Old 12-05-2021, 01:33 PM   #601
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Outstanding work!
mayco is offline   Reply With Quote
Old 12-05-2021, 05:33 PM   #602
chevy2man's Avatar
2024 Atlas
Jeffersonville , Alabama
Very nice!
chevy2man is offline   Reply With Quote
Old 12-06-2021, 06:24 AM   #603
GREEN ARGOSY's Avatar
1977 20' Argosy 20
Matsubushi , Saitama
PeterH-350LE, mayco and chevy2man
Thank you!
I'm very glad to hear your message, and also you gave me the motivation to work!
GREEN ARGOSY is offline   Reply With Quote
Old 12-13-2021, 07:20 AM   #604
1977 20' Argosy 20
I have been working on making the subfloors. And playing with other tasks some times, because I still have lots of to do things. I can choose many options yet!
I'm not going to use any equipments powered by propane gas, that including a furnace as well. So I don't need these stuffs. Probably it's assembled by two pieces, but it seemed like hard to disassemble due to rusted and sticked...
So I decided to cut it off!
Then stripped painting with paint remover.
My Argosy is a thick make-up, I need to apply paint remover then scrape it by several times at the same area.
There're bruises on the body, because it's an Argosy...
I have done it at the opposite side.
Since it's the Argosy, there're scratches on the body...
Anyway, I don't care about that!
I polished the body a little bit. I'm going to polish the body more and more! When it got a shiny surface, my face dull accordingly.
Old 12-13-2021, 12:32 PM   #605
Originally Posted by GREEN ARGOSY View Post
Hi Brad,
Does that mean disease, illness or whatever?
My symptom is.. eager to do replace everything with aluminium
Yuki, you have WAY to much energy
Looking good!
1975 24' Argosy Motor Home
Old 12-19-2021, 06:33 AM   #606
1977 20' Argosy 20
Looking good!
Thank you
I'm still keeping the energy.
​But I'm not sure which will come first the polishing work is completed or my energy is run out.
My hands are almost dead..
Old 12-19-2021, 07:42 AM   #607
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Aghhhh....
The dreaded Argosy 'orbital sander marks'.
Good luck and I hope your energy keeps up!
martin300662 is offline   Reply With Quote
Old 12-21-2021, 06:50 AM   #608
1977 20' Argosy 20
Originally Posted by martin300662 View Post
Aghhhh....
Thank you! I need to keep the energy by some beverages like Red Bull!
Yep! That's like a nightmare.. But we can find that marks under paint easily in an Argosy!
I always delete it with hard abrasives and an angle grinder. I hope the body won't worn out by grinding!
Old 12-25-2021, 07:25 AM   #609
1977 20' Argosy 20
I've been fighting the dreaded orbital sander marks recently.
Today's enemy was this part.
Yes, of course there are lots of marks!!
Here is my weapons for the first step of polishing.
I use an angle sander with a sisal disc (The top left in the picture). The sisal disc is made from sias hemp, it's harder than cotton or felt buffing discs. And I use an abrasive that is called "Sisar". The brown color bars in the picture are the Sisar and a tripoli abrasives. Those are look similar but they have different material. The Sisar is an oil based alumina abrasive and the tripoli is an oil based cilica one.
The Sisar is coarser than the tripoli, so I usually use this ​for the first step.
I polished a little bit.
The Sisar can delete the mark unless a deep wound.
But it cannot remove deep scratches or corrosion marks. There are many corrosion marks near rub rails.
The first step is finished.
Old 12-25-2021, 07:29 AM   #610
1977 20' Argosy 20
The 2nd step.
I use a single action polishier and a special juice and a metal abrasive.
The juice is made with a tripoli abrasive and kerosene.
It works well of a medium polishing.
Next, this is very famous, popular and inexpensive metal abrasive in Japan. It's a liite bit coarse grid (3μ) one.
The 2nd step was finished.
Old 12-25-2021, 07:35 AM   #611
1977 20' Argosy 20
The final step.
The last weapons are a
double action polishier and fine grid metal abrasive (1μ).
The polisher is attached a felt buffing pad, and I wrap with a cotton cloth when polishing.
All of steps were completed.
Umm... The mark is left a little bit, so this is not parfect mirror finishing. Anyway, I cannot spend lots of time polishing, and there are left surface that needs to polish on the body, I'm satisfied it at the moment.
I'm going to do the same process at rear of the rig tomorrow!
If I need to delete the marks compleatly, I think sanding pads or papers will work better.
I've used a sanding pad that is like a Scotch Brite before. It was able to cut the marks, but not parfectly. I should have used coarser one. In fact, the marks are tough to beat!
Old 12-28-2021, 10:27 AM   #612
chevy2man's Avatar
2024 Atlas
Looking good!
Old 12-31-2021, 04:48 AM   #613
1977 20' Argosy 20
Originally Posted by chevy2man View Post
Looking good!
Thank you!
Today is the last day of the year. But I worked on the Argosy, because I'm a hard worker.
The last work was polishing a drivers side rear body.
I wish you all the best in the new year.
I hope my Argosy get back on the road in 2022!
Have a nice holiday!!
Old 12-31-2021, 08:25 AM   #614
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Happy New Year Yuki
Fingers crossed that your are successful in getting your Argosy back on the road during 2022!
Old 01-01-2022, 02:24 AM   #615
1977 20' Argosy 20
Happy New Year Yuki
Happy New Year Martin
Thank you! I'll try my hardest!
Old 01-01-2022, 06:51 AM   #616
chevy2man's Avatar
2024 Atlas
Happy New Year Yuki!
Old 01-03-2022, 02:51 AM   #617
1977 20' Argosy 20
Happy New Year to you too!
I'm looking forward to seeing a new post on your thread!
Old 01-03-2022, 04:36 AM   #618
1977 20' Argosy 20
The first work in 2022 was installing a front fender trim.
The fender trim will be fixed with bolts and nuts, so I make holes on it and a body.
The first, marking an out line of the fender trim on the body. The body was not trimed evenly, I measured the distance between the outline and the trimming line, then wrote numbers in metric.
Next, chose the points there're enough space for making the holes, then drilled eleven of 3mm holes.
I'm going to install an outer fender trim. Unfortunately it has damage, needs repairing.
However, I cannot repair smashed aluminum perfectly. Probably I'll use body filler for forming the outer fender.
Old 01-04-2022, 08:32 AM   #619
Repair the trim as best you can and move on. Those are called "battle scars" and can be considered a badge of honor
Old 01-09-2022, 04:35 AM   #620
1977 20' Argosy 20
"Battle scars" sounds nice! That's cool.
However, that trim is bent and ripped, it looks pitiful..
I'm going to restore its shape with pliers as far as possible. And use body filler or FRP for forming, then paint it. I'm not sure, still thinking about it, though.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
1973 26' Argosy Restoration bbnaugher All Argosy Trailers 14 10-09-2011 07:35 PM
Vintage Argosy Restoration billyhip All Argosy Trailers 4 12-07-2009 04:42 PM
Argosy Restoration 2007 hera761 Member Introductions 3 05-27-2007 01:06 PM
Argosy Exterior Restoration Liisa Clearcoat, Exterior Paint & Trim 1 09-04-2006 08:51 AM
Start of restoration '77 Argosy 20ft barbwire All Argosy Trailers 18 08-15-2004 06:42 PM
