Old 07-09-2021, 02:37 PM   #1
1974 24' Argosy 24
Anaheim , California
Unhappy Need advice: Argosy Motorhome needs motor?
My 1974 24í Argosy Motorhome may need a new motor and transmission. Itís been broken down along the road for over a month. During that time itís had a lower radiator hose, 2 alternator belts, a thermostat, fuel line repair, and head gasket. Now itís eating oil and Iíve been told the O rings are bad, so a new motor is needed. I already knew a transmission was on the horizon. Iím in Eureka, Ca area, with not a lot of mechanics capable of doing the work- and Iím not even sure if its worth it to do. Any advice would be much appreciated.
Also, is a crate motor a rebuilt motor now? Merits of that vs a regular rebuilt?
lost.again is offline   Reply With Quote
Old 07-09-2021, 03:47 PM   #2
2019 25' Flying Cloud
Hendersonville , North Carolina
Engine Repalcement
Your a perfect situation for the install of a "Jasper Engine and Transmission". Jasper is a high quality remanufacturer of engines and transmissions. Located in Jasper, Indiana they are available nationally. Contact them and they will direct you to the closest authorized installer. I have used several of these throughout the years and have been very well satisfied. Great warranty but I never had to use it. Question is how much $$$$$ do you want to spend? Quality is not cheap. Having to do the job twice because of inferior product is even more expensive. Your looking at a substantial investment to "Do It Right".
uraljohn is offline   Reply With Quote
Old 07-09-2021, 04:54 PM   #3
You'll get lots of advice on engines and transmissions so I won't say much along those lines. Since your's is a 74 you'll find removing the motor is going to be a challenge. There are two ways to do it, one is out the front and the other is out the bottom.
Pulling from the front is the typical approach and unfortunately in the case of 74-76 Argosies also the most difficult. The entire plastic front grill will need to be removed and it's held in with rivets, LOTs of rivets. Once you get the front grille remove there will be an aluminum structural cross member that you'll need to cut out as well.
Next comes the radiator, transmission cooler, and AC condenser. After that it's just a matter of unhooking all of the misc items and pulling the motor. There are several threads on how to pull a motor out the front for you to review as well.
The other option os to remove the motor from the bottom. This entails remvoing the entire front suspension so whoever does the work will need a lift that allows them to remove the front suspension. In many ways this will likely be the easiest approach although it may not seem like it at first. In my thread I show the whole front suspension being removed and re-installed. However I did not remove the engine out the bottom, mine came out and back in through the front. The transmission is dropped out the bottom.
The 24' Argosy chassis may be different than the 20' Argosy chassis but you may find removing the rear transmission mount to be a challenge. The bolts that hold it in place are not accessible due to the floor structure sitting right on top of the bolts. A good automotive shop should be able to deal with the problem but it is a pain if nothing else.
Regardless of which method you choose you'll find it's going to be a chore and probably a fairly expensive one at that.
Good luck.
1975 24' Argosy Motor Home
Old 07-10-2021, 08:32 PM   #4
Stolyolyo
2003 22' International CCD
2004 18' Westphalia
Olympia , Washington
Argosy 24 still sound mechanically
Check out classified for '78 Argosy 24 gutted by fire Underpins are good.
stoliolio is offline   Reply With Quote
Old 07-11-2021, 01:16 AM   #5
Sag Harbor , New York
Thumbs up
Originally Posted by bkahler View Post
. . . you'll find removing the motor is going to be a challenge. There are two ways to do it, one is out the front and the other is out the bottom.
Thank you for your expert advice . . . all over the place . . . invaluable IMO.
Peter
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
Old 07-23-2021, 07:47 PM   #6
1974 24' Argosy 24
Thank you for your response. I finally found a repair shop in Eureka who said they could do the work, and there did propose a Jasper engine and transmission. Unfortunately, the price of the engine, tranny, and radiator was quoted to start at $17,500 lowest and more probably in the $22M to $25M range. It’s not feasible to me. I’m going to sell it and hope to find someone who is capable of doing the work themselves or wanting to part it out.
Old 07-23-2021, 07:53 PM   #7
1974 24' Argosy 24
Thanks for responding to my post. I’ve been working up in the California Redwoods with no internet for the last month, so I’m slow to respond. I finally got a quote for the work. It was from $17,500 to $25M.... which laid me low immediately.
I actually had the owner read your post to get an idea of how to go about it. As he read, he got paler and paler... i think he doubled the price in his mind. Haha. But I’d rather have reality up front rather than in the middle of the job. You did a kindness for me there. Thank you.
Old 07-23-2021, 09:21 PM   #8
1974 24' Argosy 24
So the general option among mechanics seems to be: its a tough job and I don’t want to do it! Maybe an argosy trailer instead of a motorhome!
Thanks for your comment!
Old 07-24-2021, 12:33 AM   #9
1960 22' Safari
in the wilderness , The great Mojave Desert
I think you should get more quotes.
Check out GM crate motors. New factory engines with warranties.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 07-24-2021, 02:49 AM   #10
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by lost.again View Post
So the general option among mechanics seems to be: its a tough job and I donít want to do it! Maybe an argosy trailer instead of a motorhome!
You will find this is a general theme if you go the motorhome route.
Yes they are built of a standard platform, yes the majority of the parts are readily available and common with other light trucks, but the addition of the motorhome structure and electrics in general massively impacts. This ranges from simply being in the way (the motorhome body was not designed to facility access to engine/cooling/brakes/etc/etc and the floor/frame laid over the chassis preventing access to things like crossmember/mounting bolts) through to chassis components being modified/different versions for the specific application.
This means commercial shops see working on these units as being 1) more time consuming, 2) more complicated, and simply 1) + 2) means it doesn't fit a rapid in/out commercial operation.
In general if it takes 2 or 3 times longer it will cost 2 or 3 times more and commercial shops don't see this as viable - you are just occupying their bay when they could be working on something else.
martin300662 is online now   Reply With Quote
1942 Chevy Panel truck as TV, Need real advice on Motor, rear etc frockman Tow Vehicles 17 06-16-2012 05:23 PM
Looking at Argosy Motorhome, need advice! 990rick Argosy Motorhomes 5 12-10-2010 11:39 PM
'76 Argosy by Airstream Motorhome 28 ft RV Motor Home eBay Watch Airstreams on eBay 0 06-07-2009 10:10 PM
1983 Excella's power system needs help and I need advice mudfish Batteries, Univolts, Converters & Inverters 1 05-31-2009 12:33 AM
Motorhome owner wannabe needs advice sailhighc Member Introductions 3 09-02-2006 05:36 PM
