Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 01-31-2019, 07:40 AM   #861
Originally Posted by Kvsterling View Post
How was foam panels attached to the bellypan/frame? Iím thinking glued and screwed. Currently replacing sections of subfloor including bellypan in those areas, but realize screws will penetrate the bellypan...
The Argosy was constructed by attaching a .030" sheet of aluminum to the bottom side of the steel floor framing (prior to setting the shell on the truck frame), then 1" Styrofoam was placed between the metal framework and finally the 1/2" plywood floor was laid down.
The only melting I saw was around the gas filler opening through the floor. Airstream did a butcher job on the floor in that area and it wasn't sealed at all so when the filler neck hose deteriorated the gas flowed onto the Styrofoam and melted it.
The construction of the Argosies, especially the early ones was pretty slip shod. It appears lots of changes were being incorporated in a short period of time. Probably to be expected on any new product line like a motorhome.
1975 24' Argosy Motor Home
Old 01-31-2019, 10:15 AM   #862
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Luckily they constructed Bella's replacement frame with the 2x1 tubes vertically....so she has 2" styrofoam.
martin300662 is offline   Reply With Quote
Old 01-31-2019, 10:50 AM   #863
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Attachment 332688
Stronger too, for a floor anyway.
mayco is offline   Reply With Quote
Old 01-31-2019, 05:11 PM   #864
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Hell.....may even float ! Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 01-31-2019, 07:08 PM   #865
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I'm not going to try it out, in case it doesn't Bob!
Old 02-05-2019, 10:00 AM   #866
1995 36' Classic 36
Ludington , Michigan
Bob, hereís what you need!
https://youtu.be/2FtNlfAbc2w
Kota is offline   Reply With Quote
Old 02-05-2019, 02:23 PM   #867
bobmiller1's Avatar
Thatís pretty cool,thanks for the info Dave. Regards, Bob
Old 02-06-2019, 05:46 PM   #868
bobmiller1's Avatar
Charly came over from his place near Boston and gave me a hand with a few items. I finished the install of the new sending unit in the bath tub....I mean gas tank. With the addition of the 1/4Ē spacer it fits perfectly. We also installed the new oil cooler lines with the fire proof sheathing over them on the engine side. All new stainless and grade 8 hardware to hold the original rear rock/mud guard across the back. This weekend we will be installing the new rear transmission cross member and getting a good solid start on the new fuel lines as well as mapping out the under floor insulation. I also took a couple of minutes to map out the new engine battery relocation. Regards, BobClick image for larger version
ID:	333054Click image for larger version
ID:	333055Click image for larger version
ID:	333056Click image for larger version
ID:	333057Click image for larger version
ID:	333058Click image for larger version
ID:	333059Click image for larger version
ID:	333060Click image for larger version
ID:	333061Click image for larger version
Old 02-07-2019, 09:59 AM   #869
bobmiller1's Avatar
The new fuel pump is ready to be installed, I duplicated the optional factory rubber mounting system for quieter operation. The clearance is really close on the mounting bracket, so some filing is necessary, Regards, Bob
Old 02-07-2019, 10:00 AM   #870
bobmiller1's Avatar
ID:	333083Click image for larger version
ID:	333084Click image for larger version
Old 02-10-2019, 06:14 PM   #871
bobmiller1's Avatar
I finished up the install of the new rear transmission cross member as well as installing 4 new Exide batteries, now that the engine start battery is up front, that allowed me to have all 3 batteries in the box for the house batteries. Iím sure that will make it possible for using more stuff while dry camping. Regards, BobClick image for larger version
ID:	333329Click image for larger version
ID:	333330Click image for larger version
ID:	333331Click image for larger version
ID:	333332Click image for larger version
ID:	333333Click image for larger version
ID:	333334Click image for larger version
ID:	333335Click image for larger version
ID:	333336Click image for larger version
ID:	333337Click image for larger version
Old 02-10-2019, 10:39 PM   #872
bobmiller1's Avatar
I finished the new wiring harness on the left side for the new fuel pump and the cooling fan on the auxiliary engine oil cooler. Click image for larger version
ID:	333382Click image for larger version
Old 02-12-2019, 01:57 PM   #873
bobmiller1's Avatar
Like I canít leave well enough alone....I found the perfect 4000 watt inverter that will fit into the compartment next to the batteries.....Iíll have to pull down the new kitchen wall to install an inverter only outlet and the remote switch panel to turn it on and off. Since I now have 3 group 31 batteries now Iíll be able to set the coffee maker up at night and have my coffee in the morning. Some state campgrounds donít allow generator usage before 8 AM and I am up at 6. My Coleman drip coffee maker is my back up but it wonít keep the coffee hot after itís brewed.....Regards, Bob
Old 02-12-2019, 06:32 PM   #874
Kvsterling's Avatar
West Chester , Ohio
I love how coffee is your justification for this part of your project. Bob is a man with his priorities in order. I have a 3k watt inverter going in for the same reason☕️.
Iím intrigued about your 2-speed rear diff...how involved is this modification?
Kvsterling is offline   Reply With Quote
Old 02-12-2019, 06:35 PM   #875
bobmiller1's Avatar
Simple on the 370LE, because of the Spicer housing that Gillig used, its a bolt in job. The hardest part is to re-build the hubs so that they mate with the spindles on the new housing......basically a bearing and race swap so that I can still use the 6 hole polished Alcoa Rims, Regards, Bob
Old 02-13-2019, 08:32 AM   #876
1986 34.5' Airstream 345
Londonderry , New Hampshire
That raises an interesting question: is there a dual speed axle that
will fit my 345 with the standard 454 engine? It would be great
if there were a bolt in gear set for the Dana axle. Does such a
thing exist?
Air345Fly is offline   Reply With Quote
Old 02-13-2019, 03:01 PM   #877
bobmiller1's Avatar
You probably have the same Dana 80 that I have in my 89 325LE. I believe that there were 2 speed tears made for them but I am sure that they are all gone. You might find one in a country bone yard but sure to be used and abused. I lucked out because the Gillis chassis is completely different from the Chevy P32 chassis. What git me thinking about it is that the newer dodge heavy duty pick-up trucks use a Dana 110 rear end housing which is square not round. Regards, Bob
Old 02-19-2019, 03:07 PM   #878
Magnet18's Avatar
Churubusco , Indiana
Finally just finished reading this thread front to back... Feels like I just ran a marathon
Bob, what paint did you use on the roof?
I saw the can of self etching primer, but couldn't make out what the actual white paint was.
Rob
Magnet18 is offline   Reply With Quote
Old 02-19-2019, 07:53 PM   #879
bobmiller1's Avatar
Snap-On white......of Coarse ! Only kidding, will post later, Regards, Bob
Old 02-19-2019, 08:35 PM   #880
Magnet18's Avatar
Only half surprised you didn't stencil "Snap-On" across the roof in 6 foot letters!
Rob
1983 Airstream 310 Class A Motorhome
-Rob
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 26 09-14-2021 06:26 PM
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 07:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 07:19 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 06:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 09:32 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
