Old 05-25-2021, 01:42 PM   #1
1984 32.5' Airstream 325
Gainesville , Florida
325 1984... where do I start...
Well... we had a few beers one July evening back last year... started looking at Airstream travel trailers and saw this crazy wonderful 325 for sale on eBay... before we knew it... we were the proud owners of an RV... oops.
We drove down to Orlando to take a look.. too besotted to walk away, paid the cash and after some road checks started driving. To say it needs a ton of work is a (no so) mild understatement. She has the standard 454 with T400 3 Spd transmission. We got 10 miles.... before it over heated and came to a halt. Cooled off... and got another 10 miles (wash, rinse, repeat 2 more times).
After a fun packed afternoon, we managed to get her to Speegles near Deland in FL. They were fabulous - Justin helped us out big time. Long story short, he looked after her for 9 months while he had the cooling system sorted out and fix a bunch of other mechanical stuff.
Drove down last Friday to pick her up, she started up, he'd test driven her a ways, all seemed golden....paid the bills and headed out. Got another 10 miles.
This time, she conked out after some traffic lights, as I was building speed up. After much hair pulling and anxiety tried to start her... and away she went again... go figure. The wife jumped back in the back up car and I eased out again. 15 minutes later, the same thing happened, seemed like fuel starvation but had put in a new fuel pump and cleared the lines. This kept happening (another 4 times), until I tried keeping the revs up as I slowed by manually down-changing... kept the revs up and she kept running.... she seemed ok.... for another 10 miles
Well I heard another odd noise (there where a lot), then noticed the volts had dropped to 0. some time later she started back firing and farting like all hell had broken loose... at least the look on folks in passing cars was an entertainment. That 454 sure makes an impressive bang. Of course, by this time... we were on the Interstate... joy. And that was that... became undriveable and died.
After a $600 quote to tow her the last 11 miles home, thought about the issue some more and looked under the hood. A bust alternator belt... all nicely wrapped around the crank fan. The original seller said the alternator might not be charging (belt was very very loose) - tightened that (at the time). After some more Q&A went and got anther battery... and BOOM (in a good way), away she went.... 11 miles of pillow driving pleasure
So a question for this electrically inclined - do you think the whole issue was a faulty alternator (or coil), possible voltage regulator.. some overload (other) that broke the belt and cause (all) of the stoppages? As the revs dropped it messed with the electrical system all the way to the coil and spake plugs etc. I guess it could still be fuel, but keeping the revs up it was fine, only when I slowed down.
Thoughts would be greatly appreciated -
I'll have a million other Q's - I'll post in the mechanics corner. At least the (supposedly) dead 7kW generator is now running... sweetly I might add. Now I just have to figure out why there's no house, shore or generator power.. and all the breakers (I can find) are okay. Maybe a hidden converter?... fun fun fun... at least we did sign up for it
Thanks -
Pete
ID:	396178   Click image for larger version
Shinytoaster is offline   Reply With Quote
Old 05-26-2021, 06:14 PM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Well, you are in the right place. Welcome, and hang in there.
Now that you have a new battery and presumably a new, snug, alternator belt, how is it? Still 0 volts at the dash?
Do you have ac power inside when on shore power? If so, there is a switch that both the shore power and generator are wired to that should automatically change between the two sources, I would look there.
Waipio Rim is offline   Reply With Quote
Old 05-27-2021, 09:34 AM   #3
Kvsterling's Avatar
West Chester , Ohio
Very cool rig! I think your drive home is the baptism most of us vintage MH owners have experienced...Welcome!!!
The alternator belt issue is common. Make sure the mount is solid (no stripped bolts/holes), the pulleys align (some shimming may be needed), and you have a fresh belt with good tension. A new belt will need re-adjustment after 100-500 miles due to belt stretch. This goes for air conditioner and power steering belts as well. Check the battery isolator as well, they will go bad and mess with voltage/amp draw
Keep sharing, we love seeing these fix em up threads
Kvsterling is offline   Reply With Quote
Old 05-28-2021, 02:04 AM   #4
Thanks - I do feel thoroughly baptized
I’m hoping the alternator was duff and that caused the belt to shred. Hopefully getting that checked this week.
She’s certainly one surprise after another. I’ve spent most of this week trying to get some propane into the tank.. and run. First the old transfer hose wouldn’t work with the new dot tank. Then, I just couldn’t get gas to flow. After pulling most of it apart, discovered the hose between the t- valve and the main regulator was blocked. How weird that was. One end had gone soft and the interior was completely blocked. No exterior signs, other than being soft. Tomorrow’s job is to find out out where to get a replacement.
Once that’s done I’ll know the state of the fridge, stove, hot water heater and heater. They all look rough, hopefully most will still run safely. My guess is not but hopefully. A re-plumb at the appliance site (exterior panels) maybe needed just to feel safer.
Thanks again (all) for your help!
Old 05-28-2021, 03:02 AM   #5
Sag Harbor , New York
Originally Posted by Shinytoaster View Post
Well... we had a few beers one July evening back last year . . .
. . . fun fun fun... at least we did sign up for it
Very cool rig! I think your drive home is the baptism most of us vintage MH owners have experienced . . .
Thanks - I do feel thoroughly baptized . . .
Welcome to the full-scale amusement park Pete! . . . We almost bought a Classic decades ago . . .
