Old 06-19-2018, 12:52 PM   #641
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
So.....in between trips I want to get the dash AC 100%.....which required removal of the dashboard....pictures to follow. Ever want to know why there are 4 fan speeds on the climate control but there is only a 3 speed fan resistor ???, now I know why. Well I got the max AC door (vacuum controlled) working again, also repaired the factory AC compressor control, now I don’t need the separate toggle switch and determined that I have in fact hot antifreeze running through the heater core even with the valve in the off position....more on that later. Dash AC should be fully operational this Sunday....want to make sure it’s 100% for the caravan....pictures to follow, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 06-20-2018, 05:07 PM   #642
bobmiller1's Avatar
Some pictures of where I’m at right now.....Click image for larger version
ID:	314651Click image for larger version
ID:	314652Click image for larger version
ID:	314654Click image for larger version
ID:	314655Click image for larger version
ID:	314656Click image for larger version
ID:	314657Click image for larger version
ID:	314658Click image for larger version
Old 06-20-2018, 06:04 PM   #643
1986 34.5' Airstream 345
Londonderry , New Hampshire
I am going through my dash A/C now. The foam on my fresh air door had turned
to dust like yours. I cleaned the old foam off and coated the door with spray
adhesive. Then I covered it with stick on foam door seal that you can get at
Home Depot. I used the black soft foam strip that is 1/4" thick. I hope that it
will last another 30 years.
Pete.
Air345Fly is offline   Reply With Quote
Old 06-21-2018, 05:33 AM   #644
1995 36' Classic 36
Ludington , Michigan
370 LE start to finish.....
The dash air on the my 360 has been little more than a joke. The air box including the evaporator seem to be adequate. The condenser seems to be undersized and inefficient based on constraints of where it’s located.
Richard and Nancy had theirs rebuilt and seem to be satisfied with its performance.
Thinking about replacing the high pressure line from the compressor in the rear with couple 10 foot sections of this heat exchanger tube before the condenser in the front. There a couple areas where they would fit along the frame rails.
In addition to a new pump and drier.
The control system is also problematic. I’d like the get rid of the vacuum servos and control head too. I’ll use a GM electric system like my 2008 Dodge Ram. I’ll look for a junkyard donor. I can also get rid of the vacuum pump system. And the poorly routed push pull cable that has never worked well. To much friction and the ends bend and unhook from the control lever.
Kota is offline   Reply With Quote
Old 06-21-2018, 11:25 AM   #645
I don't think that baseboard heating units or the solder connections would hold
the pressure. The high side pressure of R134a at 100 degrees ambient is over
300 PSI. If you want more cooling you might be better off getting a second
condenser core with a fan and mounting it up under the motorhome. You
don't want it blowing out when it is hot and you need it the most.
Pete.
Old 06-23-2018, 01:17 PM   #646
bobmiller1's Avatar
Dash AC all done, my low side is still higher than I like it so tomorrow I will reclaim the R12, evacuate and recharge, I suspect that I may have some air trapped in the system....pictures to follow. I will be in the Cooperstown area next Saturday through the 4th if anyone wants to stop by.....,Regards, Bob
Old 06-28-2018, 04:47 PM   #647
bobmiller1's Avatar
I finished the dash AC on the 370LE finally 100% and just in time for the heat wave this coming week. While I was doing this work I screwed up the wiring underneath to the alternator voltage regulator......so now that is also completely retired the way it should be.....at an idle with the AC and headlights on I am at 12 volts and the water just pours out of the evaporator box the way it should ! Regards, Bob
Old 06-28-2018, 04:48 PM   #648
bobmiller1's Avatar
ID:	315412Click image for larger version
ID:	315413Click image for larger version
ID:	315414Click image for larger version
ID:	315415Click image for larger version
Old 06-28-2018, 04:51 PM   #649
bobmiller1's Avatar
ID:	315417Click image for larger version
ID:	315418Click image for larger version
ID:	315419Click image for larger version
ID:	315420Click image for larger version
ID:	315421Click image for larger version
Old 06-30-2018, 03:53 PM   #650
bobmiller1's Avatar
In Cooperstown for a few days, it’s got to be damm near 90 right now, can’t wait to see what the next few days bring !Click image for larger version
ID:	315565Click image for larger version
Old 07-01-2018, 04:08 AM   #651
1995 36' Classic 36
Hot here in Traverse City Mich for the past few days. (95 degrees) strong south winds. Looks like that system is headed your way.
