Old 03-20-2017, 07:35 AM   #1
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
12V Feed to Distribution Panel
Please would someone put me out of my misery.
How does the power from the batteries get to the 12v distribution panel? Is it a direct cable from the heavy duty block on the chassis rail behind the battery tray, or, does it go through the blue finned isolator in the front engine compartment and then back to the 12v distribution panel?
thanks
Nick
Boom Sounds is offline   Reply With Quote
Old 03-20-2017, 06:15 PM   #2
1986 34.5' Airstream 345
Alliance , Ohio
The feed to your distribution panel should not pass thru the battery isolator. To put your mind at ease, trace the positive cable from your house battery. You may or may not have a heavy duty kill switch in line with this lead. From there it will most likely go to the block on the chassis rail and then on to your distribution panel. Hope this helps.
mehes is offline   Reply With Quote
Old 03-21-2017, 02:12 AM   #3
Thanks, makes sense. I shall trace that wire and check for any damage when I next get under the coach.
Old 03-21-2017, 03:08 AM   #4
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Depending on how yours is setup, it may also go to the solenoid that bridges the chassis and house batteries during starting, and then go to the batteries from there.
In my 84 270 the converter & fuse panel are under the bunk to the rear of the door. Mine did not come with a cut out switch.
The plus wire goes through the floor and runs along the frame forward to the back of the battery drawer to one lug of that solenoid, the alternator battery isolator and the house battery plus cable ties to that same lug. The chassis battery plus goes to the other solenoid lug.
This page should help some
WayneG is offline   Reply With Quote
12v
Constant 12v feed for composting toilet deserthi Electrical - Systems, Generators, Batteries & Solar 5 12-07-2016 05:04 PM
93 12v interior distribution panel Lumatic Lights - Interior & Exterior 0 05-31-2015 05:09 PM
12v distribution panel mayco Electrical - Systems, Generators, Batteries & Solar 0 07-19-2013 04:48 PM
12V feed for TV rbr Audio, Video & TV 1 04-07-2012 07:54 PM
Fuse/12V Distribution Panel Mike S Batteries, Univolts, Converters & Inverters 5 11-13-2008 10:05 AM
