Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 04-02-2019, 07:44 PM   #921
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I tell you what’s really been great is using the cell phone camera.....it’s a great resource tool for going back and looking......I’ve used it for wiring harnesses and everything else......Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 04-02-2019, 08:56 PM   #922
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Absolutely awesome work Bob! Amazing.
Cheers
Sidekick Tony
Old 04-02-2019, 09:17 PM   #923
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Your right Tony Bob really dose awesome work. Now if it just had a Cummins
shepherd57 is offline   Reply With Quote
Old 04-04-2019, 06:21 PM   #924
bobmiller1's Avatar
A special thanks again to Diane and Frank at Metal Suoermarket in Albany, NY for getting me the 2 sheets of .080 aluminum I need to finish off the front wheel wells if the 370LE after the 2” rigid styrofoam is installed. The front floor gets so dam hot in the summer time and cold in the winter time. I’m sure this will not only make the comfort level excellent but should also cut out all the remaining road noise. I will post detailed pictures of the install after this weekend. I started up the generator today and the rear tires are now back on ! Regards, Bob
Old 04-07-2019, 07:59 AM   #925
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Bob,
The fascia on mine is beginning to fade, too.
Did you use the original Imron or color match with another paint?
Whichever, it makes a nice "refresh" detail.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 04-07-2019, 06:43 PM   #926
bobmiller1's Avatar
I re-visited the battery compartment today....I was not happy with the cheap main fuse holder for the inverter. I broke the first one tightening the battery cable into, so I bought 2 more. Well it is so cheaply made I thought if I hit a pothole it might break off and then I would have a real problem while driving. So I redid the set up and am now using a commercial 300 amp circuit breaker which mounts the way I think it should. In any event, I do not recommend this type of fuse for our applications. Other than that I am still prepping the wheel wells for the rigid insulation install, more later. Regards, Bob Click image for larger version
ID:	337589Click image for larger version
ID:	337590Click image for larger version
ID:	337591Click image for larger version
Old 04-09-2019, 01:56 PM   #927
bobmiller1's Avatar
The single sheet of aluminum is to large to install into the wheel well and because it is .080” it will not flex enough. Even if I drop the front end down it still will not go.....so, I made it into 4 pieces which will fit perfectly together. The left side is the hardest so I picked that side first. Will cut up the 2” insulation this Saturday and see if everything fits. Regards, BobClick image for larger version
ID:	337761Click image for larger version
ID:	337762Click image for larger version
Old 04-13-2019, 08:41 PM   #928
bobmiller1's Avatar
We nailed it today, a solid 10 hours in, all of the 2” foil faced insulation is installed, rear of the tag axle all done as well as both front wheel wells, I should be able to cut out the aluminum .080 panels for the wheel wells tomorrow. The temporary flex 2 1/2” exhaust pipes are in place and we finished the final bolts securing the water tank to the floor/frame. We are shooting for a May 4th start up, possible road test........Regards, BobClick image for larger version
ID:	338077Click image for larger version
ID:	338078Click image for larger version
ID:	338079Click image for larger version
ID:	338080Click image for larger version
ID:	338081Click image for larger version
ID:	338082Click image for larger version
Old 04-14-2019, 09:03 PM   #929
bobmiller1's Avatar
I finished the left front wheel well today with the aluminum, it’s an extremely uncomfortable job, can’t do it sitting down, laying down, nor standing up.....you have to kind of straddle the rotor/caliper. Anyway it came out as expected.....nice. Going through the final check list and I find that I’m adding things as I go along LOL.....it’s never done ! I took some time to gather some part numbers and the paint that I used for the roof as has been requested from me. Front air bag part number is WO1-358-9650, Rear air bag part number is WO1-358-9599, Tie rod L/S NAPA 269-2189L R/S NAPA 269-2190R, Brake Line NAPA 38911, Brake rotor International 2505097C1 or Meritor 23-123572-002, Disc brake pads MX184HD, do not use the NAPA brake pads, they suck and you will have to replace them.....Regards, BobClick image for larger version
ID:	338189Click image for larger version
ID:	338190Click image for larger version
ID:	338191Click image for larger version
ID:	338192Click image for larger version
Old 04-14-2019, 09:34 PM   #930
I hear ya Bob!
