03-09-2017, 12:27 AM
#21
Kelseyville
Wheel Hub Hunt
So I'm at a stand still without any luck in finding new wheel hubs for the front. Are these seriously a one off Hub for Airstream? Are there any other known vehicles I can hunt for at wrecking yards? The hubs that were on it have damaged races and I do t want to replace rotors and bearings in that condition. Does anyone have any suggestions? Can the original ones be rebuilt/restored? In the mean time I'm working replacing radiator, water pump, and hoses. Here's a pic of my coach in its current state. Not sure if I'll make the April 6th coast camping trip in Eureka.....
"Electra"
1981 Airstream Excella 28' Turbo Diesel
Northern California
03-09-2017, 12:53 AM
#22
1991 25' Airstream 250
Oxford
, Oxfordshire
Check to see if the ACDELCO 18A274A is the replacement part for Tony's OEM code. I think Rockauto have them.
all the best
Nick
03-09-2017, 12:58 AM
#23
Kelseyville
all the best
Nick
I looked up the part number, that is just the Rotor part of the assembly. Ordered those already The hunt continues!
"Electra"
Northern California
03-09-2017, 01:05 AM
#24
Oxford
, Oxfordshire
There was a fella up in canada parting out a 310, he might have them.
03-09-2017, 07:35 AM
#25
Richmond
, Kentucky
Here's a listing for someone on ebay selling 310 parts. I think the seller used to be called "runamuck083" but that user name doesn't seem to be on ebay anymore.
1975 24' Argosy Motor Home
03-09-2017, 08:35 AM
#26
1981 31' Excella II
New Market
, Alabama
There are places that restore old cars that can weld the brake surface and then turn it back down again assuming the hubs are fine other than that.
I would call Jackson Center and ask them about the part and if it is a special made rotor. If so, what is so special about it that they had to have a special part made for the Airstream motor home? There might be other rotors that will fit.
Perry
03-09-2017, 09:34 AM
#27
1984 31' Airstream310
Honokaa
, Hawaii
So, you can't press out the old races and replace?
03-09-2017, 09:38 AM
#28
Richmond
, Kentucky
That's what I've was wondering. If the problem is a race has spun in the hub housing then you can take the hub to a competent machine shop and they should be able to weld the bore of the hub and then turn it back to spec on a lathe.
03-09-2017, 09:44 AM
#29
2021 16' Bambi
2021 22' Bambi
North Port
I believe what you're calling a hub is actually the wheel spacer. You would remove that from the rotor and install onto the new rotor. The bearing races would be pressed into the new rotor. Really no need to replace the spacer unless it's damaged somehow.
03-09-2017, 10:35 AM
#30
1981 31' Excella II
New Market
, Alabama
What is wrong with the hubs other than the thickness on the rotors is below the limit?
Perry
03-10-2017, 07:42 AM
#31
Kelseyville
That's exactly the problem. The races sit loose in the Hub assembly. I just found out yesterday about the process mentioned above. I found a machine shop that will bore out the Hub press in a sleeve and then bore out the sleeve to the correct race diameter. Looks like this opportunity is solved Thanks for all the help and suggestions fellas!
"Electra"
Northern California
03-12-2017, 08:19 AM
#32
1981 31' Excella II
New Market
, Alabama
Sometimes you can just go with a bearing that has a larger OD and skip the shim part. Or you can put in a bigger bearing and add the shim to the spindle. mcmaster.com has bearings. You just put in the OD and ID and it finds the bearings.
Perry
03-13-2017, 08:42 AM
#33
1979 28' Airstream Excella 28
Albuquerque
, New Mexico
OP,
Impressed at the speed you are working on this! And you got for an even better price than I did
Out of curiosity, did you replace the radiator and water pump as preventative maintenance, or was there a problem? Mine seem to be doing their job, so I replaced the fluid and have fingers crossed...
Looking forward to seeing your progress
03-13-2017, 11:54 PM
#34
Kelseyville
Originally Posted by kyote
OP,
I'm replacing as preventative maintenance, the radiator will actually be rebuilt with a new core and the water pump I ordered new. The radiator had some collected rust from sitting and the water pump bearing squeaked a little. I plan on taking "Electra"cross country so I want to do so with some peace of mind....that and my buddy who's working on it for me is a helicopter mechanic by trade and big on preventive maintenance. Hence the serious service job we're into.
"Electra"
Northern California
03-17-2017, 05:56 PM
#35
1981 31' Excella II
New Market
, Alabama
I would put OEM stuff back on it from who ever built the engine. I have had a lot of water pump bearings fail because they were not well made. You get what you pay for. The same goes for rebuilt brake calipers.
Perry
03-24-2017, 06:27 AM
#36
Kelseyville
3-20-17 Update
We have now replaced all brake lines, turned rear rotors, replaced front rotors, replaced front and rear shocks, packed and replaced all bearings, replaced water pump, rebuilt Radiator, new hoses, belts, all filters, and all fluids. And of course new tires.
Went through and sand blasted all terminals and replaced all bulbs on outside lighting. Got all to work! The plastic housing on the top lights was so brittle and worn I had to use some RTV Sillicone to hold lens in place. I'll replace all housings and lenses in the future when I go led.
When we removed the radiator we noticed the fan shroud was missing, so we ordered a universal one from Summit and fabed it in there.
A few things left to do before April 7 maiden voyage: register with DMV lol, replace ft and rr air bags (have parts already), replace fuel lines, located a propane leak (soappy water time). Re-bleed brakes.
Here are some pix
"Electra"
Northern California
03-24-2017, 06:35 AM
#37
Kelseyville
Bleeding Out ???
We bled the brakes with a pressurized bleeding tool and flushed out all the old fluid. We got good pressure at the pedal. This was with the engine off. Once we got the engine running again after finding the manual priming pump near injectors, we lost pressure at the pedal and it can be pushed all the way down. Is there a trick to bleeding a hydroboosted system or something we're doing wrong?
Erny
"Electra"
Northern California
03-24-2017, 06:56 AM
#38
Dazed and Confused
Hillsburgh
, Ontario
Erny
Did you replace the master cylinder? If not, you may have toasted a seal in the old cylinder.
The system is an absolute pain to bleed, especially the longer the coach. It can take three or four tries before all the air is out. Keep a real eye on the reservoirs as they can be depleted and add more air to the system as you go.
Amazing work and your rig will be a joy using as you have taken care of pretty well all problems from the get go.
Cheers
Tony
03-24-2017, 09:17 AM
#39
Kelseyville
Cheers
Tony
Thanks Tony! We did replace the master cylinder. For the bleeding process we used a pressurized bleeder that sits on top of master and sucks brake fluid from a bottle reservoir. We hook up to the tire for pressure. It beats having to sit there and pump 6x hold down release pump 6x release repeat 50x lol
"Electra"
Northern California
03-24-2017, 11:30 AM
#40
Baltimore
, Maryland
It looks nice, especially for six grand.
John
