Old 07-27-2020, 07:40 PM   #1
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
Replacing the Fuel Tank
Has anybody replaced their tank with a new one? I know mine has been sitting for more than a decade filled with ethanol laced fuel. The fuel in the line was deep red (and the line from the tank is completely blocked). I'm assuming the inside of my tank is mostly rust. It seems odd that they built these bodies out of aluminum, then used steel for the tank.
I think I'll need to drop the tank, regardless, so thinking about just replacing it with a new aluminum tank.
Whad'yathink?
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 07-27-2020, 07:53 PM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Bella has a new, custom built, approx ten gallon larger tank.
Make sure they install baffles, but also you should take the opportunity to fit a new sender/pick-up as later models had a slightly different mounting diameter and there is no mount having something built to only take an obsolete original part.
martin300662 is offline   Reply With Quote
Old 07-28-2020, 03:45 PM   #3
kidjedi's Avatar
1972 25' Tradewind
1975 24' Argosy 24
Denver , Colorado
Cool. Thanks for the info.! I also plan on adding an in-tank fuel pump.
BeahmStream.com
Old 07-28-2020, 03:56 PM   #4
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Why? Are you fitting EFI? External pump is much easier to change if it fails and if keeping the carb, has plenty of pressure.
I am a firm believer in 'keep it simple, stupid' (KISS) so why add complication with no added value?
Old 07-28-2020, 04:00 PM   #5
kidjedi's Avatar
1972 25' Tradewind
1975 24' Argosy 24
Denver , Colorado
EFI may happen at some point in the future.
If the tank is already down, there's no reason (other than a couple bucks) not to install the pump. As long as you install a unit that allows free flow in case of failure, it shouldn't have any negative potential.
I've got the Carter installed now, and it works great, but I still plan on installing an in-tank anyway.
BeahmStream.com
Old 07-28-2020, 04:36 PM   #6
Like Martin I opted to not go with an intank fuel pump when I converted over to TBI on my Argosy. My reasoning was the thought of having to drop the fuel tank on the side of the road to replace the pump didn't seem like a fun ordeal. I've had my share of roadside repairs and my preference is to keep them to a minimum
Instead I went with the Carter P4070 as a low pressure suction pump that feeds a 1/2 gallon surge tank. I have a high pressure frame rail mounted pump that sucks from the bottom of the surge tank and feeds the throttle body.
I figured the lesser of two evils was carrying about $125 in spare fuel pumps that I can replace anywhere. I got the idea for the surge tank from Peter's old 310. His coach had an aftermarket efi and used a surge tank as well.
Old 07-28-2020, 06:07 PM   #7
kidjedi's Avatar
1972 25' Tradewind
1975 24' Argosy 24
Denver , Colorado
Yeah. I guess my thought is: the in-tank is the "best" place for a fuel pump (according to... everyone), and then if that in-tank unit ever fails, I will go back to the Carter P4070 already installed in the line (which also has a 100% flow through rate even when not powered). Most decent in-tank fuel pumps have 100% flow if they stop pumping, so it's not detrimental to just leave a non-functioning pump where it is. Am I wrong on this?
BeahmStream.com
Old 07-31-2020, 08:43 PM   #8
Airstream Driver
PeterH-Airstreamer's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
Only draw back I can think off is a clogged up filter at the bottom of the old pump. Moving to an external Carter also includes external accessible fuel filters.
1992 350LE Classic Motorhome
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Low Fuel Warning light ON when Fuel Tank is Full, Not Empty??? Michael_Wild Mechanics Corner - Engines, Transmission & More... 1 07-06-2018 11:26 AM
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Fuel Line & Fuel Tank crazeevw Mechanics Corner - Engines, Transmission & More... 4 12-02-2011 07:38 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
