08-20-2013, 06:09 PM
"Alumi-holic"
1982 31' Airstream 310
Bartlett
1982 Classic with 454 Engine Question
My best friend Dudley has a 1982 Airstream 310 with a chevy 454 engine. Currently his water temperature runs about 218 degrees. Note: in comparison our 310 runs about 180 degrees.
So, here is his question...if he removes the thermostat...will his gas mileage decrease, increase, or remain the same?
Inquiring minds would like to know!
Thank you,
Daniel
08-20-2013, 06:22 PM
2017 30' Classic
Loretto
Removing the thermostat will not improve the mileage if anything it will take longer for the engine to warm up using more gas.
Thermostat ratings are for the lowest temp not highest. In other words a 180 thermostat will allow the engine to run warmer than 180 but not colder.
08-20-2013, 06:26 PM
1991 34' Limited
Wichita
, Kansas
I suspect that his temp should be regulating somewhere between 180 and 200 even with a thermostat installed. I would say that he has one or more of the following problems:
1. Thermostat is sticking partially closed (insufficient coolant flow).
2. Radiator is getting plugged up (inadequate heat exchange in radiator).
3. Fan clutch or shroud are defective (insufficient air through radiator).
4. Temperature indicating system is inaccurate.
5. Coolant level is low (insufficient coolant).
I've tried to list these in the order of most likely to least likely. Low coolant level is really a prime candidate, but I assume that this has already been checked.
It's not a good idea to run an engine without a thermostat except for a short period (like to test the thermostat) but that can be done more easily by sticking the thermostat in a pot of water on the stove with a thermometer in the water. That way you can watch the thermostat open at its approximate design open temp (stamped on the thermostat). If I removed the thermostat and it was very old at all, I'd just stick a new one in it with a new gasket and call it good.
The reason one shouldn't run without a thermostat is that the engine is efficient and runs with the least friction at its design regulated temperature. Running too hot is no good, because it shortens engine life, reduces power, can cause vapor lock in a carbureted engine like this one, can cause detonation, etc.
BTW, I would probably run a 180 degree thermostat in this engine.
Steve
08-20-2013, 06:28 PM
"Cloudsplitter"
2003 25' Classic
Houstatlantavegas
, Malebolgia
Dan,
All things being equal, remain the same.
What advantage removing the 'stat?.....none Check and replace if needed. (stainless, if you can find one)
The quicker the engine warms on a cold start the better.
Back flush & flow check the cooling system.
08-20-2013, 08:02 PM
"Alumi-holic"
Bartlett
All,
Many thanks for your timely responses.
Dudley is concerned as we are planning a 5 day trip next month...
Daniel
08-20-2013, 08:34 PM
1999 34' Excella
Hillsboro
The opening temp should be stamped on the tstat.
Get a pot with enough water to submerge tstat and a candy thermometer.
Heat water to "open" temp. Drop tstat in. Within seconds you should see the tstat valve open. If it doesn't, it's defective.
Use same process to verify NEW one works at stamped value.
If tstat opening at 180 as it should, problem is elsewhere and should be fixed before trip, or... You may mess up motor.
Peace and Blessings..
Channing
WBCCI# 30676
08-20-2013, 09:11 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
In addition to everything noted above, removing the thermostat will actually make the engine run hotter. This because by removing the t-stat you do not allow the coolant to cool through the radiator. With a good, clean system and a 50/50 coolant mixture and the proper pressure cap you should have a 15-20 degree drop in temp from the top hose to the bottom hose. This can easily be checked with an infrared temp gun. BTW are you sure the gauge is accurate?
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
08-20-2013, 09:51 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
It may even run hotter, without a thermostat. Even at wide open the thermostat slows the fluid flow through the radiator allowing better cooling.
If he has an AC it could be trash between the engine radiator and the AC condenser.
Garry
08-20-2013, 10:18 PM
1999 34' Excella
Hillsboro
Check for bad airflow too. Just like Garry says. Saw a pickup that had a mass of straw between radiator and condenser. Nearly no airflow. He had "tried everything". Also found the fan was not working right as the clutch failed.
We replaced with electric fan. Gave better AC function and ten drop if coolant thru the radiator.
Good luck!!!
Channing
WBCCI# 30676
08-22-2013, 02:14 PM
2012 31' Classic
1999 36' Land Yacht Widebody
Andalusia
I believe all of our Classics should be running the 195 degree stat.
08-30-2013, 01:14 PM
"Alumi-holic"
Bartlett
Dudley followed the forum advice and measured the temp with the temp gun...195 degrees. Gauge read 220.
He said he would change the temp sensor first and measure again.
Thanks to all the forum contributors!
08-30-2013, 01:17 PM
1999 34' Excella
Hillsboro
Yeee haw!
Channing
WBCCI# 30676
08-30-2013, 01:39 PM
2000 31' Land Yacht
Central
I changed my sensor got same reading, checked thermostat works, now I know gauge is wrong so don't worry about it, if it moves up then I will know I have problems. lol
