Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 10-27-2020, 06:37 PM   #1401
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Originally Posted by bobmiller1 View Post
OK, this is for Peter.....Ill try to explain the suspension on the 370LE which is very different from the other Classic motor homes. The frame is from a Gillig bus. The main suspension is supported front and rear by 4 air bags. The frame height from the bottom of the frame to the floor is 27. The rear ride height is determined by the adjustments on the tag axle. The tag axle is a torsion axle with a limited amount of travel up and down just like the trailers and the 325, 345, 350 and 360 series classic motor homes. The mid point of travel of the tag axle is where the frame is exactly 27 from the ground. When the rear is jacked up the drive axle has more up and down movement because it is not a torsion axle. Regards, Bob
Thanks Bob, for explaining the different set-up. Again, I like that it doesn't dump the rear bags when using the levelers, which in my opinion is a huge waste of resources.
AIR #13
PeterH-350LE is online now   Reply With Quote
Old 10-30-2020, 07:02 AM   #1402
1995 36' Classic 36
Ludington , Michigan
My HWH dumps all the bags before extending the jacks in auto mode. I usually run it manually and extend the jacks just enough to stabilize it and minor leveling. You can manually push the dump button and just take it down part way.
Kota is offline   Reply With Quote
Old 11-16-2020, 04:40 PM   #1403
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Gonna hit Charlys (Streamquest) next weekend. Ive been promising for a while and since my sister cancelled thanksgiving I have 3 free days. Were going to de-emission his 460 like I did to mine, get rid of the Dura-spark ignition and install a GM HEI 1 wire set up. If we have the time well also install the 1 wire 200 amp alternator set up.......hes been thinking about the E4OD but I need more time for that. Maybe I can get him to cruise with me to Arkansas next October.....its pretty cool seeing 2 370LEs going down the road together. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 11-16-2020, 05:02 PM   #1404
1995 36' Classic 36
Sounds like a good way spend the holiday! A break from tradition! We will probably eat and drink too much while watching the Lions get their ass kicked.
Old 11-28-2020, 10:53 AM   #1405
bobmiller1's Avatar
Alright.....so day 2 has started with de-emissioning or lets say the new term is de-commissioning his 370LE. The left cylinder head has to much PO damage from an ill attempted previous repair, which will necessitate the removal of the left cylinder head which is almost impossible to accomplish with the engine in the 370LE. So he had decided to install the same transmission as I have and install a new HO 460 like I have done. So now the real work starts.....he will also be upgrading the radiator. Condolences can be sent to him (Streamquest) through the forum. He is trying to quarantine me here for obvious reasons......Regards, BobClick image for larger version
ID:	383946Click image for larger version
ID:	383947Click image for larger version
ID:	383948Click image for larger version
ID:	383949Click image for larger version
Old 11-28-2020, 07:31 PM   #1406
bobmiller1's Avatar
I dont think Ive done this much work in this short amount of time.....transmission is out, front end is removed, and the engine is now out....I would like to get the radiator out tonight. I am leaving tomorrow and Charly will have a list of stuff to do before I return . Regards, BobClick image for larger version
ID:	383981Click image for larger version
ID:	383982Click image for larger version
ID:	383983Click image for larger version
ID:	383984Click image for larger version
ID:	383985Click image for larger version
ID:	383986Click image for larger version
ID:	383987Click image for larger version
ID:	383988Click image for larger version
Old 11-29-2020, 06:44 AM   #1407
bobmiller1's Avatar
Remind me never to go anywhere and help someone for the weekend.......Im spent, talk about a marathon ! LMAO !! We did it, we both cranked, about 18 hours, its all done including the radiator. I contacted my tranny guy, hes pumped, Charlys got his engine guy, radiator guy. I think Charly just wants to be able to cruise at 82 MPH like I do........ gives me a reason to get going on the 2 speed rear end......I have to keep the edge on !Click image for larger version
ID:	384003Click image for larger version
ID:	384004Click image for larger version
ID:	384005Click image for larger version
ID:	384006Click image for larger version
Old 11-29-2020, 01:25 PM   #1408
1986 34.5' Airstream 345
Alliance , Ohio
My back hurts just looking at the pictures. Great work guys. Brings back memories of my youth. I can remember combing my hair after such work stints and getting grit, grease, parts of gaskets and other unidentifiable material on the comb and floor. I usually had to throw the clothes away as my mother would not allow them near the washing machine.
mehes is offline   Reply With Quote
Old 11-29-2020, 01:33 PM   #1409
Roswelll , Georgia
I think you are both infected with Covid-370, so quarantine is in order.
