Old 08-22-2022, 07:55 AM   #661
GREEN ARGOSY's Avatar
1977 20' Argosy 20
Matsubushi , Saitama
High volume water pump and high output alternator were installed on my engine. I believe that the word of HIGH will always be better!
In Japan, we have high ambient temperature and humidity in summer, it makes high engine, water and fluid temp easily when in a traffic jam. Also human temp (I meant the driver's and passengers' temperature) rises easily as well. Therefore cooling systems are very important.
And I'm going to go with lots of electrical stuffs, those are an electrical cooling fans, electrical fuel pump, ignition box, EFI system, transmission controller, air conditioner, car audio and more. So I need a high output alternator and large capacity battery.
I made an AC condenser fan brackets before. But the brackets are blocking cores, I think it will affect cooling efficiency due to less air flow. The cooling system is a critical stuff, I want to get the maximum potential as possible. So I decided to redo it.
I made a lot of small holed on the bracket.
Then expanded the small holes with a hole saw.
It looks something like a custom made stuff, I like this drilled out style!
I'm going to put back the condenser to a radiator then attempt trial fitment it to the Argosy this weekend. I need to check AC hoses, heater hoses and air intake pipe routing with installed the massive radiator.
GREEN ARGOSY is offline   Reply With Quote
Old 08-29-2022, 08:04 AM   #662
1977 20' Argosy 20
It's time to install SuperSteer bell cranks on my Argosy. I got those bell cranks in 2019 so it slept in my garage for 3 years. Actually, their shaft is getting a little bit rusty..
It's easy to install, just replace the original one.
And I replaced tie rod end boots. Yes, I know. A tie rod end is an expendable part, it needs to be replaced. But it needs adjusting a wheel alignment when after replacement. I don't want to do that at this moment, therefore I decided to reuse the old ones. I'll replace my tie rods some day.
The new boots have different shapes as the old ones. However, it seems all right.
The bell crank looks very nice! I think should have chosen blue-ish airbag in order to harmonize the color.
Old 09-25-2022, 07:55 AM   #663
1977 20' Argosy 20
It's time to check an intake duct hose and air conditioner hoses routing with installed the radiator and AC condenser.
There was gap between the radiator and fan shroud so I filled with an aluminum angle and EPDM sponge rubber before installed the radiator.
All of engine maintenance covers are removed,it can be easy to access all stuff now.
I found the only one route for through the air intake duct hose. But there is very close an alternator pulley, so I have to securely fix the duct hose. I'm still thinking about which to use flexible hose or an aluminum pipe. The flexible hose can be routed easily but I think the hard pipe can be securely fixed than the flexible. I don't want to contact the pulley with an air intake.
Next, an air conditioner needs to connect two of refrigerant hoses and two of heater hoses and those need to go through a firewall. I'm going to use bulkhead fittings like this.
Today, I made new heater lines until the bulkhead, so I'm going to hook it up with new air conditioner unit. Then I make refrigerant lines after installed a compressor.
In addition to make engine oil cooler, transmission fluid cooler, power steering and fuel lines in the near future!
Old 09-26-2022, 05:35 AM   #664
chevy2man's Avatar
2024 Atlas
Jeffersonville , Alabama
Very nice looking work there Yuki! Can’t wait to see the finished coach!
chevy2man is offline   Reply With Quote
Old 09-26-2022, 08:46 PM   #665
1977 20' Argosy 20
Thank you!!
I have been working on my coach for years, but there are still a bunch of tasks left to be finished! It's still going on...
I also looking forward to seeing your project updates!
Old 09-27-2022, 01:04 PM   #666
Yuki, your craftsmanship is outstanding
For the intake duct hose by the alternator pulley I think you'll be happier with hard pipe over flex in that area. Yes it will be more difficult to accomplish but you won't regret the decision in the long run.
1975 24' Argosy Motor Home
Old 09-29-2022, 05:14 AM   #667
1977 20' Argosy 20
Thank you!!