Old 07-01-2018, 02:32 PM   #652
bobmiller1's Avatar
So what does one do in 95 degree hear in the shade ? Sit and relax....no, sit and drink beer....no, go inside and watch a movie in the nice AC...no, replace all the window gaskets on the remaining windows....hopefully, I’m a mess.....I need help.....Regards, BobClick image for larger version
ID:	315666Click image for larger version
ID:	315667Click image for larger version
ID:	315668Click image for larger version
ID:	315669Click image for larger version
ID:	315670Click image for larger version
ID:	315671Click image for larger version
ID:	315672Click image for larger version
Old 07-01-2018, 02:53 PM   #653
2007 22' International CCD
Hi, I’m Rich, and I have OCD too!
Old 07-03-2018, 10:30 AM   #654
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Damn BOB! Too dang hot brudda!
mayco is offline   Reply With Quote
Old 07-04-2018, 06:02 PM   #655
bobmiller1's Avatar
Well I finished all the windows with the exception of the front left 2, the couch windows, I ran out of material, can’t figure, will go over my last sodomy invoice from inland rv and check my measurements. Regardless I have to call them and order more on Friday. I spoke with the factory guys at Sea Level tank monitoring systems Monday and have picked out the items I need to update my tank level system. The dash AC works great. I found another 370LE in a garage, it has been sitting for 10 years. The owner is 79 years old. I plan on stopping by to check it out on the way to Jackson Center in August, I’ll be passing right by so it’s worth the stop. I plan on removing the original vent/hood assembly over the winter in addition to removing the stove/oven. I plan on installing the drawer type dishwasher in place of the oven and a custom 2 burner Jenn/aire style in a cutout in the new granite countertop with the addition of a larger kitchen sink.Click image for larger version
ID:	315953Click image for larger version
ID:	315954Click image for larger version
ID:	315955Click image for larger version
ID:	315956Click image for larger version
ID:	315957Click image for larger version
ID:	315958Click image for larger version
Old 07-04-2018, 06:07 PM   #656
bobmiller1's Avatar
I met a couple from Virginia at Cooperstown, they are traveling in a 2012 Eddie Bauer edition.Click image for larger version
ID:	315961Click image for larger version
ID:	315962Click image for larger version
Old 07-06-2018, 05:55 AM   #657
bobmiller1's Avatar
I ordered up the new tank monitoring system yesterday. After measuring the height of the fresh, grey, and black tanks I was able to pick out the correct sensors needed for each tank. The main display panel will be mounted on the kitchen wall near the sink with the optional pump switch to replace the one that is currently in the overhead range power vent. This panel will also have a second switch to replace the auto-fill fresh tank solenoid which is also mounted currently in the same location. A second display panel with no switches be mounted in the toilet room next to the switch panel that I installed for the tank/plumbing heaters. Although the manufacturer states that I can use the existing wiring, I am going to rewrite the entire system to modern specs. Airstream’s original wiring with wire nuts and electrical tape just doesn’t work for me. Regards, Bob
Old 07-10-2018, 02:58 PM   #658
1989 37' Airstream 370
Cleveland , Georgia
Bob,
Can u tell me what wires were the cause of your brake down on the way to Michigan
Thanks ken
Krg22 is offline   Reply With Quote
Old 07-10-2018, 03:15 PM   #659
bobmiller1's Avatar
The wiring going to the ignition coil, get a spare ignition coil cap as well, slides over the ignition coil to make a good contact. Regards, Bob
Old 07-12-2018, 04:32 PM   #660
bobmiller1's Avatar
The new tank monitoring system has arrived ! Since I have a few weeks before the next trip and I have to cut another hole in the kitchen wall, I am going to remove the rest of the “wallpaper” and replace it with a seamless sheet of aluminum .....the same that I used for the door. I am going to remove the instant hot water switch on the wall to neaten things up a bit. I have to pull the wiring out of the oven/range hood and get that all labeled, figure out where I want the new generator start/stop switch. Everything else will probably fall into place......or fall apart. I have already prepped all the tanks including the propane tank for the new sensors and wiring, pictures to follow, Regards, Bob
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 26 09-14-2021 05:26 PM
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 06:19 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 05:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 08:32 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
