Old 04-16-2017, 09:40 AM   #1
1987 34.5' Airstream 345
northern IL , Illinois
34.5 rear emergency glass repair
Hello everyone. The rear emergency exit glass is in need of replacement only being held up with window tint. Has Anyone had to do this. Looking for some tips of what not to do. Or should I take it to the glass shop. Mo is 34.5 I think it cracked when we put it on the trailer to bring it home. Thanks Hans.
Hans 34.5 is offline   Reply With Quote
Old 04-16-2017, 10:54 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If it is a frame like the trailers use the problem is going to be getting the frame apart. I have done it. The aluminum frame galls to the 2 metal pieces that hold the extrusions together. The frame has to be driven off those 2 pieces straight alone the center line of the frame.
If you get it apart replace with plastic as cutting a glass to the tolerances of the frame is going to be costly. I gave the glass shop the correct dimensions but he insisted on adding an 1/8 in as his ruler was better than mine. The second cutting was on him.
2004 Excursion 4x4
Old 04-16-2017, 12:31 PM   #3
Howie, from what I remember the exit window on the 345s is the same window (rectangular) that is used on the trailers so I would think your instructions would be spot on.
I wonder if Airstream sells the complete hinged window section only, i.e. the part that hinges out in lieu buying the entire window assembly?
Old 04-19-2017, 08:02 AM   #4
Thanks I could not find one. Think I will take it apart and replace it carefully.
Gas line emergency repair. J. Morgan LP Gas, Piping, Tanks & Regulators 51 05-05-2016 12:05 PM
emergency brake repair Bill McNamara Mechanics Corner - Engines, Transmission & More... 9 02-14-2016 12:05 PM
Clipper, Emergency Exit, Land Yacht, Emergency Ladder masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 9 03-05-2015 10:34 PM
replacing windows - glass, lexan, tempered glass? BrianY Windows & Screens 4 07-01-2010 12:08 PM
"Emergency Repair" Forum suggestion Bambi_Bandit Off Topic Forum 1 08-17-2005 10:08 AM