Yes, to use hard pipe would be better in that place. I will get aluminum hard pipe and rubber joints soon. Actually, I don't want to buy any stuff from the USA due to very depreciation of the JPY currently.. But I need a few auto-parts for my coach before running the motor.
Old 10-02-2022, 08:45 AM   #668
1977 20' Argosy 20
At first, I had thought to install a heater valve in the cabin because it's easy wiring connection but I installed it in the engine bay finally. If the heater valve is installed in the cabin, hot water always come into the cabin when the engine is running, it would heat a foot area even though the heater is off. Anyway, I don't need that foot warmer in summer!
Next, installed a brake back plate.
Then installed a parking brake cable before installing brake shoes. Of cource I use brand new cable.
I needed more hands when installing the shoes but I couludn't. So I used some clamps for holding the brake stuff. It worked pretty well.
Before and after.
I'm going to install intermediate and front parking brake cables and brake lines next weekend. However, new brake proportioning valve is missing. I should find it in the messing my garage.
Old 10-10-2022, 08:11 AM   #669
1977 20' Argosy 20
It's time to install a front parking brake cable. I bought two cables. The first one was shorter than the original, so I bought other cable.
This one is same length as the original. This is what I wanted!
The new cable doesn't come with a clamp, I reuse exist one.
The original cable routing was close to headers, but I want to keep away from heat source as possible. I'm going to think about it after installing other compornents something like a brake master cylinder, hydro boost and steering gearbox.
The brake proportioning valve was found in my messy garage.
I already made brake lines, it needs just installng.
The all of stuff were installed!
I'm going to install remaining brake parts next time. To be continued..
Old 04-06-2023, 06:59 AM   #670
Yuki, here are a few pictures of my Cushman Truckster. It is a 1994 1-ton flatbed powered by an OMC 22 hp engine.
Picture taken just after I got it running for first time. The flatbed is 120 cm wide and 182 cm long. It makes for a great portable workbench or platform.
With cab attached and now in daily use.
The flatbed is handy for lots of things, including hauling tree limbs to the burn pile.
I think you need a Cushman for yourself
Thanks for the help!
Old 04-07-2023, 08:16 AM   #671
1977 20' Argosy 20
Attachment 429864
Attachment 429865
Attachment 429866
Thank you for sharing pictures of your Cushman!
It is bigger and longer than I expected. Also its loading capacity is two times more than my Datsun truck, and three times more than Japanese mini truck (Kei truck)!
This is my Datsun and my GL1000.
This is a kei truck and ex-my Yamaha XS750 (It was stolen )
Anyway, now, I want a Cushman!
Old 04-07-2023, 03:52 PM   #672
Attachment 429926
That little Datsun is definitely loaded down!!
The Goldwing would be 60 cm to long for my Cushman.
Attachment 429927
Wow that sucks
The Kei truck is similar to the ones we used on Johnston Atoll when I was working there on the island. I don't believe they are street legal here in the USA.
Somehow that doesn't surprise me
Old 04-08-2023, 07:03 AM   #673
1977 20' Argosy 20
Yes, the Goldwing was too longer for loading on my Datsun. The Datsun has only 6' 5" long on the bed. In addition its cab was extended backward by me, so the bed is shorter than the original. I'm not going to load the Goldwing again.
That's nice! The Kei truck is very useful vehicle. It is very popular especially in the countryside. I've heard kei trucks are used on private properties in the USA.
Old 04-10-2023, 07:53 AM   #674
I'm impressed with the cab extension. That's not an easy task. Please post a picture or two showing it in more detail.
A lot of business use them as well as private individuals. I believe the cheap Chinese knockoffs are becoming more popular due their cheap price
Old 04-11-2023, 09:16 AM   #675
1977 20' Argosy 20
I've modified the cab twice on my Datsun. The reason why I extended the cab was too tight space in the cabin due to the change seats. The original seats were very thin and plain ones, but I prefer to classical or old style ones so I replaced leather seats which were detached a Nissan Figaro.
