Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 03-01-2020, 08:10 AM   #1181
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
The 370LE model is the Gillig commercial bus chassis. The 345 is a Chevrolet P32 chassis. A completely different breed of cat. The 325LE that I also own, that engine comes out the front. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 03-01-2020, 08:11 AM   #1182
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by Paul J Mauro View Post
wow I am impressed . ! I want to upgrade my 85 345 engine and tranny so I guess you have concluded that going from underneath was better than removing the nose or did the front suspension need to come out anyway ?
The 370 may look like the rest of the classics but is a totally different chassis and drive train.
martin300662 is offline   Reply With Quote
Old 03-01-2020, 10:35 AM   #1183
Paul J Mauro's Avatar
1985 34.5' Airstream 345
Bolton , Massachusetts
ok thanks - i thought I was off . did you to an engine on your other rig ?,my 454 is tired but since I bought it new in 1985 it has a right to be retired .just can find a great truck,rv or other place that will take it on near boston so I may have to drive it far away
Paul J Mauro is offline   Reply With Quote
Old 03-01-2020, 02:28 PM   #1184
guess Im getting warmed up to put a new 454 and new trans in my 85 345 i wouldnt mind paying for some help if I could find some ! in the planning stage now
Old 03-01-2020, 02:43 PM   #1185
bobmiller1's Avatar
Dashboard in ! More wiring out, removed the Magic (useless) box that controls the idiot lights, or at least it was supposed to. Removed all of the original remnants of the obsolete cruise control....will be going with a digital one this summer. The wiring looks crazy, but it is organized chaos. Click image for larger version
ID:	362297Click image for larger version
ID:	362298Click image for larger version
ID:	362299Click image for larger version
ID:	362300Click image for larger version
ID:	362301Click image for larger version
ID:	362302Click image for larger version
ID:	362303Click image for larger version
ID:	362304Click image for larger version
ID:	362305Click image for larger version
Old 03-01-2020, 02:44 PM   #1186
bobmiller1's Avatar
ID:	362307Click image for larger version
ID:	362308Click image for larger version
Old 03-01-2020, 03:34 PM   #1187
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
Here is something you donítAttachment 361789 see every day.....Attachment 361788 Regards, Bob
AC Delco distributor on a Ford? Blasphemy
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement EZ-Lift WD with 2 Anti Sway Bars. previous tow vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L
Ultraclassic is offline   Reply With Quote
Old 03-01-2020, 03:57 PM   #1188
bobmiller1's Avatar
No......! Reliability my friend, Regards, Bob
Old 03-01-2020, 05:31 PM   #1189
2000 30' Excella
GTA , Ontario
I was kidding, the Delco set up is clean, just add key power, and your good to go, also tach hook up. Depending on the age of the dist you can get the advance curve adjusted with weights and the diaphragm is adjustable thru the vac port
Old 03-05-2020, 04:46 PM   #1190
bobmiller1's Avatar
Moving forward, the final template is done for the new dash, now that it is installed, front end to be reinstalled this weekend. Weíre going to start the engine March 28, 2 weeks behind schedule...... not bad considering the additional work that had to be done. Regards, BobClick image for larger version
ID:	362646Click image for larger version
ID:	362647Click image for larger version
ID:	362648Click image for larger version
ID:	362649Click image for larger version
ID:	362650Click image for larger version
ID:	362651Click image for larger version
ID:	362652Click image for larger version
ID:	362653Click image for larger version
ID:	362654Click image for larger version
Old 03-05-2020, 09:06 PM   #1191
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
What is that big ol box for Bob?
mayco is offline   Reply With Quote
Old 03-06-2020, 06:32 AM   #1192
bobmiller1's Avatar
For Mike.......Click image for larger version
Old 03-06-2020, 03:02 PM   #1193
"Alumi-holic"
cesalie2's Avatar
Dearman Avenue , Tennessee
Bob,
Truly impressive work!
cesalie2 is offline   Reply With Quote
Old 03-08-2020, 07:03 PM   #1194
bobmiller1's Avatar
I got the shop all cleaned up today and the front end is now in position to be installed. I dropped off the back-up camera box to my upholstery guy so it will match the rest of the dashboard. All of the switches are done and ready to be installed in the new dash.Click image for larger version
ID:	362888Click image for larger version
ID:	362889Click image for larger version
ID:	362890Click image for larger version
ID:	362891Click image for larger version
ID:	362892Click image for larger version
Old 03-08-2020, 08:17 PM   #1195
mayco's Avatar
It’s about time you got something done on that thing....geeeeezzzzzzzz
Old 03-08-2020, 08:18 PM   #1196
mayco's Avatar
Itís about time you got something done on that thing....geeeeezzzzzzzz
Old 03-09-2020, 01:29 PM   #1197
bobmiller1's Avatar
The second go-around with the wood dashboard proved fruitful ! The final template for the instrumentation is also done. Iím pushing forward !Click image for larger version
ID:	362941Click image for larger version
ID:	362942Click image for larger version
ID:	362943Click image for larger version
ID:	362944Click image for larger version
Old 03-12-2020, 02:08 PM   #1198
bobmiller1's Avatar
Iím burning the wick in both ends now....came up with a great idea to wire in the oil pressure/oil temp/cylinder head temp sensors all in the same loop ! The exhaust/driveshafts/air parking brake all reinstalled. The dashboard should be finished this weekend. I got the overhead box that houses the stereo/back-up camera back from the upholstery shop today. More pictures to follow tomorrow. Regards, Bob Click image for larger version
ID:	363124Click image for larger version
ID:	363125Click image for larger version
ID:	363126Click image for larger version
Old 03-13-2020, 08:59 AM   #1199
bobmiller1's Avatar
Still moving forward.....should get a lot done this weekend. Regards, BobClick image for larger version
ID:	363184Attachment 1Click image for larger version
ID:	363186Click image for larger version
ID:	363187Click image for larger version
ID:	363188Click image for larger version
ID:	363189Click image for larger version
ID:	363190Click image for larger version
ID:	363191Click image for larger version
ID:	363192Click image for larger version
Old 03-13-2020, 12:11 PM   #1200
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Good looking Aida Express.
I have three high pressure German keroís and two Coleman kero.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is online now   Reply With Quote
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 26 09-14-2021 06:26 PM
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 07:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 07:19 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 06:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 09:32 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
