Old 08-19-2019, 10:45 AM   #1061
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Will the Michelin 225 tires work on the rear of the 310 with the 761002 Alcoa rims, saw where people stated they were to close to each other on the Forums. This is why I have been searching for 8R/19.5 tires for so long. Thanks on the centermatic info.
cole3444 is offline   Reply With Quote
Old 08-19-2019, 12:11 PM   #1062
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
No problem, the 370LE clearance is a little over 1Ē.
bobmiller1 is offline   Reply With Quote
Old 08-19-2019, 12:12 PM   #1063
bobmiller1's Avatar
Youíre probably running a steel rim on the inner, correct ?
Old 08-19-2019, 12:30 PM   #1064
1971 31' Sovereign
1972 31' Sovereign
Yes, steel rim on inside rear, that makes it easier to find tires in my area running 225's
Old 08-19-2019, 12:58 PM   #1065
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I don't mean to be a downer but in the interest of safety the Michelin XZE 225/70R19.5 has a maximum speed rating of 75 MPH. Most all 19.5 tires are rated a 75 MPH maximum speed.
Having a tire come apart at speed can not only adversely affect your day but can inflict significant damage to your Airstream.
Cheers, Dan
~ Margaret Thatcher ~
Old 08-19-2019, 03:49 PM   #1066
bobmiller1's Avatar
Speed rating on tires
Point taken....i will check that one out.....i have always been known to push the limits, regards, bob
Old 08-23-2019, 11:11 PM   #1067
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Seems like there may be a little more room on the top end.
Faster Bob, Faster!!!
https://www.michelinb2b.com/wps/b2bc...5_Bulletin.pdf
streamquest is offline   Reply With Quote
Old 08-25-2019, 01:26 PM   #1068
bobmiller1's Avatar
Another FINE example of Airstreamís shoddy workmanship.....after reinstalling the generator the interior start/stop switches would not work, honestly, you would think that they would have used quality butt connectors for the price they charged for these Classic motor homes, but it appears they went to the lowest bidder ! The amp draw in the second 20 amp circuit is 22 amps with both the rear AC and the 100 amp power max converter operating. That explains why the 20 amp breaker was tripping. With the new 30 amp breaker installed the front circuit is drawing 15 amps with the front AC on leaving me plenty of spare power, I believe I could still run the microwave/convection oven, but I donít want to push my luck ! Regards, BobClick image for larger version
ID:	350444Click image for larger version
Old 08-25-2019, 01:48 PM   #1069
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
HEY! What gives?
You're something special to get butt connectors; must have been an upgrade from the screw on wire cap connectors my coach has.
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 08-25-2019, 10:31 PM   #1070
bobmiller1's Avatar
Iím almost done with the windshield list......Cooperstown next weekend ! I finished up installing the additional closet lighting that I wanted to do and the second used cancel overdrive switch that I got off of EBay worked so that is installed now and operational ! Life is good ! Regards, BobClick image for larger version
ID:	350496Click image for larger version
ID:	350497Click image for larger version
ID:	350498Click image for larger version
ID:	350499Click image for larger version
ID:	350500Click image for larger version
Old 08-26-2019, 12:48 PM   #1071
1971 31' Sovereign
1972 31' Sovereign
Bob,
On your 325 what type of lug nut cover did you use to cover the extra lug nut holes on your front 5 lug Alcoa rims. Getting ready to try the 225's on the rear of my 310. My tire guy asked me how I was going to cover the extra holes on the front rims. Didn't know if you had a part number for the lug nut cover.
Old 08-30-2019, 05:50 AM   #1072
bobmiller1's Avatar
Another ďlast minuteĒ project before the Labor Day weekend trip was to find a place to put my collapsible ladder when not using it. I used to put it on the floor next to the couch or on the bedroom floor.....always in the way. A 6Ē PVC pipe was to big and a 4Ē to small. I was able to obtain the perfect 5Ē and related end caps/hangers to make it happen. I will also be trying the new/old overdrive switch tonight on the ride out. Regards, BobClick image for larger version
ID:	350829Click image for larger version
ID:	350830Click image for larger version
ID:	350831Click image for larger version
ID:	350832Click image for larger version
ID:	350833Click image for larger version
ID:	350834Click image for larger version
ID:	350835Click image for larger version
ID:	350836Click image for larger version
ID:	350837Click image for larger version
Old 09-02-2019, 01:30 PM   #1073
bobmiller1's Avatar
Another excellent trip to Cooperstown, performance was excellent with the 370LE, the cancel overdrive switch works as it should kicking me out of 4th gear back into 3 rd..Iíll experiment with the foot up and downshift buttons before the end of the season. Iím making final preparations with Jasper for the engine rebuild and getting ready to pull the ďkitchenĒ for itís replacement in late October. Regards, BobClick image for larger version
ID:	351134Click image for larger version
ID:	351135Click image for larger version
ID:	351136Click image for larger version
Old 09-22-2019, 06:23 PM   #1074
bobmiller1's Avatar
I finished up the docking lights for night time maneuvers......backing into a black hole has never been one of my favorites.....this will definitely do the trick....I hope. Regards, Bob Click image for larger version
ID:	352776Click image for larger version
ID:	352778Click image for larger version
ID:	352779Click image for larger version
Old 09-29-2019, 08:37 PM   #1075
bobmiller1's Avatar
A rare sight to see for sure.....2 of the original 33 370LEís traveling together....to give you a perspective of the length of a 370LE, the following pictures will show. Maybe next year we can get Ken from down south and a few others for a 370 reunion, Regards, BobClick image for larger version
ID:	353240Click image for larger version
ID:	353241Click image for larger version
ID:	353242Click image for larger version
Old 10-03-2019, 01:20 PM   #1076
bobmiller1's Avatar
I put one of these lights on the Snap-On truck and I have got a lot of compliments, the larger 54Ē model, however they make a 36Ē model so.....it fits perfectly. I should have the wiring done on Sunday in time for the last trip in the dark to Cooperstown (Columbus Day) weekend. Regards, BobClick image for larger version
ID:	353478Click image for larger version
ID:	353479Click image for larger version
ID:	353480Click image for larger version
Old 10-03-2019, 03:45 PM   #1077
1995 36' Classic 36
Ludington , Michigan
370 LE start to finish.....
Got one ordered today. A couple idiots decided to ignore my signal and cut me off on lane changes. Should make it difficult for them to tell the cops they didnít see my signal.
https://www.amazon.com/dp/B07NL1ZPZ7..._G0MLDbYCAYW79
Best deal I found.
Kota is offline   Reply With Quote
Old 10-03-2019, 04:22 PM   #1078
bobmiller1's Avatar
Hey good....fits better than I thought it would.....blends in with the belt molding do you donít even notice it when youíre 10 feet back....,either that or my eyes are just bad LOL ! Regards, Bob
Old 10-07-2019, 03:42 PM   #1079
bobmiller1's Avatar
Iím finishing up the rear signal light.....itís coming out nicely. Regards, BobClick image for larger version
ID:	353743Click image for larger version
ID:	353744Click image for larger version
ID:	353745Click image for larger version
Old 10-08-2019, 08:45 AM   #1080
bobmiller1's Avatar
The rear signal/safety light is all done, the back-up light is high intensity. I will give it a good try out this weekend. Regards, Bob Click image for larger version
ID:	353788Click image for larger version
ID:	353789Click image for larger version
ID:	353790Click image for larger version
ID:	353791Click image for larger version
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 26 09-14-2021 05:26 PM
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 06:19 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 05:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 08:32 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
