottle reservoir. We hook up to the tire for pressure. It beats having to sit there and pump 6x hold down release pump 6x release repeat 50x lol
Try this method as the power steering and brakes are a conjoined system.
http://www.larescorp.com/tech-tips/h...-instructions/
Check flexible hoses for internal leaks if old and not replaced.
Cheers
Tony
03-24-2017, 09:32 PM
#42
Dazed and Confused
Hillsburgh
, Ontario
While it may not be the problem it maybe good for you to get aquainted with the hydroboost system and how it interacts and affects the brakes.
http://www.brakeandfrontend.com/oper...ssist-systems/
Cheers
Tony
03-26-2017, 02:47 AM
#43
1991 25' Airstream 250
Oxford
, Oxfordshire
Tony's links should give you what you need. Further instructions can be found in the service and unit repair manuals
03-27-2017, 07:06 PM
#44
Kelseyville
Serial/Vin Tag location? Help
So we finally got good pressure on the pedal and made the voyage to DMV for the visual vehicle identification part of the interstate title transfer from Nevada to California.
I showed them the vin tag in the engine compartment above the radiator, then he asked me for the location of the safety compliance tag. He described it as containing the vin and stating this vehicle is in compliance with all federal safety standards blah blah blah.
I looked high and low tore back carpets opened all drawers inside and out without any luck!
Can someone tell me where the heck this tag is located?
"Electra"
1981 Airstream Excella 28' Turbo Diesel
Northern California
03-27-2017, 07:44 PM
#45
Dazed and Confused
Hillsburgh
, Ontario
Federal Safety Standards? For a 30+ year old Airstream? The late 70's, early 80's?
I'd be shocked if such a thing existed. I'd be telling the inspector the same thing.
Airstream didn't even keep records, let alone meet any sort of Federal standards, if the Federal standards even existed at all for RV's.
Cheers
Tony
03-27-2017, 08:32 PM
#46
1986 34.5' Airstream 345
Alliance
, Ohio
I believe he tag is located in the inspector's head. I've never seen one, heard of one, or wanted one. I guess that's another reason I'll never live in California.
03-27-2017, 08:48 PM
#47
Kelseyville
Is the vin number on any other location/tag on these coaches aside from engine compartment? I guess I'm looking for something like this.
"Electra"
Northern California
03-27-2017, 09:37 PM
#48
Dazed and Confused
Hillsburgh
, Ontario
Believe it or not I did find a RVIA tag. It's a yellowed plastic oval shaped tag riveted onto the skin just above the step to the right of the main door. I'll take a picture of it tomorrow.
My bad, I'm shocked I found it.
Cheers
Tony
03-28-2017, 04:00 AM
#49
Alliance
, Ohio
Yes. I have a RIVA tag in the same location and the axle loading sticker on the headliner above the drivers seat. Neither have the Vin number on them.
03-28-2017, 05:56 AM
#50
Dazed and Confused
Hillsburgh
, Ontario
Here are the pics:
Cheers
Tony
03-28-2017, 06:44 AM
#51
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Debbie says I should issue tags certified by Bob....Good enough doesn"t satisfy me...Although indexing screws is one of my OCD issues or concerns items like fire suppression systems, correct brakes, wiring ,tires etc. are just absolutely necessary for a trouble free and enjoyable trip. Regards, Bob
03-28-2017, 07:18 AM
#52
Dazed and Confused
Hillsburgh
, Ontario
I looked at previous photo's of your coach and though difficult to see I couldn't see a tag beside the doorway. If that is the case and a tag is nowhere to be found on your coach I would get a hold of the RVIA or your local RV dealer to start the jumping through hoops process of certification.
Hopefully you find the tag.
Cheers
Tony
03-28-2017, 12:41 PM
#53
Kelseyville
Originally Posted by isuzusweet
i looked at previous photo's of your coach and though difficult to see i couldn't see a tag beside the doorway. If that is the case and a tag is nowhere to be found on your coach i would get a hold of the rvia or your local rv dealer to start the jumping through hoops process of certification.
Cheers
tony
thanks tony!!!!!
"Electra"
Northern California
03-28-2017, 02:19 PM
#54
1984 31' Airstream310
Honokaa
, Hawaii
It sounds like the DMV guy is looking for a tag like the one you posted at #47. DOT regs require them for vehicles being imported, see #2 at https://icsw.nhtsa.gov/cars/rules/im...ite/index.html
That site also gives some unhelpful clues as to where the tag should be. No idea why he wants to see it for your rig unless maybe he thinks it's homemade.
03-28-2017, 03:13 PM
#55
Dazed and Confused
Hillsburgh
, Ontario
thanks tony!!!!!
Did you end up finding it? If so, where on your coach?
Cheers
Tony
03-28-2017, 07:45 PM
#56
1982 28' Airstream 280
Port Angeles
Many years ago I did a bus conversion in Calif. After spending a good part of an afternoon at the DMV trying to get an explanation of "inhabitable" so I could register the bus as an rv, I finally ask "What does your inspector check off on his list to determine what is inhabitable?" Their response, "We don't have an inspector, you just state that it is inhabitable on a form." I drove to the next nearest DMV and filled out the form and got it registered. I suggest you find another DMV office and try again. If they want another tag, show them the Airstream tag above the other side of the radiator.
Cheers, Dan
~ Margaret Thatcher ~
03-28-2017, 09:03 PM
#57
Dazed and Confused
Hillsburgh
, Ontario
So just an update from my end. I sent a request for information to Gorving, which is the consumer side of RVIA, asking them for more information on the RVIA tags.
I asked 1) Where were the tags first issued to RV's and if an RV is missing its tag what steps would have to take place on replacing or certifying, (if the RV was never issued one).
Haven't heard back yet.
BTW Dan, your 82, Mexcella is 81, both 280's, does yours have a tag, and if so, where?
Cheers
Tony
03-29-2017, 07:39 PM
#58
1979 24' Airstream Excella 24
Tipp City
, Ohio
Have you looked on E-bay? I seem to recall seeing those tags on E-bay a while back.
03-29-2017, 10:25 PM
#59
Kelseyville
Originally Posted by Isuzusweet
Here are the pics:
Cheers
Tony
Electra has that tag in the same location, but it's not the one the DMV guy was looking for. I called Airstream customer service and apparently this is a common request. I emailed the Airstream rep my vin and contact information and Airstream will mail me a verification letter to shove in the DMV guys face. Doesn't look like I'm going to make the April 7th trip but I'm close.
"Electra"
Northern California
03-29-2017, 10:37 PM
#60
Port Angeles
Cheers
Tony
Hey Tony my RVIA tag is behind the right front wheel well just ahead of the panel seam at the rear of the cockpit. Just aft of the seam is a decal from Florida where the coach was originally purchased.
Cheers, Dan
