Originally Posted by Snowturtle
None of the gauges work in the Central Control Panel of my '74 Argosy 20. The gauge lights work (except the red water pump power light), the water pump switch & generator switch both work, the hood fan works, but all of the gauges register zero. I have been living in the Argosy and have it plugged in full time and hadn't realized that my Univolt battery is bad, only has about 4 volts - could that be the problem? I assumed that the Univolt system didn't matter when the RV is plugged in, maybe that's wrong?
Thanks.
Do you have a copy of the 74 Argosy Owners manual? In the manual there is a copy of how the wiring is laid out for the control panel. If you don't have a copy I can scan the wiring diagram and post it here.
If your coach still has the original univolt installed I would highly recommend replacing it with a
Progressive Dynamics 9645 power supply. The old univolts are notorious for over charging batteries which ruins them. The Progressive Dynamics are really good at maintaining a proper battery charge.
Since you are continuously plugged into shore power then your univolt was constantly charging the battery which I'm sure is what caused it to go bad.
I don't know that the univolt/battery issue is what's causing your control panel issues but getting the
12 volt system in order would be a good start.
