07-19-2018, 03:38 PM
#681
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Finally found one $185.00, but try and make one. Now that the dash climate control works as it should, the expense is worth it to me, Regards, Bob
07-22-2018, 05:30 AM
#682
1989 37' Airstream 370
Cleveland
, Georgia
Bob, where did u find the a/c control at. I rerouted my cable as to where it passes through the fire wall and also the angle to releive some tension on the plastic mount and lever for temp
07-22-2018, 05:37 AM
#683
north blenheim
, New York
They are still available, I actually ordered it through my local Ford Dealership even though it is a Chrysler part.
07-22-2018, 10:33 AM
#685
1987 32.5' Airstream 325
dripping springs
When you did the 50 amp conversion I assume you ran additional wiring to the AC switch (rooftop ac’s). If so, were you able to pull through the holes in the wall, or are the wires tied to something? Thanks!
07-24-2018, 06:10 PM
#686
north blenheim
, New York
07-26-2018, 07:48 AM
#687
1982 31' Airstream 310
champaign
I'm in the dark here, as usual  , what are you doing with that kitchen wall? What's the final finish?
07-26-2018, 03:53 PM
#688
north blenheim
, New York
Oh.....you know Mike, something special that I’ve wanted for a while, stay tuned for more pictures......Regards, Bob
07-26-2018, 05:03 PM
#689
champaign
Soooo I didn't realize any of our Classics had plywood behind the vinyl wall covering. At least that's what that looks like. So is the plywood covering aluminum or is the plywood fastened directly to the ribs with no aluminum interior wall covering....at least in that area of the coach? Hmmmmmmmmmm, something new every day. I'm guessing you're going with a cool tile finish or shiny aluminum on that wall........right? Right.
On another note, your new motor. I'm not sure I followed what you posted. So are you going to find a used motor and have it rebuilt to your specs? Or are you buying a new motor and modify it to your specs? Sure wish I lived closer so I could get in the way while you're doing the swap, I would love to witness that process first hand. I'm assuming you're doing the work in your shop there. Hire some teenager to hang out and do nothing but photograph the process as you go along.
07-26-2018, 06:35 PM
#690
north blenheim
, New York
Damm....you're good, indeed, plywood behind the wall paper, then an .040 inner aluminum skin, and you are correct on the finish, but I'm not saying which one...The 7.3 Ford IDI Turbo is going to be a rebuilt engine to my specs including the exhaust brake...the trany guys are writing the software as we speak for the highly modified 4R100 overdrive transmission which will be mated to the 7.3 On a side note I almost had to cut my right pinky finger off this morning....I was snaking wires through the wall and reached in with my pinky to grab the snake wire and got stuck.....an hour later I was free...never again, cell phone has no coverage in the shop and the house is 1/2 mile away......no one would hear me scream anyway so it doesn't matter LOL ! Ask Charly...he can tell you ! Regards, Bob
07-26-2018, 06:37 PM
#691
north blenheim
, New York
07-26-2018, 06:57 PM
#692
Dazed and Confused
Hillsburgh
, Ontario
FREAK-IN ALBINO FEMALE PEACOCK?
Holy crap batman, what are the chances of seeing that in your lifetime. Go out and buy a lottery ticket son.  Very, very cool!
Cheers
Sidekick Tony
07-26-2018, 08:01 PM
#693
1995 36' Classic 36
Ludington
, Michigan
370 LE start to finish.....
Haven’t had time to follow too close. Sounds like a change in plans on the 7.3. That’s a damn nice engine. I almost bought a F250 from my brother in loo to harvest the engine and transmission. Should be a good fit in a box designed for that big block Ford.
07-26-2018, 08:35 PM
#694
1995 36' Classic 36
Ludington
, Michigan
What controller are you using?
07-27-2018, 04:44 AM
#695
1985 32.5' Airstream 325
Lindsay
, Ontario
Bob give up on the Found On Road Dead FORD stuff put in a Cummins 5.9 with an allison 6 speed and be done with it. A real Mans diesel is 6 cyl.
07-27-2018, 05:29 AM
#696
north blenheim
, New York
Hey John.......remember this saying ??? “Never Late With A V8” ???
07-27-2018, 05:39 AM
#697
Churubusco
, Indiana
Why stop at 8?
How about a rare engine for that rare motorhome?
http://thunderv12.com/power
1983 Airstream 310 Class A Motorhome
-Rob
07-27-2018, 06:16 AM
#698
1995 36' Classic 36
Ludington
, Michigan
What prompted abandoning the Detroit swap?
07-27-2018, 11:03 AM
#699
north blenheim
, New York
Dave, to difficult to mount the Detroit into the chassis, accessorieslike the alternator and the AC compressor were to high to fit under the dog house, accessory brackets were and are unobtainium......the 7.3 is a better fit, with the exhaust brake and the 4R100 overdrive transmission, Regards, Bob
07-27-2018, 01:21 PM
#700
Lindsay
, Ontario
Bob I think you meant always late with a v8
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
