Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 06-10-2018, 04:45 PM   #621
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I am finishing up the air reel install tonight....will post some pictures, still trying to locate brackets for the Detroit dieselís AC compressor, power steering pump and alternator, engine mounts and the rest of the hardware I will need for the diesel conversion. Now that I have a firm hold on my never ending lawn growth situation, Iím going to focus on fine tuning the dash AC, repair the speedometer, and try to figure out which rear end I have in the 370LE so that I can do a ring and pinion swap for more speed. I have been in touch with Pennwood....tentative dates for the fall ďGet-Together are either 09/12/18-09/17/18 or 09/19/18-09/24/18. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 06-11-2018, 05:55 AM   #622
1995 36' Classic 36
Ludington , Michigan
The later dates would work best for us but we could make either work.
Kota is offline   Reply With Quote
Old 06-12-2018, 01:53 PM   #623
bobmiller1's Avatar
The air hose reel compartment is 95% done, just a little paint touch up work from taking the reel in and out 23 times before I got it right, 1/4Ē clearance top and bottom. Regards, BobClick image for larger version
ID:	313830Click image for larger version
ID:	313831Click image for larger version
ID:	313832Click image for larger version
ID:	313833Click image for larger version
ID:	313834Click image for larger version
ID:	313835Click image for larger version
Old 06-12-2018, 02:38 PM   #624
2007 22' International CCD
Nicely done! Even a bit of space for a few air hose accessories, like a tire inflater, etc. Maybe a small metal tray with a bit of rubber lining to dampen rattles....?
rmkrum is online now   Reply With Quote
Old 06-12-2018, 06:11 PM   #625
bobmiller1's Avatar
Hell.....I can fit my blow up doll in there as well....,folded up of coarse ! Regards, Bob
Old 06-12-2018, 06:37 PM   #626
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Airielle is her name; doubles as a mattress for the local lake, Arrrgh, now I have a mental picture I won't be able to shake for a while....
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 06-12-2018, 07:18 PM   #627
bobmiller1's Avatar
LOL.....not going there, or possibly we should open a new thread !
Old 06-12-2018, 09:35 PM   #628
Not in THIS set of forums....please!
Old 06-13-2018, 04:03 AM   #629
1995 36' Classic 36
You going to run a compressor on the Detroit or stick with the electric?
Old 06-13-2018, 05:32 AM   #630
bobmiller1's Avatar
Compressor on the Detroit for sure.....keep the electric as a back up !
Old 06-13-2018, 07:22 AM   #631
Is the compressor for the doll?
1975 24' Argosy Motor Home
Old 06-13-2018, 08:17 AM   #632
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
And you've got the air hose handy to blow it up
mayco is offline   Reply With Quote
Old 06-13-2018, 03:12 PM   #633
bobmiller1's Avatar
Correct !
Old 06-15-2018, 05:33 PM   #634
bobmiller1's Avatar
I found the tag on my rear end this morning (the 370LEís.....donít even go there !) it turns out itís a Dana/Spicer about 1/2 the size of the one thatís in my tool truck. Before I head out to Pennwood in August Iím going to do a ring and pinion swap....the book says I have a 5.63:1 in it now and Iím going to throw a set of 4.56 :1 in it...,,if my calculations are correct Iíll get 70 MPH with that set up at 3200 RPM verses the 56 that Iím getting now with the 5.63:1 I donít care if I smoke the tranny cause itís coming out anyway in October. I am also in the process of checking out a 2 speed rear end to mate up with the diesel.....beets the heck out of a gear vendors. Regards, Bob
Old 06-15-2018, 07:45 PM   #635
Dazed and Confused
Isuzusweet's Avatar
Yup, just gave the Airstream Gods some serious ammo. Hope you have Good Sam or RV AAA.
Cheers
Sidekick Tony
Old 06-15-2018, 08:26 PM   #636
bobmiller1's Avatar
Good Sam deluxe plus the fly me to the hospital if I stroke out plan with the return my RV to my house bonus ! Thanks for asking !
Old 06-16-2018, 07:11 AM   #637
1995 36' Classic 36
I drove a dump truck with an Eaton 2 speed years ago. There were a lot of reasons it was a pain in the rear. On a truck with 4 speed and undersized engine that nearly doubled its weight between empty and full it did its job. The newer truck had a bigger engine and a 5 speed. Much nicer to drive. If you were just going to use it as an overdrive in high and a granny for pulling Tony out of the ditch it might be an acceptable option. Iíd really just try to find the differential gearing and an over the road tranny for a similar weight vehicle with that Detroit.
Old 06-16-2018, 08:47 AM   #638
Dazed and Confused
Isuzusweet's Avatar
Don't even joke about stuff like that.......what was his big mistake? He hit the brakes....transfered more weight to the blown wheel, causing it to dig in.
Old 06-16-2018, 11:35 AM   #639
Based on how fast he was passing the other vehicle I'd have to say excessive speed probably had something to do with it as well.
Old 06-16-2018, 01:27 PM   #640
bobmiller1's Avatar
Old video, saw it a couple of years ago....but it shows how fast the do do can hit the fan....my thoughts on the 2 speed rear is in addition to the pinion swap.....I would use low range in the campgrounds and to pull Tony out and use high range on the road....this would give me the best bang for the buck ! And it is a simple job to do ! Iíve got info coming from Dana/Spicer this week as I want to keep my original axle housing to see if the upgrade is possible....will let you all know, Regards, Bob
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 26 09-14-2021 06:26 PM
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 07:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 07:19 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 06:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 09:32 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