Happy Trails,
Peter
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
Old 05-28-2021, 12:44 PM   #6
I just noticed your blog post here:
https://www.airforums.com/forums/blo...5-please-3287/
. . . seeking the manual mentioned in this 2011 post:
[click on orange arrow to go directly to the post]
Thats the Chassis manual... I think he is looking for the Airstream service manual.
Airstream used to have it on their site, but its gone now.
I have a PDF of the 1984/5/6 310, which also covers 345's if that might help.. PM me your email address if anyone wants a copy?
I think Keyair is still active here, and will hopefully see either your blog post, or this post.
Good luck,
Peter
Old 06-13-2021, 06:15 AM   #7
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Here you go
Boom Sounds is offline   Reply With Quote
Old 06-13-2021, 06:18 AM   #8
Service Manuals
1983_Chevrolet_Light_Truck_Service_Manual
http://www.73-87chevytrucks.com/tech...ice_Manual.pdf
1984_Chevrolet_Light_Truck_Service_Manual
1986_Chevrolet_Light_Truck_Service_Manual
1987_Chevrolet_Light_Truck_Service_Manual
Service Bulletins 1990
http://www.73-87chevytrucks.com/tech...Supplement.pdf
UNIT REPAIR MANUALS
Light_Truck_Unit Repair manual 1981
http://www.73-87chevytrucks.com/tech...air_Manual.pdf
Light_Truck_Unit Repair manual 1987
LIGHT DUTY TRUCK – FUEL, EMISSIONS AND DRIVEABILITY MANUALS
Fuel, Emissions and Driveability 1987
http://www.73-87chevytrucks.com/tech...iveability.pdf
WIRING MANUALS
Wiring manual 1983
http://www.73-87chevytrucks.com/tech..._30_and_ST.pdf
Wiring manual 1985
http://www.73-87chevytrucks.com/tech...10_30_Only.pdf
Wiring manual 1986
CRUISE CONTROL MANUALS
http://www.73-87chevytrucks.com/tech...se_Control.pdf
http://www.73-87chevytrucks.com/tech...%20III_opt.pdf
OTHER TRAINING MANUALS
http://www.73-87chevytrucks.com/tech...ng_Booklet.pdf
http://www.73-87chevytrucks.com/tech...20Training.pdf
http://www.73-87chevytrucks.com/tech...ng_Linkage.pdf
http://www.73-87chevytrucks.com/tech..._1977-1983.pdf
http://www.73-87chevytrucks.com/tech..._1973-1980.pdf
MISCELLANEOUS
http://www.73-87chevytrucks.com/tech...nsfer_Case.pdf
Old 06-14-2021, 09:38 AM   #9
1988 34.5' Airstream 345
Clarkston , MI
I think your belt was the issue with all the electrical challenges. Speaking from experience, your trip was very similar to mine. No electricity, no spark from the HEI ignition to light those big 454 pistons. I would not spend a dime more until you sort that out. There is a Serpentine belt conversion you can get that will resolve this issue. My 87 has it. This was a GM upgrade due to this problem in later models.
Propane issue is ... interesting. Keep us up to date on your resolution. We all learn from each other because you are a member of a small club of folks with these wonderful machines. We need to stick together.
Beltran is offline   Reply With Quote
Old 06-22-2021, 11:36 AM   #10
Thanks - you are absolutely right. That's my main concern as it looks as tho' a few folks have tried to fix it and failed.
The shop it was at for 8-9 months repaired the radiator and put new belts on the alternator so that wasn't the initial issue. It conked out 15 minutes into the drive home (or so) and the belt was still on then, broke sometime later. All three batteries were useless so it wouldn't have taken long for them to discharge completely.
The mechanic that did the job said sometime alternators can spin freely without a load on but can become much more restrictive when loaded and break the belt or have weird output. I don't entirely get that but the last people that owned it said it wasn't charging properly (the belt was loose so I thought that was the issue). Anyway, it broke at some point on the way home and eventually came to a grinding halt (with much banging and farting).
My thoughts are similar tho' - I'm quietly hoping the the alternator was faulty and the current generated was sporadic so when she slowed for traffic lights and sat idling for awhile conked out.... when I kept the revs up she was okay. It was so much like fuel starvation, but they replaced the mechanical fuel pump and said delivery was good. I might replace the electrical pump by the tank anyway, but as they say "90% of fuel problems are electrical"... very true
Old 06-23-2021, 07:19 AM   #11
Clarkston , MI
a couple of points. The 3 batteries are not connected together. 2 of them are coach batteries and 1 is for the automotive side. So if that one goes dead because its not being charged properly then your going to lose the engine ignition. It's also driving your fuel pump, lights, blinkers, etc... Mine lasted about 45 min of drive time before it died with similar results.
When your engine is running what does your Altimeter say? Is should read between 13-14Volts if its charging. If its 12 or less your charging circuit isn't active. That should be a clear indication that there is still a problem.
Battery age is a factor as well. But if you have enough to start the engine and a good charging circuit then it should run unless you have lights, fans and a whole bunch of other stuff draining the system. Then a weak battery (one that has been fully drained 3+ times) cannot retain enough charge to function properly.
Also your alternator might be on the way out and perhaps it cannot put out enough power to properly charge. Your dash gauge would be showing you that though.
1988 325 New Start image360 General Motorhome Topics 41 08-17-2018 04:31 PM
1984 Airstream 325 33 - Oregon Luvinmygirl Airstream Classifieds 0 05-06-2018 11:30 PM
1984 Airstream 325 33 - Oregon Luvinmygirl Airstream Classifieds 0 11-16-2017 12:17 AM
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 07:36 AM
