Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 01-17-2021, 03:11 PM   #1441
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I got a little distracted today and decided to wash the 370LE......itís been a while since I washed the fuel tank in the Yukon XL, (DAMM), so I thought Iíde get that done. Regards, BobClick image for larger version
ID:	387122Click image for larger version
bobmiller1 is offline   Reply With Quote
Old 01-20-2021, 09:47 AM   #1442
bobmiller1's Avatar
I started the re-do of the transmission cooling lines. I am eliminating the radiator circuit as I feel that the radiator only increases the temperature to above 200 degrees. I am also increasing the diameter of the lines from 5/16Ē to 3/8Ē which is not only standard for an E4OD but also the auxiliary cooler. The auxiliary cooler has a thermostatically controlled fan which comes on at 200 and off at 160. Iím in the fine tuning stage now and will see how this modification works, Regards,Bob Click image for larger version
Old 01-20-2021, 10:47 AM   #1443
What size cooler did you use?
1975 24' Argosy Motor Home
Old 01-20-2021, 01:16 PM   #1444
bobmiller1's Avatar
3/8Ē
Old 01-20-2021, 01:42 PM   #1445
Originally Posted by bobmiller1 View Post
3/8Ē
Sorry, I meant BTU.
Old 01-20-2021, 03:39 PM   #1446
bobmiller1's Avatar
LOL.....get it right.....I have no idea, Iíll look it up in the paperwork and let you know......personally certain specs, and thatís one of them, donít mean diddely to me, they either work, or they donít. Regards, Bob
Old 01-20-2021, 04:33 PM   #1447
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Brad, I used this 29200 BTU cooler when I recently went all hard lines, added a thermal switch and a fan.
Happy so far.
https://www.summitracing.com/parts/BMM-70274
Chevy is stock 3/8
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 01-21-2021, 07:44 AM   #1448
My issue was finding space to put one so I found the largest cooler that seemed to fit the space, 20,500 BTU, and mounted it. Considering a 370 is almost twice the length and weight of my 20' I would assume something much larger would be needed. As an aside, I'm not routed through the radiator either.
Old 01-21-2021, 07:47 AM   #1449
Happy so far.
Chevy is stock 3/8
Mine is a B&M as well. Your 70274 would probably not fit on my Argosy. I did not want to install it in front of the radiator so it's mounted underneath. Unfortunately there is a lot less space under a 20' compared to a 350 or 370.
Old 01-24-2021, 12:50 AM   #1450
bobmiller1's Avatar
Iíve got the new 3/8Ē transmission cooling lines mapped out now to the auxiliary cooler, just need a few more adapters and some final tweaking to make everything good. I received the new air compressor stainless steel check valves and pressure switches for both Charlyís and my 370LEís. Weíll be able to raise our pressures to approximately 125 PSI with a cut in of around 80 PSI. Regards, BobClick image for larger version
ID:	387437Click image for larger version
ID:	387438Click image for larger version
ID:	387439Click image for larger version
ID:	387440Click image for larger version
ID:	387441Click image for larger version
ID:	387442Click image for larger version
ID:	387443Click image for larger version
ID:	387444Click image for larger version
ID:	387445Click image for larger version
Old 01-24-2021, 05:37 PM   #1451
Airstream Driver
1994 30' Excella
Images: 49
Iíve got the new 3/8Ē transmission cooling lines mapped out ....
How did you map them, were you able to use some of the older lines or did you have to start from scrap?
AIR #13
Old 01-25-2021, 12:26 AM   #1452
bobmiller1's Avatar
Being that the radiator circuit is not being used, the new 3/8Ē transmission cooling lines now only have to go to the rear of the air reel storage well is, just forward of the steps on the curb side. The total run is about 5í for each line compared to 20í for the 5/16Ē lines. I also found another potential restriction in the 5/16Ē lines that I installed 2 years ago with the brass adapters that I used to join the 5/16Ē lines to the auxiliary cooler. Iím going to take a closer look at that tomorrow morning to see if I was right. Regards, Bob
Old 01-26-2021, 02:14 PM   #1453
bobmiller1's Avatar
I finished up the install of the new air compressor pressure switch and stainless steel high temperature check valve. The original check valve has a slight leak going back to the compressor , another reason the compressor ran more than it should, but hey.......30 plus years, no complaints. I have all the adapters I need to finish the new 3/8Ē transmission cooling lines so Iíll start to tackle that tomorrow morning. Regards, Bob Click image for larger version
ID:	387604Click image for larger version
Old 01-27-2021, 01:06 PM   #1454
bobmiller1's Avatar
Air pressure was still at 50 PSI this morning. Thatís great ! I know that the front leveling valves have a slight leak, Charlyís gonna get in touch with Gillig to see if theyíre still available. He has the same issue, as Iím sure all 370LE owners have, Gillig doesnít make the leveling valves, so I may try to outsource them through Fleetpride or EBay to save some loot. More money for fuel........Regards, Bob
Old 01-28-2021, 10:16 AM   #1455
bobmiller1's Avatar
The transmission cooling lines are all finished, just have to drill the frame and install the isolation mounts that hold the lines apart and from rattling, not that I could hear it. Regards, Bob
Old 01-28-2021, 11:50 AM   #1456
bobmiller1's Avatar
ID:	387704Click image for larger version
Old 01-28-2021, 11:57 AM   #1457
bobmiller1's Avatar
ID:	387713Click image for larger version
ID:	387714Click image for larger version
ID:	387715Click image for larger version
Old 01-28-2021, 02:46 PM   #1458
1986 34.5' Airstream 345
Londonderry , New Hampshire
A very neat and tidy job on the oil lines.
Air345Fly is offline   Reply With Quote
Old 02-11-2021, 02:14 PM   #1459
bobmiller1's Avatar
Charly and I are on a quest (pun intended) to eliminate all of our air leaks in the air suspension system of our 370LEís. He was able to find the OE leveling valves for his front end but being that his front end is out right now he sent them to me. I eliminated about 60% of my leakage due to a leaking check valve and pressure switch at the compressor. Iíll install the valves this Sunday and see if that helps.....canít hurt. The YukonXL has been kicking my hinny.....I think I have all the right parts now, Iím into it for about $1,700.00 just in parts, all for a leak and an incorrect gauge reading. Iíve replaced both fuel pumps and sending units in both tanks, all the EVAP hoses, fuel tank straps, and the crossmember which holds the winch which holds the spare tire up. Regards, Bob Click image for larger version
ID:	388484Click image for larger version
ID:	388485Click image for larger version
ID:	388486Click image for larger version
ID:	388487Click image for larger version
ID:	388488Click image for larger version
ID:	388489Click image for larger version
Old 02-11-2021, 02:43 PM   #1460
Airstream Driver
1994 30' Excella
Images: 49
I am not particularly fond of the Hadley internal check valve. Its just some rubber ball subjected to a lot of motion. I have considered adding high quality brass check valves in a few places
AIR #13
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 26 09-14-2021 06:26 PM
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 07:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 07:19 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 06:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 09:32 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
