Old 10-25-2016, 10:28 AM   #1
1988 34.5' Airstream 345
San Francisco , California
12V question
Hi,
My son was messing with my 345 yesterday and something is now messed up in my 12V system. I'd appreciate any trouble-shooting help.
Moho starts great. Generator starts great from control panel. When generator is on, roof AC can on. So, 110V system and motor system are fine.
However, my coach batteries were and continue to be switched off (no change). That said, my steps now won't retract ... even if the generator or motor are running. 12V power loss? Further, the control panel is non-responsive (non-lit) with the exception of using the start/stop button for the generator.
I looked at the fuse panel under my oven and couldn't figure out how to tell if a fuse is blown. Do I seriously have to unbolt these things?
Advice?
terry
nums is offline   Reply With Quote
Old 10-25-2016, 10:37 AM   #2
Terry, interesting problem.
I can think of several possibilities but the most likely culprit would be the fuse between the DC fuse panel and the coach batteries. If your setup is like the ones I'm familiar with there should be two large (maybe 3/8" diameter by 1-1/2" long) fuses. Airstream usually installs a fuse on the plus (+) side and also on the negative (-) side so if one of those is blown you will have no power to your DC fuse panel. The fuses would be located near the Univolt and might be hidden by the fuse panel itself.
Typically there is also a selector switch in the battery compartment that allows you to turn off/disconnect the battery feed to the DC panel. However if your DC converter (Univolt) is powered up you should still have DC power at the fuse panel.
I hope this helps.
Old 10-25-2016, 05:06 PM   #3
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
The first place I would start is to ask your son what he was doing.....rather than chasing your tail around at a lot of possibilities or advise. Just Saying....Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 10-25-2016, 05:35 PM   #4
12V question
Unfortunately, my 6 year old son pushed every button reachable on the Moho but can't recall anything...
However, I accessed the univolt and saw that it was plugged into a wall socket... so, I tried it on an extension cord and it powers fine and gives me juice to the dc system. Interior lights, etc work... but not powered step...
Couldn't find any inline fuses on 110 system, near coach batteries or near univolt.
Old 10-25-2016, 05:54 PM   #5
bobmiller1's Avatar
Ahh.....now that we know your son's age, you do have a problem.....a good test light might be your best friend !
Old 10-25-2016, 06:15 PM   #6
1986 34.5' Airstream 345
Alliance , Ohio
I'd start at the battery and work my way to the fuse panel. Did your son mess around in the area of the battery? Mine has an isolation switch which looks very impressive to a six year old.
mehes is offline   Reply With Quote
Old 10-25-2016, 07:36 PM   #7
I also went through the fuses in the glove compartment. They all seem intact.
I think the problem may be related to to the step ... he did announce to me that day that he found the automatic step up/down switch (button on door frame near hinges). So, he probably pushed it 500 times. Perhaps related, the step is now not retracting ... either under motor power, generator power or with univolt properly powering other DC wiring (via 110 extension cord).
I'm comfortable using a multi-meter to measure current ... less so chasing unpowered lines.
I know that the 110 ac is not working ... perhaps I'll backup from there.
order: 1) chase ac wiring to dc to ac converter (univolt is only ac to dc, right?) ... establish that that wiring isn't shorting
2) check dc to ac converter (where do I find that?)
3) chase dc wiring to batteries
Old 10-25-2016, 10:06 PM   #8
oops! no DC to AC converter
instead dc wiring is run in parallel to univolt
troubleshooting that
Old 10-26-2016, 04:18 AM   #9
Sounds like the outlet the univolt plugs into is turned off or tripped. Check to see if all the circuit breakers in your main 120 volt electrical panel are on and not tripped.
I'm not sure where the main 120 volt electrical panel is in your coach but it's usually in the back under a bed somewhere.
Since he was pushing buttons everywhere he might have turned on to many things and once so I'm betting the breaker is tripped due to overload.
Old 11-05-2016, 09:04 PM   #10
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Even with 500 times pushing on that switch for the electric step, switch should be ok. I'd check the step motor before I'd start going too far. Might just be that simple.
Old 11-06-2016, 09:17 PM   #11
gaiaenviro's Avatar
1987 32.5' Airstream 325
dripping springs , Texas
My univolt was on a switch for the outlet. Might check for one down low (mine is right above the floor under the drawers and microwave). Mine has been accidentally turned off enough times that I labeled it (on/off) with a sharpie so I can see it and correct immediately as necessary...
-Bill
gaiaenviro is offline   Reply With Quote
Old 11-06-2016, 09:20 PM   #12
gaiaenviro's Avatar
Also check the magnet on the door for the step switch. I've found mine misaligned and spent hours trying to sort out the step (as I'm trying to leave on a trip), only to discover it's really something simple....
-Bill
Old 01-15-2017, 08:54 AM   #13
jkwoodrow
1987 34.5' Airstream 345
Springfield , Ohio
Check your grounds. There is a 24" strap from the battery drawer to frame and one from the rear of the left engine head to frame. You probably have another issue from what you described but ground issues in our older units cause all kinds of problems.
John Woodrow is offline   Reply With Quote
12v
12V Power Plug in for 12v T.V. Undertaker Electronics & Connectivity 12 09-10-2016 08:53 AM
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
Quick 12v Question Dave-O Electrical - Systems, Generators, Batteries & Solar 8 03-05-2003 03:37 PM
12V question uwe Electrical - Systems, Generators, Batteries & Solar 16 09-05-2002 01:14 PM
