Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 02-25-2018, 05:27 PM   #481
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Finished up the right front Dyna-Mat install, more prep work done on the bathroom wall, installing the dump valve heaters and the tank heaters ( in anticipation of the "Freeze Your Nuts Off Caravan" !!!. Will work in the front left tonight and see how much I finish. Regards, Bob Click image for larger version
ID:	304986Click image for larger version
ID:	304987Click image for larger version
ID:	304988Click image for larger version
bobmiller1 is offline   Reply With Quote
Old 02-25-2018, 09:13 PM   #482
bobmiller1's Avatar
The front left is about 70% finished, I'm done (tired), both tank heaters installed, dump valve heaters installed, waiting on the elbow heaters to be delivered, Regards, BobClick image for larger version
ID:	305008Click image for larger version
ID:	305009Click image for larger version
ID:	305010Click image for larger version
ID:	305011Click image for larger version
ID:	305012Click image for larger version
ID:	305013Click image for larger version
ID:	305014Click image for larger version
ID:	305015Click image for larger version
Old 02-26-2018, 11:26 AM   #483
Magnet18's Avatar
Churubusco , Indiana
Hey Bob,
What valve/tank heaters did you use?
Looked back a few pages and didn't see it mentioned, sorry if I missed it.
Rob
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 03-01-2018, 09:14 AM   #484
bobmiller1's Avatar
I finished up all of the Dyna-Mat install in the front, I like the Dyna-Mat so much I ordered another sheet for the generator enclosure, so I had to remove the under sink cabinet again to get ready for the install, I'm sure it will keep more of the heat out of the inside as well as make it less noisy inside. I am all ready for the carpet padding install on Saturday, It will take me 2 weekends to finish the install of the electric heated floor, then I can have the carpet installed, All of the seats/couch/dinette are all done so they can be installed after the carpet. The shower trap and elbow heaters came so they are installed as well. Central vac should take one more day and still working on the window re-seal job, running new wiring for the electric air horns on the roof as the original wiring is shorted out.....more later, Regards, Bob
Old 03-01-2018, 09:16 AM   #485
bobmiller1's Avatar
ID:	305180Click image for larger version
ID:	305181Click image for larger version
ID:	305182Click image for larger version
ID:	305183Click image for larger version
Old 03-02-2018, 08:18 AM   #486
jkwoodrow
1987 34.5' Airstream 345
Springfield , Ohio
You are doing an awesome job Bob! Everything looks great!
I've never seen or heard of elbow drains. You'll definately be equipped to camp in some extreme cold!
John Woodrow is offline   Reply With Quote
Old 03-03-2018, 06:26 AM   #487
bobmiller1's Avatar
OK, well let's see...it's back in the 20's...got 34" of snow...the power out...and today is the big day for the carpet padding install...well the house has a full stand by Onan Generator that I installed 15 years ago which was running when I got up this morning...but the shop does not have one, soooo..I have to start my Honda 3000UI put it on the loading dock run a 100' extension cord to the corn stove, put a 16' extension ladder up to pull the garage door cord so I can open the door.....damm Charly, maybe I should have bought that other Onan generator we were looking at.....In any event hope to get lots done today, the 5 new mirrors came in to replace the ones with the tape lines on them, the electrical control panel also showed up that I am going to install in the bathroom wall to the right of the medicine cabinet which controls all the heaters for the tanks, elbow, and dump valve heaters. Regards, Bob
Old 03-03-2018, 06:28 AM   #488
bobmiller1's Avatar
ID:	305362Click image for larger version
Old 03-03-2018, 07:45 AM   #489
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Holy cow!
mayco is offline   Reply With Quote
Old 03-03-2018, 09:19 AM   #490
1986 34.5' Airstream 345
Alliance , Ohio
We had 1/4" yesterday morning. Ten miles north of me they had 5-6". Somehow this is another result of 'Climate Change'. Bob you must be the biggest offender.
mehes is offline   Reply With Quote
Old 03-03-2018, 06:18 PM   #491
bobmiller1's Avatar
Yeah, I guess after I acquired all my gas guzzlers I installed solar on the house.....they tell me I save about 35 trees a month .....whatever that means ! Regards, Bob
Old 03-03-2018, 07:03 PM   #492
bobmiller1's Avatar
We finished all the carpet padding today, front cockpit windows all redone, and the first slider right front finished, each slider takes 4 hours from start to finish, I know now cause I have done my fair share of them. Tomorrow I will tackle the electric radiant floor heat install....my carpet guy wants to finish the carpet install next Saturday, I have started to run the wiring for the tank, dump valve and elbow heaters. Regards, Bob
Old 03-03-2018, 07:07 PM   #493
bobmiller1's Avatar
ID:	305476Click image for larger version
ID:	305477Click image for larger version
ID:	305478Click image for larger version
ID:	305479Click image for larger version
ID:	305480Click image for larger version
ID:	305481Click image for larger version
ID:	305482Click image for larger version
ID:	305483Click image for larger version
ID:	305484Click image for larger version
ID:	305485Click image for larger version
Old 03-03-2018, 07:11 PM   #494
bobmiller1's Avatar
Oh, the last picture is a low pressure switch I needed for the low air pressure warning light on the dash...the circuit closes at 38 PSI to complete the ground for the light. Regards. Bob
Old 03-03-2018, 10:20 PM   #495
bobmiller1's Avatar
Enough for today, I just finished about 95% of the wiring for the tank heater install. The custom switching panel with built in circuit breakers will be in installed in the wall cavity to the right of the medicine cabinet. Regards, Bob
Old 03-03-2018, 10:22 PM   #496
bobmiller1's Avatar
ID:	305500Click image for larger version
ID:	305501Click image for larger version
ID:	305502Click image for larger version
Old 03-04-2018, 09:07 AM   #497
mayco's Avatar
Beautiful work bob as usual. The knobs above each switch? Are they rheostats for each switch?
Old 03-04-2018, 05:47 PM   #498
bobmiller1's Avatar
No Mike, push button circuit breakers, finished the front lay out for the floor heat...,,harder than I thought, but what isn't, switch panel roughly installed in bathroom , low air pressure switch installed on tank.....definitely a work in progress , Regards, Bob Click image for larger version
ID:	305572Click image for larger version
ID:	305573Click image for larger version
ID:	305574Click image for larger version
ID:	305575Click image for larger version
ID:	305576Click image for larger version
ID:	305577Click image for larger version
ID:	305578Click image for larger version
ID:	305579 an added benefit of the switch panel is the USB charger, the whole panel is water proof, and if someone's phone dies while they are doing their business they can charge up.....perfect !
Old 03-04-2018, 10:00 PM   #499
bobmiller1's Avatar
The electric radiant heat is 95% done in the living room.....seems to be the story with everything lately.... 95% done not 100%.....I'm being held hostage on the last 5% because I am relying on someone else for information or parts. The front kicked my ass, I hope the bedroom/bathroom isn't as bad. Regards, Bob Click image for larger version
ID:	305600Click image for larger version
Old 03-07-2018, 03:02 PM   #500
bobmiller1's Avatar
The living room is now 100% done, carpeting going in driver/passenger/living room area on Saturday, radiant heat done in 1/2 the bedroom, will try to finish the other 1/2 and bathroom shower area tomorrow morning. All heating tanks/valves/traps/ and elbows done and operational.Click image for larger version
ID:	305877Click image for larger version
ID:	305878Click image for larger version
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 26 09-14-2021 06:26 PM
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 07:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 07:19 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 06:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 09:32 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
