01-11-2009, 03:08 PM
Richmond
, Kentucky
Unlockable compartment locks
When we got our 74 Argosy Motorhome it included a huge keyring with probably 20 keys. Unfortunately only one of the keys fits the exterior compartment locks and it only opens one of the locks out of about 8.
Any recommended procedure for removing the old locks? I've never drilled a lock out before but that seems to be the only method I can think of to get access to these compartments.
Thanks!
1975 24' Argosy Motor Home
01-11-2009, 03:20 PM
1967 22' Safari
1960 Caravel
Edmonds
Locksmith
A good locksmith can make a key for the lock. Not sure of the cost difference between a locksmith and buying and replacing the locks.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
01-11-2009, 03:27 PM
Richmond
, Kentucky
I really would prefer not to use any of the old locks as they are corroded and rusty. The locks smith would probably be cheaper but I if I use a lock smith I still have to deal with the ugly lock assemblies.
01-11-2009, 03:38 PM
1967 22' Safari
1960 Caravel
Edmonds
I don't know much about Argosys but, most of the lock assembly's I've seen in compartment doors are just cam or leaver type cabinet locks. Like this. Am I close.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
01-11-2009, 03:49 PM
Richmond
, Kentucky
Lee, you're right they are all just the lever type of lock as used on Airstream trailers and Motorhomes.
01-11-2009, 03:59 PM
1967 22' Safari
1960 Caravel
Edmonds
Photos
If your lucky the lock will be exposed and you will be able to remove the nut holding onto it. If your not so lucky you will need to drill enough rivets to pull the old lock out and put a new one in. Make sure you measure the lock they come in different lengths. Search around you should be able to find sets that are keyed alike so you don't have a bunch of keys to keep track of.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
01-11-2009, 04:00 PM
Las Vegas
, Nevada
Brad- I was able to open two of mine with a old, old worn out chevy trunk key and alot of wigglin. Once open the locks were easily replaced, on mine the nuts were exposed.
01-11-2009, 06:26 PM
1977 27' Overlander
Trotwood
, Ohio
If ya take it to the locksmith, he will use a lock pic gun to open all the locks and U then can take them apart with out damaging the skin. Sorry in not closer I'd open them for ya.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
01-11-2009, 07:43 PM
Richmond
, Kentucky
Unfortunately a locksmith is out of the question. The Motorhome is a ways out in the country and is not drivable (yet). Since I plan on replacing the locks anyway it just seems easier to do whatever it takes to remove the locks.
I need to get some of the compartments open now which is why I was wondering about drilling out the locks. None of the locks that I really need to remove are exposed on the back side to where I could access the nuts on the locking ears. In order to remove the gas tank I have to open one of the access covers which hides the fuel tank.
Bill, I've tried using all of the keys that seem to slide into the locks along with lots of WD40 and other fluids with no success. On the keyring there were two keys that were broken off which makes me wonder if those were the keys I really needed . I've also tried all the keys from our 310 Motorhome with no success.
01-11-2009, 07:46 PM
Corona
Brad.
Please post a photo of one of the locks.
We may be able to help you from there, since we have some special keys.
01-11-2009, 08:05 PM
Richmond
, Kentucky
Here are two of the locks in question.
01-12-2009, 10:50 AM
1967 22' Safari
1960 Caravel
Edmonds
Work
Hi Brad, I hope Andy can come up with some sort of key. If not, you will need a good drill and several sharp high speed bits. Start small and centered in the lock and you might be able to drill out the screw holding onto the lock bar. You will have to drill through the lock. You may have to increase the bit size as you go. If nothing else you will eventually remove enough of the lock for it to fail. Be careful not to drill anything on the other side. Good luck!
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
01-12-2009, 11:27 AM
1965 26' Overlander
Newport
, North Carolina
we had to drill out one of the locks on our trailer, we just used a large bit, no bigger than the hole and went at it, it took a little while, but eventually got through and it came out easy. just be careful not to hit the skin on the sides. A new lock for ours was only a few dollars.
,Katie & Anthony, 2kids, lots of pets!
01-12-2009, 09:48 PM
These locks are not strong at all. I have opened them by running a screw into the keyhole and pulling on the screw with a pair of pliers to bend the locking lever and open the door. It's not hard at all. If you plan on replacing them anyway, you don't need to spend the time drilling them out. This is much faster and easier.
Good luck, Rich
01-12-2009, 10:15 PM
Richmond
, Kentucky
Rich, I think I'll try your method first and if that doesn't hack it I'll try dreadydreame's (interesting user name!) method of drilling out the locks.
Thanks!
01-13-2009, 07:42 AM
Corona
Thanks!
We can loan you a key for the rectangular locks.
That key will work, unless the locks were recoded.
01-13-2009, 07:56 AM
1975 31' Sovereign
Searcy
, Arkansas
Brad,
Although I really hope you get into those locks taken care of...I am really excited to find out the treasure that might be inside the compartments...maybe it was a place the PO hid his millions $$$$$$$$! Maybe his gold and sliver!!!! Maybe his fine jewels!!!!
Or?????? Maybe his old sewer hose...hehe!
Please let us know what you find!
Tell Susan Hello!
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
01-13-2009, 08:23 AM
Airstream - Other
Bosque Farms
, New Mexico
You know, those locks are pretty generic. We used to keep a pile of lost keys around here. When people lost keys and couldn't unlock their compartments, we'd pull out the pile and go through. Inevitably, one or another of the keys in the pile would unlock the locks.
Lynn
ACI Big Red Number 21043
01-14-2009, 09:35 AM
Richmond
, Kentucky
Andy, PM has been sent.
Thanks!
01-14-2009, 09:38 AM
Richmond
, Kentucky
Originally Posted by Airhog1
Brad,
Tell Susan Hello!
G
Gene, just so you can be in on the discovery I will gladly mail anything of interest that I find in those compartments to you in a hermetically sealed package...... .
