Old 06-08-2019, 10:33 AM   #1
1977 28' Argosy 28
dexter , New York
Roof leak
I have developed a leak or two, my question is what can I seal the roof with ? I looked at cool kote reflection coating 80. $ for 5 gallons is it the right thing to use?
jonesy 1 is offline   Reply With Quote
Old 06-08-2019, 11:09 AM   #2
Leaks could be coming from various sources. The air conditioner gaskets could need replacing, rivet seams could be leaking or rivets themselves could be loose causing leaks, or any number of places can cause leaks.
Here's one source for the air conditioner gasket.
For the seams and rivets use Captain Tolleys Creeping Crack Cure
Once you get the leaks fixed then coat your roof with paint.
Old 06-09-2019, 07:16 PM   #3
1977 28' Argosy 28
dexter , New York
I found the leak . There is an old antenna wire on the roof . Now only one left in the front over windshield it looks like it runs down the center metal square tube , now can it be marker lights or gasket around the windshield?
Old 06-10-2019, 05:17 AM   #4
A leak up front like you're describing could come from the front marker lights or the windshield gasket.
Here's a link to my thread where I sealed the windshield gasket on my Argosy.
Anyone use liquid roof for fiberglass roof repair? 442 john Airstream Motorhome Forums 4 01-02-2013 01:23 PM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
