Old 06-03-2020, 05:28 PM   #101
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
I will have to check and see, they run through the metal to the engine area.
cole3444 is offline   Reply With Quote
Old 06-03-2020, 05:40 PM   #102
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
How about a tutorial on how to get the dash cover off? I need to get under mine and could use some help.
Cheers, Dan
~ Margaret Thatcher ~
Old 06-03-2020, 07:14 PM   #103
1971 31' Sovereign
1972 31' Sovereign
I removed my side panels by the seats, took out the screws at the windshield (three broke off), cluster screws, you may have two screws that attach the sides of the dash to the body (my unit did not have them) and remove the glove box, you have some screws at the bottom area of the dash that need removed. I cut my dash at the bottom next to the driver side by the glove box which won't be seen when put back together and removed some rivets around glove box area. Cutting the dash housing allowed me to lift the cover off without removing my cluster. I had two handles that I took off to slide the dash over them and disconnect the vent ducts. If you change out duct for the vents I used four six foot pieces and radiator clamps to hold them in place. It was a lot easier with a helper. Mine was in good shape with six loose wires found and no bad rust under dash. A first for me and big thanks to Kenneth for all the help he gave me. Hope this helps you and others. Holler if you need anything else.
Old 06-03-2020, 10:21 PM   #104
Thanks and yes I probably will be hollering.
Cheers, Dan
Old 06-04-2020, 06:19 AM   #105
1971 31' Sovereign
1972 31' Sovereign
Here are a few pics of screw locations mine had, I apologize I did have two screws on the D/S end that I used a hack saw blade to cut them and where I cut my dash. I did not take pics of the screws at the windshield be careful I snapped three of mine off trying to get loose. I will fill in the cut area with ABS slurry when finished.
ID:	369345   Click image for larger version
Name:	2 screws.jpg
ID:	369347   Click image for larger version
Old 06-18-2020, 07:13 PM   #106
1971 31' Sovereign
1972 31' Sovereign
1983 310 Overhead Lights
Has anyone worked on their interior lights on their 310 that are mounted in the overhead cabinets. I reworked my overhead storage and installed LED bulbs in the lights. When I turn the switch to low on the switch by the door it blew the fuse that feeds the blue wire. Pulled the switch out and the PO had a brown/white wire connected to the bottom terminal on the switch. disconnected B/W wire and the lights work on low but not on high. The lights over the sink work when you turn on high but only three bulbs come on and when you switch to low same thing the other three lights come on. Attached a diagram of the schematic on my switches #20,21,22 and terminals 17,18,19 from my manual and I can't find a resistor that might actuate the high side of the lights and unable to tell where the B/W wire on terminal 17 runs to see what is causing the wire to short out. If anyone knows how the wires go on the switch by the door let me know tired of blowing fuses while troubleshooting. This and the new wiper switch that others have installed is all I like on the inside to complete.
ID:	370680   Click image for larger version
Old 06-19-2020, 11:16 AM   #107
1971 31' Sovereign
1972 31' Sovereign
if anybody knows where the brown/white wire goes to from the light switch by the door let me know.
Old 06-20-2020, 03:18 PM   #108
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Hey Cole. I replaced my interior lights that are built into the cabinets. Not sure I can help with your shorting issues but I was able to inspect how those lights are wired and the “low/high” function. My rig is an ‘82. That switch at the door is an “on/on” sw. It simply activates two different feeds up to the lights, no resistors or anything. One feed goes to the set of “low” bulbs and the other feed goes to the set of high bulbs. The difference in the brightness is merely two different wattage bulbs. One set is a higher wattage than the other set. Pretty simple setup but cumbersome with LOTS of wire used . I made cover panels for where the original lenses were located and then installed LED puck lighting with a remote control dimmer.
If you want pictures I can see what I have. Let me know.
mayco is offline   Reply With Quote
Old 06-20-2020, 04:44 PM   #109
1971 31' Sovereign
1972 31' Sovereign
I would appreciate pics mayco at your convenience, Mine had all the same type bulbs so I just disconnected the Br/W wire that was popping fuses. I installed all new LED bulbs and that helped. Would love to put some updated lights in. Thanks for responding trying to finish up and hope to get to use my 310 soon.
Old 06-20-2020, 05:35 PM   #110
mayco's Avatar
I could only find a few of the finished project Cole. Somewhere I’ve got pics with the lenses all pulled apart and in the middle of changing to its current condition. Click image for larger version
ID:	370801Attachment 1Attachment 1
Those panels that the puck lights are in are just 1/4” luan plywood, covered in headliner type foam and then finished with the same material we used for the couch and other trim pieces. In the kitchen I covered the plywood with aluminum.
Old 06-20-2020, 05:38 PM   #111
mayco's Avatar
Old 06-20-2020, 05:40 PM   #112
mayco's Avatar
For some reason it’s letting post only one pic at a time....
Old 06-20-2020, 06:18 PM   #113
1971 31' Sovereign
1972 31' Sovereign
Like the look of the lights. After I played with ABS slurry and repaired all my cracks the wife decided to have me make luan forms that she covered in leatherette to hide some of the ABS cabinet faces. Your type of design would blend in well with her brown decor. Pic of what she did to ours. Sorry for the sideways pic.
Old 06-25-2020, 05:52 PM   #114
1971 31' Sovereign
1972 31' Sovereign
mayco, I was wondering where you got your TV mount just noticed yours while looking at my post.
Old 06-27-2020, 05:42 PM   #115
mayco's Avatar
I Got that off Amazon. Ceiling or under cabinet mount. I’ll see if I can find a link.
Here ya go,
Mount-It! MI-LCDCM Kitchen Under Cabinet Mount TV Ceiling Mount Folding Bracket, 90 Degree... https://www.amazon.com/dp/B009GKIC8M...sms_tai_KN99Eb...
Old 06-27-2020, 06:59 PM   #116
1971 31' Sovereign
1972 31' Sovereign
Thanks mayco just put it on my wife's Amazon account. It will help keep the tv out of the way.
Old 10-17-2020, 02:44 PM   #117
1971 31' Sovereign
1972 31' Sovereign
Currently working on my belt line trim on the 310 and wanted to ask if anyone came up with a good lubricant that will help the 1/2" belt trim slide around the body and not drag in the grooves as it is pulled. Any help will be appreciated.
Old 10-17-2020, 04:29 PM   #118
Airstream Driver
PeterH-Airstreamer's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
Don't insert and pull, it will shrink badly. If you want to use a lubricant use a foamy glass cleaner. Insert the bottom and then using a dull flat head screw driver to slide in the top. Work a couple feet at a time. Thats the fast way.
Slow is insert bottom and work in the top inches at a time. Always verify that you didn't pull it away from the end cap
1992 350LE Classic Motorhome
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 10-17-2020, 05:57 PM   #119
1971 31' Sovereign
1972 31' Sovereign
Thanks so much, will start that tomorrow.
1983 310 What engine is this? Please Members help! 310 Mechanics Corner - Engines, Transmission & More... 16 09-30-2018 07:16 AM
Rear Airbag Compressor 1983 310 Help Please steveturk Jacks, Stabilizers, Lifting and Leveling 13 03-09-2014 10:49 PM
1983 310 guages Bfrank General Motorhome Topics 6 07-23-2002 05:01 PM