What happened to the paint on Charley's 370? It looks naked.
bora77 is offline   Reply With Quote
Old 11-30-2020, 06:46 AM   #1410
1995 36' Classic 36
You guys are animals!
Good to see Charley is doing the job right. At least in my opinion. I see a drag race at the next get together.
Ive been busy getting the place ready for winter. Bunch of work to do on the 94 360 when I get it in the heated shop. What are your covid Christmas plans!
Old 11-30-2020, 08:37 PM   #1411
Paul J Mauro's Avatar
1985 34.5' Airstream 345
Bolton , Massachusetts
Ok you guys are birds of a feather (looney birds) that was super speed . Looking at the pictures I have garage envy as well as a feeling of inadequacy .do I need counseling ?
Paul J Mauro is offline   Reply With Quote
Old 12-01-2020, 03:26 PM   #1412
Airstream Driver
1994 30' Excella
Images: 49
its all photoshop
AIR #13
Old 12-06-2020, 08:42 PM   #1413
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
“green screen” eh Peter?
mayco is offline   Reply With Quote
Old 12-20-2020, 03:09 PM   #1414
bobmiller1's Avatar
Time to get going on some of the stuff planned for the 370LE. I bought this stuff a couple of years ago, and now that a majority of the heavy work is done, its time to install this system. Its basically a carbon copy of the system I installed on the 325LE with the exception of an additional head for the top of the transmission area. Planning on ripping out the original hardwood floor and dinette and replacing with original oak 5/8 or 3/4 and rebuilding the step well area where that useless plastic insert is located. Going to make the dinette 4 longer to take care of my long legged issue and install a new drawer for pots and pans under the forward bench. Click image for larger version
ID:	385224Click image for larger version
ID:	385225Click image for larger version
ID:	385226Click image for larger version
ID:	385227Click image for larger version
Old 12-28-2020, 09:35 AM   #1415
bobmiller1's Avatar
Along the list of improvements was to take care of the water pump pressure switch. Although the Seaflow pump is one of the best because of flow and pressure as Mike previously stated (Mayco) they use a 5 cent pressure switch. Although I routed the ground instead of the power through the factory pressure switch I was still having intermittent concerns (problems) I decided to go with a more commercial set up, about $60.00. Moving along as well on the fire suppression system. Regards, Bob Click image for larger version
ID:	385619Click image for larger version
ID:	385620Click image for larger version
ID:	385621Click image for larger version
ID:	385622Click image for larger version
Old 12-29-2020, 11:59 AM   #1416
bobmiller1's Avatar
I installed the new water manifold this morning, no leaks. The water pump works great, holds pressure at 40 PSI while the shower is running. I need to install another new liquid filled gauge on the city water inlet feed so I can see the pressure coming in while hooked up to city water, why ??? Just something else to look at. Regards, Bob Click image for larger version
Old 12-29-2020, 12:09 PM   #1417
bobmiller1's Avatar
Old 12-29-2020, 12:43 PM   #1418
Airstream Driver
1994 30' Excella
Images: 49
I installed the new water manifold this morning, no leaks. The water pump works great, holds pressure at 40 PSI while the shower is running. I need to install another new liquid filled gauge on the city water inlet feed so I can see the pressure coming in while hooked up to city water, why ??? Just something else to look at. Regards, Bob Attachment 385709Attachment 1
I always use a pressure regulator at the faucet, not interested in seeing 90 psi entering any section of my onboard lines
AIR #13
Old 12-29-2020, 01:54 PM   #1419
bobmiller1's Avatar
You need better lines........LMAO !
Old 12-29-2020, 03:10 PM   #1420
Airstream Driver
1994 30' Excella
Images: 49
That is actually true, so in the meantime I'll keep the pressure around 40psi
AIR #13
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 26 09-14-2021 06:26 PM
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 07:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 07:19 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 06:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 09:32 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