Lookin good!
Old 04-15-2019, 08:49 PM   #931
Kvsterling's Avatar
West Chester , Ohio
Were the insulation panels glued underneath to the bellypan? I like the aluminum tape to seal the seams!
Kvsterling is offline   Reply With Quote
Old 04-16-2019, 02:55 PM   #932
Magnet18's Avatar
Churubusco , Indiana
Thanks Bob, looking good!
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 04-17-2019, 06:56 AM   #933
bobmiller1's Avatar
After a year of looking I finally found the “Needle in the haystack” The electric 12 volt adjustable height dinette base that I have been wanting. Airstream offers them in the newer Classic trailers. I got a price of $1,700.00 at Jackson Center and recently got a price of $2,600.00 from Albany RV. Well......to much ! Though a Snap-On dealer in Japan I was finally able to get the manufacturer of the table for Airstream and just ordered it $132.00 plus $145.00 for international shipping. Quite a mark up for Airstream wouldn’t you say......it was worth the wait......Regards, Bob
Old 04-17-2019, 07:48 AM   #934
Well done Bob!
Old 04-17-2019, 03:39 PM   #935
Silver Dreams
stream3's Avatar
1988 34.5' Airstream 345
Columbus , OH
Ouch! $$$
Oh shoot! I'm feeling sick right now - I bought the electric lift from Jackson Center. Never dreamed I could get it from the manufacturer. Costly mistake, but happy you could get yours for a fraction of what I paid.
1988 345LE "Rosie"
-Jerry
stream3 is offline   Reply With Quote
Old 04-18-2019, 01:20 PM   #936
bobmiller1's Avatar
So, the transmission wiring harness is now laid out in the garage floor. This is the part I have not been looking forward to, but I’m going to do it right. I have to find a good place to put the TCM, I’m thinking on the forward bulkhead, just next to the steering column. Any excess wire will be cut back, soldered, and shrink tubed. I’m still recovering from last weekends work......my shoulders are really sore......must be an age thing. I have to repeat the process this Sunday on the right side. Other than that it’s start up time and run around like a chicken with its head off looking for leaks. Still waiting on the kitchen guy, but have not pulled out the cabinets yet. Regards, Bob
Old 04-18-2019, 01:22 PM   #937
Blue Emu is your friend Bob... that the only advice I can give you!
Old 04-18-2019, 04:29 PM   #938
bobmiller1's Avatar
Ah the old “Johnny Bench” remedy...,,I’ll have to look it up !
Old 04-21-2019, 04:21 PM   #939
bobmiller1's Avatar
I’m almost done with the right front wheel well.....ran out of screws, another excuse to go to Lowe’s and spend more $$$$. Transmission wiring harness next. I sure hope it’s cooler in the front after spending almost 3 days installing the 2” insulation and aluminum.....my back and shoulders need a break ! Happy Easter everyone! Regards, Bob Click image for larger version
ID:	338773Click image for larger version
ID:	338774Click image for larger version
ID:	338775Click image for larger version
ID:	338776Click image for larger version
ID:	338777Click image for larger version
ID:	338778Click image for larger version
ID:	338779Click image for larger version
ID:	338780Click image for larger version
Old 04-21-2019, 09:12 PM   #940
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
...ran out of screws, another excuse to go to Lowe’s and spend more $$$$.....
I used to go to Lowes or HD myself to get more stainless steel screws. Now I order in bulk, amazing how much money I save.
https://www.fastenere.com/collection...head_style=Pan
AIR #13
PeterH-350LE is offline   Reply With Quote
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 26 09-14-2021 06:26 PM
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 07:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 07:19 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 06:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 09:32 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
