Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 09-21-2019, 07:52 AM   #21
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by ShandyLane View Post
Hello Cliff, congrats on your Argosy 28 MH! I don’t feel so bad about my purchase, now! Mine is exactly the same as yours. PO had started a reno and then stopped. As they started with the bathroom, i would like to move it to the center to create a back bedroom. My question is: is it possible to replace only the damaged portions of the sub floor or is a shell off necessary.? I can’t seem to find a thread on a shell off on an airstream MH. Thank you!
Take a look at Bella's thread...
martin300662 is offline   Reply With Quote
Old 09-22-2019, 09:49 AM   #22
1976 Argosy 20
1977 28' Argosy 28
Napa , California
Attachment 352641
Hello Martin, i found Bella’s thread after i wrote my above post. Thank you! I must say there is never a dull moment in Bella’s life, or yours!! Great job! I am hoping that i do not have to fo a shell off...i am now waiting for delivery of the MH, will keep you guys posted! Such a wealth of info here! I have a 1976 argosy minuet which i love and have now been bitten by the Argosy bug!!!!
Ciao a tutti!
ShandyLane is offline   Reply With Quote
Old 09-22-2019, 09:53 AM   #23
1976 Argosy 20
1977 28' Argosy 28
Napa , California
Originally Posted by cliffcharb View Post
No need to remove more than required. You just need access to the bolts and screws going through the channel. I was able to remove the rivets out of the lower walls and pull them out of the way to access.
Cliff, thank you very much, i just drew a sigh of relief...however if there are evident signs of water infiltration we will take it from there.
Ciao!
Old 09-30-2019, 05:06 PM   #24
2021 16' Bambi
2021 22' Bambi
North Port , Florida
A little bit more progress. Step and fridge area repaired. Currently building platform for the new fridge to sit on
cliffcharb is offline   Reply With Quote
Old 09-30-2019, 05:10 PM   #25
2021 16' Bambi
2021 22' Bambi
Can anyone tell me where the main wiring runs through the coach. I have a direct short on circuit 1, purple wire. Does it run along the roof?
Old 10-01-2019, 03:37 AM   #26
Yes, there is a main bundle that runs down the center of the roof and branches off as needed to various locations.
There are rivets holding the center panel in place but once the rivets are removed you pull down on the center of the panel at one end and work your way to the other end. Best to have at least two people involved when performing this task.
1975 24' Argosy Motor Home
Old 10-05-2019, 04:15 PM   #27
2021 16' Bambi
2021 22' Bambi
New Argosy 28 Owner
ID:	353636Click image for larger version
ID:	353637Click image for larger version
Now to cut and install original door inserts. Should fit in nicely.
Old 10-06-2019, 08:41 AM   #28
Attachment 353636Attachment 353637Attachment 353638
Looks good
As a suggestion you might consider coating the wood with a good quality spar varnish. That will help keep it from rotting away, especially since it is open to the outside through the fridge louvers.
Old 10-07-2019, 07:00 AM   #29
2021 16' Bambi
2021 22' Bambi
New Argosy 28 Owner
Don’t mind the construction mess.
Also installed the replacement exhaust fan in the bathroom. Had shipped all the way from Australia. Almost identical from the original Dometic GY 11.
Old 10-09-2019, 03:21 PM   #30
1976 Argosy 20
1977 28' Argosy 28
Napa , California
Hi,
I am also following this thread. Is your rear bedroom original or did you modify the layout? I am asking because i want to move my mid twins to the rear and the bathroom to the middle. Is yours a 28ft? Would you mind posting photos of the interior?
Thanks very much!!
Old 10-10-2019, 06:54 AM   #31
2021 16' Bambi
2021 22' Bambi
Hi,
Thanks very much!!
Mine is a rear bath, mid twins. Click image for larger version
Old 10-11-2019, 05:32 PM   #32
1976 Argosy 20
1977 28' Argosy 28
Napa , California
Gotcha! I had understood it to be a rear bed. Thanks! Your looks like mine, only mine is torn apart lol!
Old 10-20-2019, 12:34 PM   #33
2021 16' Bambi
2021 22' Bambi
Another piece of the puzzle repaired.
ID:	354589Click image for larger version
Now on to either repairing the original AC or replacing.
Old 10-20-2019, 12:36 PM   #34
2021 16' Bambi
2021 22' Bambi
Another question for owners of these fine coaches. Since the original carpet has been removed the wife and I are deciding on replacing again with carpet or a vinyl flooring. For those that replaced with vinyl flooring was the noise level increased while traveling?
Old 10-21-2019, 04:01 PM   #35
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
WHAT WAS THAT! WHAT NOISE?[emoji23]
Trust me, you're not going to notice a noticeable difference. My personal opinion is to go with LVP, or LVT. Easily replaced if damaged, extremely durable, easy to clean, and will not mold.
Cheers
Sidekick Tony
Old 11-02-2019, 02:17 PM   #36
2021 16' Bambi
2021 22' Bambi
Those with a 77 28’ would you mind telling me what the 4 switches at the door control? My top switch leads to the lights above the couch and dinette but nothing else seems to do anything.
Old 11-02-2019, 02:50 PM   #37
Dazed and Confused
Isuzusweet's Avatar
One should control the one section of interior lights; one maybe controls another section of interior lights around the kitchen area; one should be your outside light; the last one has me befuddled.
Cheers
Sidekick Tony
Old 11-03-2019, 11:55 AM   #38
1977 20' Argosy 20
Arlington , Texas
The four switches by the door on my 77 20’ are:
1. Top turns on the brighter set of lights over the dinette.
2. Second from the top turns on the dimmer set of light over the dinette.
3. Third from the top turns on the “scare” or bright light on the outside beside the door.
4. Fourth from the top turns on the “porch” light above door on the outside.
GWallace is offline   Reply With Quote
Old 11-03-2019, 04:15 PM   #39
2021 16' Bambi
2021 22' Bambi
This non stop Florida heat must be getting to me, I totally forgot about the outside lights.
On a side note my new fridge is throwing an error code. Of course it’s an error that requires you to see “your authorized dealer”
Old 11-17-2019, 03:14 PM   #40
2021 16' Bambi
2021 22' Bambi
A bit more progress over the last few weeks. Fridge control board was replaced, tech thought the original converter was the culprit but covered it under warranty anyways. Just to be safe I went ahead and replaced it. Lights and fans do run a lot brighter and quicker now. So even though it was putting out the correct volts I’m thinking there wasn’t any amperage behind it.
The cockpit was put back together with new insulation, now hunting for a brown automotive carpet to finish it off.
Got the generator running with a new facet pump. I might need to replace the isolators, cause it rumbles the coach like I’m in a train. Haha
new owner of used Airstream 2015 Bambi 22FB Owner -- need help Scran Member Introductions 11 10-03-2017 12:35 PM
New Argosy Owner and new to the forums bolingball12 All Argosy Trailers 10 11-18-2010 06:14 PM
NEW OWNER of One Owner 1972 Ambassador 29 foot Mrwaterway Member Introductions 11 11-20-2009 12:53 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
A new Argosy owner GOTPIKE All Argosy Trailers 28 11-29-2002 11:09 AM
