Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 04-23-2020, 01:27 PM   #1
1977 24' Argosy 24
North Port , Florida
Images: 8
Power Steering Pump Replacement Help, '77 24' MH
Can anyone give me step by step instructions on how to remove the power steering pump? Thank you in advance - will share the info with The Mechanic of the Motorhome.
Elisa is offline   Reply With Quote
Old 04-23-2020, 02:02 PM   #2
You can start by reading about my replacement of Peanut's power steering pump.
You don't have to remove the radiator but it sure makes it easier. If the radiator is still in place the mechanic will need to work from the top of the doghouse, from the inside the driver wheel well and probably a little from underneath.
While he is in there make sure he replaces the power steering pressure hose, assuming he can find one.
1975 24' Argosy Motor Home
Need Power steering pump help! dgmelp Mechanics Corner - Engines, Transmission & More... 6 07-20-2013 09:49 PM
Removing power steering pump Aldo Mechanics Corner - Engines, Transmission & More... 9 02-23-2013 06:15 PM
Power steering pump failed after steer safe installation. LandYacht33 Mechanics Corner - Engines, Transmission & More... 4 10-09-2011 07:56 PM
Steering Stabilizer Replacement Help 911rs Argosy Motorhomes 8 08-20-2007 03:15 PM
