09-27-2021, 08:32 AM
#581
Richmond
, Kentucky
Originally Posted by GREEN ARGOSY
I haven't updated my thread for a while, but been hard working on the Argosy!
I need to do fabricaion or modification. Anyway, I think it should not be hard!
Yep, you definitely have aluminitus......
1975 24' Argosy Motor Home
09-27-2021, 08:33 AM
#582
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Attachment 404988
Attachment 404989
I installed insulation foam panels between subfloor and outer panel at the middle of coach.
Attachment 404990
Then lay an insulation sheet on subframe and the insulation foam.
Attachment 404991
Cut the sheet and placed to position then fixed with an aluminium tape at edges and openings.
Attachment 404993
Subfloors will be installed like this.
Attachment 404992
Here is the insulation sheet that intends for residential homes. I have two of 30meter rolls, I'm going to use this insulation for under roof, wall and floor.
The other thing..
Attachment 404994
I got new step, I'm going to replace a steel ones with the new one.
Attachment 404995
This steel step is working well, however I prefer looks of the aluminium.
Attachment 404996
Hi Yuki
The steps are the same as I got for Peanut. Did you get the manual or electric version?
09-27-2021, 11:28 PM
#583
1977 20' Argosy 20
Matsubushi
, Saitama
Hi Brad,
Does that mean disease, illness or whatever?
My symptom is.. eager to do replace everything with aluminium
09-27-2021, 11:59 PM
#584
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by martin300662
Hi Yuki
Hi Martin,
I got the manual version. The electric one would be nice, but it's pricey..
The manual one is expensive as well for me...
09-28-2021, 12:49 AM
#585
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Here the manual version is around 20,000¥ ($180), and the electric is around 35,000¥ ($315), and there is also a kit to add electric to the manual step (the metal work is the same).
Let me know if you need any parts as the are very readily available here.
09-28-2021, 06:27 AM
#586
1977 20' Argosy 20
Matsubushi
, Saitama
Thank you!
That's great! Those prices are far from ours.
At first I was thinking of buying the step from ebay. Because its price was around 20,000¥, but the shipping cost was 15,000¥ (That's almost same as the product price.. ), so I decided to buy it from a local RV parts shop. The manual version is around 33,000¥, eventually it was cheaper than ebay.
They sell the electric one for 63,000¥, at least I don't want to buy that..
If I have spare money or need electric operation in the future, to add the power kit to my step!
09-28-2021, 08:59 AM
#587
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
09-28-2021, 10:46 AM
#588
Richmond
, Kentucky
Hi Brad,
It's nothing money can't cure
09-29-2021, 06:50 AM
#589
2024 Atlas
Jeffersonville
, Alabama
Hi Yuki,
Great work! I’m still enjoying your thread. Can’t wait to see the finished coach!
09-29-2021, 08:55 AM
#590
1977 20' Argosy 20
Matsubushi
, Saitama
I think that price is not bad.
Wow! Did you carry two sofa beds by plane?? Your transportation method is very nice!! Anyway, I cannot imagine a situation like that someone checks their bed at an airport.
I just remembered that my carry-on baggage was too heavy due to many cars and motorcycles magazines were packed in my bag. I had to throw out some stuffs from the bag at Heathrow airport!
09-29-2021, 09:06 AM
#591
1977 20' Argosy 20
Matsubushi
, Saitama
Yes, I agree with you. Therefore, my disease will never be cured!
09-29-2021, 09:18 AM
#592
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by chevy2man
Hi Yuki,
Thank you!
It has been progressing slowly and slowly.. I can't wait to drive the coach on the road!
10-01-2021, 07:57 PM
#593
tallahassee
Thank you!
Thought I’d check in also, just to let you know that I’m reading and very impressed with the details of this renovation. You do good work.
Carol
10-03-2021, 05:55 AM
#594
1977 20' Argosy 20
Matsubushi
, Saitama
Carol
Hi Carol,
Thank you
I'm glad to hear that, also I got motivated!
10-10-2021, 08:02 AM
#595
1977 20' Argosy 20
Matsubushi
, Saitama
The insulation work has been progressed..
And I started removing ceilings.
Removed a roof air conditioner unit and ceiling lights before removing ceilings.
At first I didn't understand its structure, so I didn't have any idea for how to remove the ceiling. I removed all of revets on the cielings but I couldn't take the ceiling off the coarch.
I figured out the structure. Aluminium moldings and side ceiling panels were fixed together by revets. I should remove the middle ceiling panel first, then remove the aluminium moldings and side seiling panels at the same time.
The middle and side ceilings were removed.
Also I removed rear end cap.
I'm going to collect pinky fluffy insulation next time!
(I don't like it though..)
10-24-2021, 07:34 AM
#596
1977 20' Argosy 20
Matsubushi
, Saitama
10-24-2021, 04:06 PM
#597
2024 Atlas
Jeffersonville
, Alabama
Looking good!
10-31-2021, 05:13 AM
#598
1977 20' Argosy 20
Matsubushi
, Saitama
Looking good!
Thank you!
I painted the chassis and frame yesterday.
My project is progressing slowly but steadily.
12-05-2021, 07:19 AM
#599
1977 20' Argosy 20
Matsubushi
, Saitama
It's time for installing a subfloor at the rear of the coach.
I decided to use more bolts for the aluminium angle because of a little bit torsion. There is thin rubber sheet between the aluminium angle and a frame.
I used low profile bolts and Loctite for fixing.
25mm (1") insulation boards are sandwiched between aluminum composite boards.
Then installed a subfloor. I painted it but I'm going to lay a flooring over the subfloor, so painting is just protection.
A channel frame and the floors are bolted up, it's steady!
I haven't decided to use a black holding tank or not yet. So the middle area is blank space for now. I will decide it later, that's the reason of why I made three separate floors.
The one of my plan is installing a portable generator for that place, but I'm not sure. I have lots of things to do, so this is low priority one.
12-05-2021, 09:58 AM
#600
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Your work is outstanding, much nicer, more precise and cleaner than new!
AIR #13