However, it is very thicker than the original and the backlest was like vertical angle! Therefore, I decided to modify the cab.
There wasn't any modification except replaced wheels in this picture.
My Datsun was able to load a 750cc motorcycle without unlocked the tailgate.
I was able to extend the cab more. But the most important thing was this is a truck. I often load something long stuffs on this truck, for example, plywood panels are about 6' long, hence I wanted to keep 6' long on the bed. So I decided to tilt the back of the cabin.
It's very simple, it need cutting, welding and just action!
Here is the first stage of extended cab mods.
I was able to load a Yamaha YZ125 on the bed without unlocked the tailgate. Yes, I know, it seems like this motorcycle is too big for my truck.
Old 04-11-2023, 09:48 AM   #676
1977 20' Argosy 20
Here is the second stage of extended cab mods.
I got a sliding windw from the USA. The seller said that this is a sliding window for a Subaru Brat. I don't have any ideas about this, however, I never mind that. And I bought a back door of a Mitsubishi from a junkyard.
I cut the back door and metal sheets then welded together.
There is not much extended to backward, but the shape is changed.
Then I applied body filler and sanded it.
I painted bed liner paint on the cabin. It's a wannabe vinyl tops!
My small truck fits perfectly with small Honda.
Old 04-11-2023, 01:07 PM   #677
Yuki,
You must be getting old if you want soft and cushy seats
I like the truck mods and you've done an exceptional job in their implementation.
I'm really impressed with your resourcefulness and ability to get the work done. Seeing the work you've done on your truck explains the high quality of work you've been doing on the Argosy. You have a very good attention to detail.
Do you plan on towing the truck behind the Argosy or a trailer for motorcycles?
Old 04-12-2023, 09:06 PM   #678
1977 20' Argosy 20
Yuki,
Exactly! I prefer comfortability to maneuverability on my truck. I can't imagine driving car with hard seats like a bucket seats.
Thank you so much! I'm honored to hear that from you. My truck has been added exceptional or abnormal modifications since it was owned by me. Probably, I can't sell my truck even if old cars' value is being increased recently, nobody want to buy it due to the modifications! Therefore I keep going my way!
Anyway, I have to resume my Argosy restoration work, I'm going to do that soon!
No, I don't have any plans to do that for now. Because the body size of my Argosy is too much for the roads in Japan, even if it has only 20' long. Towing something should be annoying. However, I'm planning on loading my mini bike with a hitch carrier behind my Argosy.
Old 08-18-2023, 07:54 AM   #679
1977 20' Argosy 20
I'm back on my Argosy!
This is the first time to do working my Argosy in 2023 even if it's already in August. Anyway, it's time for replacing wheel bearings and a seal.
The bearings seem to be OK, but the seal has damaged so it needs to be replaced. I don't want to play with too heavy brake drums many times, so I decided to replace the bearings at this time.
A sliding hammer worked very well for intalling the bearings and the seal due to the deep shape on a brake drum.
The outer bearing needs to be placed on next to a snap ring. (Do not pushed the outer race out more than necessary)
The mission has completed. And I did the same thing to do at the opposite side.
There are still a lot of things to do!!
Old 08-19-2023, 03:12 PM   #680
Nice job
Those drums are heavy aren't they. Did you need to have them machined?
1973 26' Argosy Restoration bbnaugher All Argosy Trailers 14 10-09-2011 07:35 PM
Vintage Argosy Restoration billyhip All Argosy Trailers 4 12-07-2009 04:42 PM
Argosy Restoration 2007 hera761 Member Introductions 3 05-27-2007 01:06 PM
Argosy Exterior Restoration Liisa Clearcoat, Exterior Paint & Trim 1 09-04-2006 08:51 AM
Start of restoration '77 Argosy 20ft barbwire All Argosy Trailers 18 08-15-2004 06:42 PM
