01-10-2022, 08:01 AM
#621
1977 20' Argosy 20
Matsubushi
, Saitama
02-06-2022, 06:59 AM
#622
1977 20' Argosy 20
Matsubushi
, Saitama
02-20-2022, 08:31 AM
#623
1977 20' Argosy 20
Matsubushi
, Saitama
My Argosy got a floor, it's meaning I'm got extra workspace.
I applied caulking for wheel wells where was welded by me, because I can't trust my welding skill.
I made wheel wells by steel sheet in the past. But I don't like to contact steel surface and alminium suarface so I dicided to redo it.
I cut the outside steel panel then riveted an aluminum panel.
I'm going to attach mud flaps under silver plates. It's intended to protect the gap between the wheel well and frame from water splash.
It's time for trimming the aluminum panel. The existing cutout seems like over size, some holes are lacking and missing.
The first, I attached fender trims then markerd outline on the tape.
The fender trim depth is about 19mm.
Next, mark 19mm points (Lots of points) from the outline.
Connect the points, it appears the trimming line.
Then cut the triming line with a jigsaw.
The mission is conpleted.
Do the same things for the other side.
To be continued..
02-21-2022, 04:41 AM
#624
2024 Atlas
Jeffersonville
, Alabama
Looking good!
02-27-2022, 05:30 AM
#625
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by chevy2man
Looking good!
Thank you!
I make front mudflap brackets recently.
The restoration project is progressing slowly...
02-28-2022, 10:21 AM
#626
Richmond
, Kentucky
Yuki, that is an interesting upgrade in the wheel wells. I've considered doing something like that but so far have not actually done anything. My big concern was road debris getting caught up above.
It will however eliminate the pounding that the panel takes normally. My Argosy was rusted badly in that area and I had to rebuild the 1"x2" framework and replace the steel cover plate.
How good or bad are the roads in Japans?
1975 24' Argosy Motor Home
03-01-2022, 12:35 AM
#627
1977 20' Argosy 20
Matsubushi
, Saitama
Mine was rusted as well. Also the subfloor was rotted due to came water splash from gaps. That's the reason why I made new frames and panels for the wheel wells. And, there was an electrical junction box in there. I cannot understand why the builder put that in the location where can be wet.
This mudflap is intended for the protection from splash and road debris, but it is not covering around the whole tire, so above of the tire area might be pounded by them. If it happens too much, I will add extra mudflap.
I'm going to paint an underbody coating spray (it's like a Noxudol) to the wheel well and attach a mudflap in front of the tire too.
Most roads are paved, there are not bad condition. Of course we have gravel roads over here, however there are usually narrow width so the Argosy cannot go through this kind of roads!
03-19-2022, 07:35 PM
#628
1979 24' Airstream Excella 24
Tipp City
, Ohio
Yuki
I love the way you rebuilt your rear wheel wells. Man, that's a lot of work but, you should never have water infiltration again. Keep up the good work , it looks awesome!
03-22-2022, 07:34 PM
#629
1977 20' Argosy 20
Matsubushi
, Saitama
Originally Posted by Gregsch
Yuki
Thank you!
Actually, I'm very sensitive about rotting due to splash water. I'm going to apply ton of sealant to everywhere the gaps or the junctions.
04-03-2022, 08:48 AM
#630
1977 20' Argosy 20
Matsubushi
, Saitama
04-04-2022, 11:12 AM
#631
2024 Atlas
Jeffersonville
, Alabama
Very cool Yuki!
04-06-2022, 12:30 PM
#632
Richmond
, Kentucky
Originally Posted by GREEN ARGOSY
New compartment cover is made of steel metal sheet, however it will be attarched the aluminum skin with aluminum angles.
Attachment 413908
The compartment cover was welded. It looks like my wheel well cover!
Attachment 413909
I'm going to rivet the alumiumn angles and a compartment door frame.
The compartment and cover look really good. I made mine out of steel as well. My compartment originally had two layers. The inside was a steel box and then insulation was laid over it and an aluminum box was built to cover everything. I will likely use some sort of insulation but I don't know about installing an aluminum cover.
Actually, I haven't decided what I'm going to store in this compartment box. It might be a portable generator, a split type air conditioner...
Alcohol.....
04-20-2022, 08:49 PM
#633
1977 20' Argosy 20
Matsubushi
, Saitama
Very cool Yuki!
Thank you!
I have not updated my thread recently.. I need to work harder!
04-20-2022, 08:50 PM
#634
1977 20' Argosy 20
Matsubushi
, Saitama
Alcohol.....
Thank you!
My compartment didn't have an aluminum box and insulation, there was just rusty coating on the steel surface. I'm going to lay insulation sheets and probably sound-deadening sheets if I install a generator in the compartment.
Alcohol? That's a good idea! I might install a beer barrel to the compartment. There is a fuel tank at the opposite side, then this side will be a fuel tank for the driver! However, driver's fuel economy is more costlier than the V8's, even if world oil prices increase more than now.
06-18-2022, 08:03 AM
#635
1977 20' Argosy 20
Matsubushi
, Saitama
06-18-2022, 04:16 PM
#636
Richmond
, Kentucky
The wheel wells and chassis look really good!
I think it would have been easier for me if I had just hired you work on my Argosy
06-20-2022, 07:05 PM
#637
tallahassee
I played with other my toys recently.
Ready to install a motor and a transmission!
Look forward to seeing the motor and transmission installed and ready to run. So what kind of toys kept you away for so long?
Carol
06-21-2022, 07:27 AM
#638
1977 20' Argosy 20
Matsubushi
, Saitama
Thank you!
I'm honored to hear that. However, I need so much time for all the tasks, so I am something like an inefficient worker.
06-21-2022, 08:23 AM
#639
1977 20' Argosy 20
Matsubushi
, Saitama
Carol
Thank you
I'm looking forward to that too. The motor and transmission are sleeping in my garage for a long time and taking up big space. To tell the truth, I really want to put it away immediately!
My toys are Mercedes T1 van and Honda CBX.
The van was abandoned outside for a while, so the body and chassis were rusted and rotted. I have been repairing that.
I haven't tried starting the motor yet, so I'm not sure it is alive or not.. I hope it will run.
And I repaired front forks because of leaking fluid. Replaced bad seals then it's fixed!
06-22-2022, 06:06 AM
#640
tallahassee
Thank you
My toys are Mercedes T1 van and Honda CBX. )
In my life, that Mercedes van would not qualify as a toy! My father would say “you are a glutton for punishment”. Hopefully the Honda isn’t just a pretty toy. Hope you have places to ride without lots of traffic. Over here motorcycles can be quite dangerous in city traffic.
Carol
