Originally Posted by beemergb
Thank you for giving me this info , the person who is selling it sent me this the id plate on the chassis . Does this mean it weighs 12500 Lbs ? Hope to hear soon Harry
No Harry, it means the maximum weights (total, front and rear axle, called GVWR, and front and rear GAWR) are 12500/5000/7500.
Below is the chart from the owners manual to explain more
You will see the maximum weight is 12500lb (5700kg) but the actual weight is the curb weight (between 7800-8200lb/3500-3700kg).
In Europe you will register the maximum weight (and need to make sure your driving license allows you to drive that maximum weight, ie your driving license needs to be for up to to 7500kg/7.5tonne to drive a 24ft).
