06-10-2018, 01:59 PM
#1281
Richmond
, Kentucky
2" of insulation would definitely be nice! As you suggested, the high traffic areas, which would be right down the center. So you'd be looking at insulating about a 36" to 42" wide section. It would be time consuming but it should be doable. My guess is the main thing to look out for would be the exhaust system. You might need to shield the insulation that is above the exhaust/muffler.
1975 24' Argosy Motor Home
06-10-2018, 02:00 PM
#1282
Richmond
, Kentucky
Tony, how far apart do I space the screw fasteners holding the Coosa down?
06-10-2018, 03:02 PM
#1283
Dazed and Confused
Hillsburgh
, Ontario
I wouldn't go further than 6-7". IIRC I started 4-5" away from the channel and stopped 1 1/2" away from the end of the sheet; however your layout may require a different approach.
Cheers
Sidekick Tony
06-10-2018, 03:40 PM
#1284
Richmond
, Kentucky
Cheers
Sidekick Tony
I can work with those numbers, thanks.
06-13-2018, 07:31 AM
#1285
Richmond
, Kentucky
Started installing the balance of the Coosa board. Here's a sneak peak at the latest piece installed.
06-15-2018, 06:10 PM
#1286
Richmond
, Kentucky
Finished cutting and fitting the rest of the Coosa board today. I still have about a hundred fasteners to install and should be able to finish that up tomorrow.
Needless to say it looks a whole lot different inside now!
06-15-2018, 06:36 PM
#1287
Dazed and Confused
Hillsburgh
, Ontario
There's something about laying a new subfloor that gives you a boost in a project; you know you still have miles to go, but it's clean, it smells clean, and its neat to walk on it. I accomplished something today.
Been there, done that.
Cheers
Sidekick Tony
06-16-2018, 01:30 AM
#1288
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Big landmark Brad....I am happy for you.
I would get a chair and just sit in it for a while and appreciate what you have done to get this far.
Heck it now qualifies as an aluminum tent so you could join the caravan when it come to the National Park. Beats Mark having to sleep in his SUV!
06-16-2018, 05:03 AM
#1289
Richmond
, Kentucky
That's a good idea
Of course the odds are if I sit in the chair I'll fall asleep from exhaustion!
I've been thinking about that. There's still a lot of stuff that has to happen but there's a reasonable chance it that could.
06-16-2018, 05:06 AM
#1290
Richmond
, Kentucky
Cheers
Sidekick Tony
Definitely miles to go but I can finally kinda sorta see the light at the end of the tunnel!
06-16-2018, 10:45 PM
#1291
Take me back to the 70's
1970 21' Globetrotter
1971 29' Ambassador
1977 20' Argosy 20
Boston
, MA
Looks AMAZING Brad!! [emoji1376][emoji1376]
Jami
77 20' Argosy Motorhome-
70 21' Land Yacht GT-renovating
75 20' Argosy Motorhome...ISO. radiator
06-17-2018, 01:06 PM
#1292
Richmond
, Kentucky
With the floor done I can finally start working on a bunch of little things
I cut the openings in the back for the brake/tail light housings that I'm going to install. They look a little crooked in the picture but that's because they're just sorta sitting in the holes. I'll make sure they're straight before I fasten them in place!
If you're wondering about the left rear corner damage, I'm going to be replacing that panel with one I got from John. I actually cut the opening in that panel first to make sure my pattern was right. I figured if I botched the job it wouldn't be a big deal since I was replacing the panel anyway
I also sealed around the opening in the floor where the fuel filler hose passes through. Putting the gas tank back in place should happen in a week or two.
I plan on making a little housing around the filler opening that's sealed so gas fumes and moisture can't get inside the coach.
06-17-2018, 03:52 PM
#1293
1984 27' Airstream 270
Scotia
, New York
Didn't that year have the plastic cowling with the tail lights, or are they like the Airstream tail lights, or are you converting?
Do not take life too seriously.
You will never get out of it alive.
06-17-2018, 04:16 PM
#1294
Richmond
, Kentucky
Converting. Mine originally had the plastic housing with the rectangular lenses. Only the 74 motorhomes had this style of lense. The 75 and later Argosies used the typical 4" square lense with the plastic housing.
The plastic always cracks and they are a maintenance headache. I liked the looks of the 69 to 74 tail lights from the trailers so decided to use those instead. Besides, they are nice cast aluminum housings
06-17-2018, 05:00 PM
#1295
Dazed and Confused
Hillsburgh
, Ontario
Boy those tail lights look familiar.....almost Toyota like, but not. Do you know what vehicle they came off of?
Cheers
Sidekick Tony
06-17-2018, 06:26 PM
#1296
Richmond
, Kentucky
Cheers
Sidekick Tony
I never could never find out what vehicle Airstream got them from.
The early Argosy trailers used them as well.
06-21-2018, 07:38 AM
#1297
Richmond
, Kentucky
As much as I would like to think the dirty grungy work is now done since the floor replacement has been completed I have to keep reminding myself the dirtiest and grungiest task is still left to do. That task is removing the rest of the interior panels, end caps and wall/ceiling insulation
I do think once the insulation has been removed I can say the worst is definitely behind me!
The debate I'm having with myself at the moment is whether to tackle the insulation mess now or put it off and have it continually stare me in the face. I'm thinking of taking the July 4th week off work to tackle this job. I have to keep telling myself, the sooner I get this part done the sooner it will all start going back together again!!
06-21-2018, 08:25 AM
#1298
1982 31' Airstream 310
champaign
Cheers
Sidekick Tony
Absolutely!
06-21-2018, 11:43 AM
#1299
Richmond
, Kentucky
Originally Posted by mayco
Absolutely!
It's definitely a weird feeling to step up inside the coach and be able to walk around with out worrying about falling through the floor openings
06-22-2018, 12:05 PM
#1300
champaign
Have you done much or any 120volt wiring while the bottom panels were off? Other than a few outlets is there much 120volt wiring behind the upper skin panels? Have you got your wiring schematic pretty much nailed down? One place I'd add a 120volt outlet would be right behind the drivers seat in the wall. Ive got an extension cord semi permanently run down there. Lynn sits on that end of the couch and uses it for her chargers, also a handy spot to plug in a shop light when working on the motor.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
